Vrockola pro getting stuck after song - Computers & Internet
How to delete songs off of the eclipse 180 pro mp3 player
it is easy to hook it to a computer and look for it as a Drive, then go into it and delete the songs you do not want.
Apr 30, 2015 | Eclipse 180 Pro 4GB* Video MP3 Player
The Iview 102dv player played a music dvd ok for the first 3 times. The player is about 2 months old. It gets stuck on the first song of the music dvd. If taken out, then it may play from the 2nd song...
Not an expert in DVD players, But it sounds like a scratched DVD or a weak laser. You could try buying and running a laser lens cleaner through it, as that will clean the laser and make it play better.
Also check if there is a firmware update for the DVD player.
May 30, 2011 | RJ Tech iVIEW-102DV DVD Player
I have a gpx mp3 player, model MW140R. I have downloaded music to it before. I erased some songs. Now my windows vista home basic does not recognize when the mp3 is plugged in. The sync botton will not...
I just recently purchased the GPX MW140R. I can load .mp3 songs to it and remove them but my problem is that when I'm selecting songs, there are times that it will come to one and get stuck and the only way for me to get out of that stuck mode is to turn it off by removing the battery. Why is it that it gets stuck on certain songs and not others when they are all .mp3 format?
Any help in resolving this matter would be greatly appreciated.
Jeff... (jledee0405@yahoo.com)
Is there something that I need to update on that unit or what? Thanks again...
Mar 21, 2011 | GPX MW3836 MP3 Player
Using oakley thump pro 512mb, once reset glasses comes on but unable to use any of the controls to change song forward or backward or even to change volume. this is after fully charging them. what could...
I'm having the same problem....also if you try and forward to the next song...it will repeat that same song 3 times. Its almost like the volume butons are stuck or something...they dont seem to depress the same 9you dont feel a click or anything)... weird.
Aug 14, 2010 | Oakley Thump MP3 Player
Stucked at Refresh database
When the Sansa reads "refreshing database," what it is doing is going through all the songs you've loaded on to it, pulling out the "tag" information (Artist, Album, Song Title, Genre) so it can add this information to its own database which it uses to display the songs to you in its menus.
If it gets stuck during this process, usually it's because of a corrupt song file, or a song file in a format it doesn't understand.
Note that the e280 is only able to play MP3 and WMA audio formats. If you've loaded a different type of audio file onto your Sansa, you'll need to remove them.
If the songs you've recently loaded have all been MP3 and/or WMA, you may have loaded a corrupted file onto your Sansa. Try removing the songs you recently added, and see if the problem goes away.
Feb 27, 2010 | SanDisk Sansa E280 MP3 Player
Laptop got stuck!
You can end the Not Responding Application to task manager, just press ctrl+alt+del then click on task manager, or ctrl+shift+esc to go there directly, click on task that is not responding then click on End Task.
If you want to shutdown your computer that froze just press on the power button of your computer for 10 seconds or more to force it to shutdown.
Dec 17, 2009 | Fujitsu Siemens AMILO Pro V2010 Notebook
My 2GB memory stick PRO duo claims its full,
i) it has nothing to do with the number of songs(like you said 188 songs,,,, 15 picturess... or something like that ), it depends on the storage capacity of your memory stick(2 GB)
ii) some songs may occupy more memory, so may occupy less memory....for eg: song1: 10 mb, song2 : 3 mb; .....
so i would suggest to store some songs(not numbered ...depending upon their capacity and suffiencecy of your card....)
Dec 28, 2008 | Sony 2GB Memory Stick PRO Duo Memory Card
This is my first mp3 player, so I don't really know how they work. My mp3 player is a slick, and it says it works with WMA files. I have followed the directions in the manual, and synced songs from my...
i use free rip pro for copying my cds to mp3.
go to www.freerip.com/ you can download the free version or buy pro for a small amount. pro is just faster really.
once downloaded you can decide where on your computer you store the mp3 files and even if you want to convert the files to other format than mp3. it really is easy to use and works like a dream
hope that this helps
May 11, 2017 | Audio Players & Recorders
Can't get new songs to synchronize
Get the firmware upgrade for the player, and make sure the songs are in the correct format - mp3 format is best
Jul 28, 2008 | Philips GOGEAR SA6045 MP3 Player
Stuck on one song
try fiddling with the repeat option. you might have changed it and it just didn't register.
Jun 03, 2008 | Samsung YP-U3 MP3 Player
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
