Question about IBM ThinkPad R40e 2684 Notebook
Hi again! What is the best way ,step by step ,to download driver from my usb key to hard drive?
    Scholar:
  • 97 Answers
You mean copy a drive from your usb flash card to your hard drive?
If so, go to start, control panel, and find out which drive your usb is on.
Then run the program that wants the driver, and when it asks you where to find it, tell it which drive and directory it's in.
Posted on Sep 25, 2009
Testimonial: "I will try this ,thank you!"
My hard disk hardrive dont read on my computer
w7
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
for xp
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
Downloads to Recover Your Files and Save Your Bacon and 10 Best Free Hard Drive Utilities.
Some addition links found on Google
http://www.datarecoveryreview.net/
http://www.cleverfiles.com/
http://www.easeus.com/resource/hard-disk-data-recovery.htm
hope this helps
Aug 15, 2012 | Ultra G-Technology G-Drive mini - 60GB...
My blu ray dvd doesn't recognise my portable hard drive
w7
for xp
hope this helps
Aug 13, 2012 | Western Digital My Passport Essential...
My device is unrecognized by windows vista it keeps saying I need to update the driver but this I know is built into the unit is there a fix for this?
Try uninstalling the Generic USB Hub and USB root HUB drivers listed in your computer.
Restart the computer and then try connecting the HDD once more.
Nov 11, 2011 | Fantom G-Force MegaDisk 1.0TB 7200RPM USB...
Hi, I have just rebooted my PC, and find myself missing the driver to my Verbatim Hardrive 320 GB. Is it possible to download a new driver, so I again can watch all my pictures I have saved? Hope you can...
No driver is needed, it's just a basic USB external memory. If you get a message about a driver then the pc no longer recognizes it correctly, which means that it has failed.
Your only hope of maybe recovering some data out of it is to dismantle the unit, extract the actual hard disk from within and connect it directly in a desktop - access it from My Computer.
Feb 07, 2011 | Verbatim 320GB USB Portable Hard Drive
Compaq presario M2202AP doesnt recognize WD 3200 external usb drive. I cant find the download site for the corresponding usb hard drive. ...
Hi You can download driver from below link. Click here Install driver then check. Also follow below if still not recognize. First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Try your harddrive in different computer if it is not recognized on another computer too then your harddrive has internal issue.
Let me know if you need further assistance. Thanks for using FixYa
Oct 13, 2010 | Western Digital Passport 320GB External...
Write protection
some kingston drivers have mechanical protection, little slider on the side with symbol of open/close pedlock. this one have problem on your computer...
follow these steps:
1. insert drive into usb port
2. open "my computer"/"computer"
3. click right mouse button on kingston drive
4. left mouse button on "properties"
5, remove tick from button "write protect"
6. save and exit
this should solve your problem, i fnot, then download this driver and try again:
http://driverwhiz.com/drivers-en?brand=Kingston%20USB&logo=Kingston&subid=1002-au-en-90000000464&gclid=CJma3tKkmKMCFQ0dewodgjcRqQ
ther eis emote possibility that driver is infected with malware or virus protecting it from access, best way then is running antivirus on it and then format it.
if you find this advice helpful, please do not hesitate to leave your remarks and vote 4 for me, thanx!
Aug 01, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Win98 driver for Kingston 512Mb flash memory.
Hi!
Here's a link to download original Kingston DataTraveler I (of all sizes available) drivers for Windows 98SE:
http://www.kingston.com/support/USBFLASHDRIVES/downloads/DTI.EXE
Cheers,
Pelu.
Mar 16, 2010 | Kingston Technologies 512MB DataTraveler I...
When hooked up, blue light flashs, never goes solid, anf device cannot be found on my computer.
Hi there.
Try the following:
1. Restart your computer. Check again if the HD is missing.
IF it is still missing, THEN try
2. Unplug the USB drive and plug into another USB slot on your computer. Look for the drive again. If it doesn't show up then do Step 1 again.
A couple of other things to check :
Did the USB drive come with software or drivers that required being installed?
Does the USB drive connect to the computer (type, MAC / PC) that you are using?
For example, sometimes drives are made to work with a particular system, i.e., MAC or PC. AND then there are other USB drives that interface with both systems.
If you have the manual for your drive you can check the Troubleshooting section of the manual. If you don't then you can go to the Verbatim website and download a manual.
I hope this is helpful. Regards,
Feb 09, 2010 | Verbatim (96528) 250 GB USB Hard Drive
How do you install additional hard disk drivers on windows xp
Attach the Hard Driver to the Computer and turn ON the Computer.
If required, restart the Computer again.
The Hard Drive Driver will automatically install in the Computer and the Operating System will detect the Hard Drive automatically.
Good Luck!!!!!!!!!!!!!!!!!!!!!!!
Sep 14, 2009 | Computers & Internet
Seagate FreeAgent Pro - 500GB No detection need drivers
Try doing flea power & the power cycle.
1. Disconnect all the peripherals like keyboard,mouse,printer, scanner & monitor and power supply from the CPU.
And press & hold the power button for 2 min, it will release the flea power from the mother board.
Restart the system & check.
2. Disconnect everything.wait for 5-10 minutes and then connect every thing.
Restart the system.
If it does not resolve the issue then you can try this :
Check this before you try to edit the registry values.
http://developer.apple.com/documentation/Darwin/Reference/ManPages/man1/profiles.1.html
Just remove the registry key it happen when this key is corrupted.
HLKM\System\CurrentControlSet\Enum\USBSTOR
And delete all references to the external hard drive.
And also HLKM\System\CurrentControlSet\Enum\USB
and found the keys associated with the USB to IDE value.
After restarting the system, the drive should be detected & configured automatically by the computer.
Disclaimer : I will not be held responsible for anything that happens to your computer as a result of following my guide. Use this guide at your own discretion and risk.
Also if you still need driver:
This is the best way to download the drivers of all your devices which are connected to the system for free.
You can download the Driver Magician from this link :
http://www.toggle.com/lv/group/view/kl34858/Driver_Magician.htm
Download the reg key from this link :
http://public.box.net/paul123
then doule click & select ok.
Run the program and select update drivers, it will list the list of pdated drivers.
Select the drivers and select download drivers.
If it does not download just select the driver you need and at the bottom you would see a link,
Just copy that link and download from your browser or download manager, I use orbit downloader.
Good Luck.
Live, Love, Laugh.
May 17, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
IBM ThinkPad R40e 2684 Notebook Logo
49 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
