Question about Peg Perego John Deere Gator HPX Ride on Toy
ONLY 1 DRIVE TIRE MOVES IN 2ND GEAR - Peg Perego John Deere Gator HPX Ride on Toy
  • mark_staun Sep 27, 2009
    yes
  • romney2012 May 11, 2010
    is this a peg perego brand
    Genius:
  • Peg Perego Master
  • 1,508 Answers
Bad motor, you can order a new one here www.powerwheelsoutlet.com
Posted on Jun 12, 2012
Gear shifter moves but wont go into drive or reverse only to park. car starts fine.
there is a very inexpensive rod underneath which gets weared...check it out and replace it. The rod which connects to the gears and ur gear shifter handle.
May 16, 2015 | 2003 Mazda Tribute
Why won't the transmission shift?
do all gear lever positions work.
REV
1st
2nd
drive, all positions , the car moves?.
or do you mean car is stuck in 1st gear in drive.
try to say what exactly happens,.....
what you do, and what IT did.
May 05, 2015 | 2002 Jeep Grand Cherokee
When putting into reverse it has to be in the
This sounds a lot like the bush's in the gear change linkages are either worn out or gone. I have seen this a few times. Ask someone to check to see if the linkage moves when you move it only one place. Do this with the motor off and the hand brake on. Select nutural. Ask a friend to see if the gear selector moves when you select "D" drive. If there is little to no movement, time to start looking at linkage bush's
Sep 16, 2014 | Cars & Trucks
Slow to shift into 2nd gear slight vibration low speed
Sounds like they may have drained your transmission fluid instead! Look in the Owner's Manual on how to check the transmisison fluid and the engine oil - do not drive the car 'til you check these!
The tire sensor will need to be replaced - either check on Ebay or call the dealer for the part, or a tire dealer may be able to fix it.
GL,
Td
Feb 03, 2014 | Motorsports
Gator won't work in 2nd Gear
sounds like you have a bad motor, you'll need to pull the dump bed off to acess the motors and disconnect one and then see if it works
May 22, 2013 | Peg Perego John Deere Gator HPX Ride on...
Where is the transmission solenoid on a 2000 buick regal?
These solenoids are internal you would have to remove the tire, axle and trans side cover not as simple as it seems by my explanation.
Jun 20, 2012 | 2000 Buick Regal
Car moves slowly in drive but ok in 1-2-3-D.
Someone else mention that the WINTER button makes the car start in 2nd gear to improve traction and reduce slipping in snow and ice. perhaps your winter button is active and it needs to be unclicked. in regular weather starting in 2nd would be like you describe.
Apr 01, 2011 | 2002 Isuzu Rodeo
Steering loose
On these vehicles the main thing to look for when you have play in the steering is on the passenger side of the vehicle in front of the right front tire on the frame the idler arm.How to check and see if it is that jack up the right front(passenger)side tire and when it is off the ground put one hand on front of the tire and the other hand on the back of the tire and try to move it back and forth,if it moves a decent amount then look at the idler arm and move the tire back and forth again and if the idler arm moves up and down say about 1/2 and inch replace it and have the front end alignment done afterwards.
Apr 21, 2010 | 1985 Toyota 4Runner
2nd gear won't work
probably a bad/disconnected shifter switch first of all check to make sure that the shifter switch is connected underneath
Oct 08, 2009 | Peg Perego John Deere Gator HPX Ride on...
Front passenger wheel
Could be a few things. Bad ball joint, cv joint, or others. But I'ld start with the CV joints. Basically, your axle shaft. First way to tell if that's the prob would be to put truck in 4 wheel drive, LOW gear. This will lock up all four tires. Then jack up that corner of truck. If the tire only moves a little before you can't anymore, it's fine. But if you can spin your tire completely, odds are it's your cv joint.
Sep 06, 2008 | 1997 Nissan Pathfinder
Peg Perego John Deere Gator HPX Ride on Toy Logo
Top Peg Perego Toys Experts
Adam Fjeld
Adam Fjeld
Gary
Gary
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
