Question about Leviton Vizia Rf Switch Plug In - RZP03-1LW - Alabaster
I have a plug that has the main source of power coming to it and it is looped to another plug to the right about ten feet away. Now I want to loop another plug from the main one but going about 10 feet to the left. Am I able to put two wires on one set of screws? Or is there another way for this to be done. Thanks
    President:
  • 632 Answers
Check the existing plug connected to the plug where the main source of power is connected to and just connect the new one like the way the existing one is.
Posted on Sep 25, 2009
American camper tent 2455 setup
Finally figured it out through trial and error. This right here is the only correct explanation given anywhere on the net.
First, make sure you have all of your poles. There will be 4 straight green ones, 4 straight blue, 4 straight burgundy with plastic feet, 4 curved yellow, 2 small orange arches, a straight pink and a straight white.
Before you start putting the poles together, stake the tent down at every loop point around the base of the tent. There should be 10 of them. Make sure they're fairly tight and the floor of the tent is taught and flat but not so tight that you tear the tent at the seam. Stake 1 corner first. Then put the second stake through the second loop in order and using a firm pressure, pull away from the first stake, along the line of the tent base, make taught and push the second stake into the ground. Repeat until finished.
The first pole assembly uses in this order, going out from the yellow arch, which is in the center. From one side of that arch, add one green, then a curved yellow, then another green and a burgundy at the bottom. Do the same from the other side of the center arch piece.
This arch outlines the door and goes through the 3 loops on the front of the tent, around the door, so the poles hold the tent up. the loops at the bottom are not for the poles. Every loop around the bottom are where the stakes go to hold it down. For now point the feet towards the back of the tent wherever they will stand on their own. You can fine tune it and firm it up once you get the second arch in place.
All green ones should now be used up.
For the second arch, do the same thing but use the blue instead of the green. So from the one side of the yellow arch, 1 blue, 1 curved yellow, one blue and one burgundy. Same order from the other side of the arch.
Now all the poles should be used up except for the straight pink one and the straight white one. These two go together to make a straight pole that goes through the metal loops attached to the yellow arch pieces and locks the two arch assemblies apart at the top.
Now this takes some maneuvering and some word smithery to describe but what you want to do is make sure the feet of the front arch assembly, are pointed towards the back of the tent and stop at the side. The back arch feet will point towards the front of the tent. They both stop about 6 inches BEFORE the center tie down loop on the SIDES of the tent, on either side of the center loop. The front arch will actually lean forward, with the feet pointed behind it and wedged into the ground, right up against the tent at the bottom, move it around until you have a nice firm feel to it. Same with the back arch but this one will lean away from the back of the tent and the feet pointed towards the front. Once you get the back arch into place, it will really firm up and won't budge.
Another way to describe it would be that the two arch assemblies feet will point towards each other at the side of the tent, about 6 inches before they reach the center loop on either side.
Hope this helped. =)
Posted on Jul 04, 2015
Apr 09, 2013 | Sport & Outdoor - Others
Apr 09, 2013 | MSR Family Tents
Instruction for setup of American Camper tent 8x11
Aug 28, 2012 | MSR Kamp Rite Double Tent Cot
Hello - I have a Boss RC-2 Loop Station. While I enjoy the pedal's capabilities, it almost always creates an unwanted hum and sometimes an electronic pulse in every amp I use it with. (I typically keep...
Make sure the power supply for this is powered from the SAME receptacle as your amplifier is powered. Keep the cable from this to the amp fairly short and high quality cable. Keep guitar away from magnetic field sources... the wall wart adapters are notorious for generating magnetic fields.
Jul 20, 2011 | Roland Boss RC-2 Loop Station Stompbox...
Need to connect Bose 901 + JBL TL260 to HK3490 and swap for classical / rock..
For analog stereo sources, place the Active EQ in a Tape Loop and only select that loop when your'e using the 901's. If you use a digital source and activate a Tape Loop you will kill the source.
If you have a sub, WATCH OUT as the EQ WILL AFFECT its pre-out.
The best solution would be to get a separate amp for tthe 901's and, using Y-cables, share the Pre-Out-Main In with the Active EQ, which would feed the new amp. That would give you HK-controlled volume for the 901's. This eliminates any undesirable Active EQ getting back into the receiver to affect the sub or JBL's..
Nov 11, 2010 | Bose 901 VI Main / Stereo Speaker
I NEED INSTRUCTIONS TO AN OLD AMERICAN CAMPER TENT IF ANYBODY CAN HELP ME ON MY SEARCH TO FIND SOME INSTRUCTION
Jul 12, 2010 | MSR Family Tents
Printer will not complete boot up
On the control board on the right side there is a 330uf 10v capacitor that needs to be changed. The top was bulged on the one I was working on and when I replaced it it works fine. It had the on/off loop going on.
Feb 28, 2010 | HP Photosmart C5180 All-In-One InkJet...
I get a low hum from my speakers. How can I get rid of this?
Boston Acoustics Media Theater HUM. The problem may be the power source. Find another DC power source for the 12 volt. All I had was a 14.5 volt 4.5 amps source Model PS6 power source which fit the plugin socket. Absolutely no hum now and still great sound. However, I would recommend a DC 12 volt source with at least 3 amps output.
Dec 08, 2009 | Boston Acoustics MediaTheater Computer...
Can I wrap excess pump power cable around by discharge pipe
What motor's amp draw? What is the pipe material? If you can loop the wire back and forth and tie it to the discharge pipe with a wire tie you would be better off. I have seen a 110 volt electric smoker melt the power cord in a retractable shop light. A coil of romex without metal at the center will do the same thing.
Sep 29, 2008 | Plumbing
On a kx-ta1232 key system we are trying to run a single line phone for an extenstion to a shop that is 3400 ft away. The line is bridged in the CO. When it is bridged you hear a buzz in the background...
The loop limit of a single line station is 3700 feet on 24 gauge cable. That would be point to point with no bridges. Viking Electronics makes a loop extender that would increase the loop limit to thousands of feet, or you might try search engines for a Proctor 46222 or 224 loop extender.
It's unlikely that the telco will treat your pairs as the loop is probably within specs.
Carl
Aug 27, 2008 | Panasonic Lands Phones
Leviton Vizia Rf Switch Plug In - RZP03-1LW - Alabaster Logo
54 people viewed this question
Top Leviton Electrical Supplies Experts
 Kenneth
Kenneth
Hippy_dd
jdthefixer
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
