Question about Whirlpool LSR5132J Top Load Washer
I HAVE WHIRLPOOL TOP LOAD GSW9800PW2 WASHER, IT FILLS, THEN STOPS (SHUTS DOWN) UNTIL YOU SLAM THE LID DOWN MANY TIMES, THEN IT FINISHES EVERYTHING NORMAL
  • 5,911 Answers
I would recommend you check your lid switch. Slamming the washer lid will only compound the issue and eventually will cause the lid to warp and additionally break the lid strike (if equipped). Due to the frequency of use, the lid switch does wear out and it is the most common cause of these symptoms. Its also an inexpensive repair. If the washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle or drain, this is commonly caused by a lid switch malfunctuion. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug.
If the switch is not activated by a lid strike, it will activated by a hinge actuator located next to either the left or right lid hinge. You will need to remove the operator console in order to access this type of switch.
NOTE: On this type of lid switch the lid hinge has a small rod that is used as an acutator to toggle the switch. In many cases, you can adjust the rod by bending it if the switch is not making contact.
If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If parts are needed, a replacement can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. All these sites offer competitive pricing, so shop all of them for the best price.
This is a very simple repair, that usually costs about $25 to $35 to repair yourself. If you have questions, or require additional assistance, please let me know. I hope this helps you.
Posted on Sep 24, 2009
Must slam the lid on our whirlpool washer to get it to wash after it fills with water.
The lid switch need replacing or adjusted. When the lid is down something pushes the switch down. It could be back at the hinge or a slot elsewhere in the top.
Feb 22, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
Fills with water then won't go to the wash cycle until you slam the lid several times
It sounds like the lid switch is faulty. The washer has a lid switch that checks to see if the lid is open, if lid is open the washer will not start the wash cycle. Check/replace the lid switch and you should be back in business.
Oct 04, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
My washer wnot agitate unless i slam lid
is the lid up during the filling process? the new washers will not agitate unless the lid is down. no need to slam the lid.. There is no pin to push the activator switch.. they are controlled with a magnet...
Jul 31, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
My Whirlpool ultimate II will fill up and then stop
The lid switch need to be replaced. You might try to lengthen the rod that pushes it down. You might try trimming lid bumpers with a razor blade to make the rod go down further.
Jun 30, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
My whirlpool washer adds water then stops.
Check your water level switch for a blockage in the air hose.
Check the kid switch for good contact.
Mar 01, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Cycle stops...
replace the lid switch, or check the connections it might even be your pusing rod for activating the switch
Jun 17, 2008 | Kenmore 24032\24036 Top Load Washer
Washer
Sounds like the lid switch to me .... cheers and merry Xmas from 'downunder'
Dec 24, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool ultimate care II stops during cycle
THe most likely cause for this is either the lid switch or the timer itself sticking.
Sep 14, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
467 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
