Question about Proview PA-32JK1A 32 in. LCD Television
My xbox360 runs in 1080p through component cables, but only 1080i through hdmi. why?
BECAUSE THIS PROVIEW WILL NOT GO ANY HIGHER THAN 1080I THATS Y. THIS ONE DOES NOT HAVE 1080P SO U WILL NOT SEE IT, ONLY 780P AT MOST!!
Posted on Sep 29, 2009
I have a 47" Visio 1080p. Tv is always set at hdmi
AV inputs are for standard analog video which is 480i. HDMI and Component inputs are the high definition inputs that run at either 1080i or 1080p You won't ever get 1080i or p through AV inputs.
Oct 22, 2012 | Televison & Video
My playstation 3 will not play in 1080p. It used to work, but when we switched cables, it wont work in HD.
When you switched cables, you mean you changed the cord running from the PS3 to the TV? HD content requires an HDMI connection from the PS3 to the TV. It is possible that when you changed cables, you replaced the PS3's HDMI cable with Component Cables which can only deliver in Standard Definition and not in High Definition (720p, 1080i and 1080p).
HDMI:
http://www.playstation3hdmicable.com/images/hdmi2.jpg
Component: http://www.componentcable.net/images/Component%20Cable%20PS3.jpg
Apr 29, 2011 | Sony Playstation 3 (PS3) Console
So i was messing with the display resolution, it was working fine before i started messing with it... i changed the resolution from 1080i with component cables... to 1080p. I lost the picture unti i...
1080i only works with component cables and wont go to 1080p but your hdmi will set it back to 1080i and then switch back to the component cables.
Jan 03, 2011 | Microsoft Xbox 360 Console
Says my hdmi ports are unsupported. they worked yesterday but now it wont work on the dvd player, xbox 360, or the ps3. got any idea of how to fix this or how i can reset the tv?
Hay there i have the same problem and found out my LCD does not support xbox360 via hdmi have to use a componets cable not the standard av cable its the ones that go in to the YB,YR,PR slots like an RCA but they are actualy HD quality cables that will give same affect as using the HDMI cable and its hlf the price to!!. With the use of the components cable you will be able to veiw xbox360 in full hd up to 1080i or 1080p hope this helps as there many unanswered questions here! Who the hell runs this site? They arent very helpfull ay!!!!!!!!!!!!!!! Regards Matt Rocket
Oct 16, 2010 | Hitachi Televison & Video
Hooking xbox360 up for HD in component 1
Thats the highest setting, for component, that TV will show. it really is that simple. You would need HDMI connector to possibly go any higher. but I think you will find it is the TV.
Apr 01, 2010 | Mitsubishi WS-55511 55" Rear Projection...
My Insignia hd 1080p tv is only receiving at 720p. I am using HDMI cables and a telus hd tv box. How do I get it to receive at the full 1080p?
I hate to be the one to break this to you, but there is very little 1080p content available to be viewed on your television. Telus TV outputs only 720p or 1080i video, so you are getting the best available picture already. The exception is Blu-ray, where almost all content is played at 1080p if you use an HDMI cable.
Feb 07, 2010 | Insignia Televison & Video
1080P video via HDMI generates awful interference
Your Plasma's native resolution is 720P. Go into the Blu Ray's output setup. you can choose 480p 480i 720p 1080i and 1080p. Set it for 720p that should clear up the issue.You may have to run Component directly to the TV since you only have 1 HDMI input and you can run Digital coax or optical to your AV receiver for audio. On a 50" TV the difference between 720p and 1080p using "GOOD" cables cannot be seen by the human eye. Above 50, yes it is noticeable.
Hope this helps.
May 22, 2009 | Onkyo TX-SR705 Receiver
Screen randomly flashes black
First and foremost you need to change one of two things. Either your video output settings on your xbox 360, or use an hdmi cable as opposed to component cables. Component cables are only designed to output video up to 1080i, not 1080p(big difference). So if you try to run a output signal of 1080p with cables only made to send 1080i, you will have picture issues.
Nov 23, 2008 | Sharp Aquos LC-32D40U Television
HDMI XBOX360 Elite -"No Signal"
The connection order can be a key issue as to whether or not the HDMI signals will pass through the system. For best results the receiver should be turned on first, then the source device(s) and then the display. The reason for this has to do with getting the equipment to handshake properly for the HDCP protocol.
If HDMI video will not pass through your receiver, you may with to just connect the xbox using the component cables. Since component will pass through 720p and your TV is 1080i you should expect the same qualtiy and a more crisp picture.
Oct 12, 2008 | Denon AVR-2307Ci Receiver
Ws-65807 65" mitsubishi rear projection tv
For this unit and the addition of the secuity features of Blu-Ray, the 1080i you set can handle is through the component input from a DVD player or an XBOX. In the configuration menu of the PS3, change the resolution to 1080i and see if your set will reset to it. The 1080i on the Blu-Ray is only possible on the HDMI cable as far as I could find, again due to the security restriction. The Mitsu is not going to run it in 720p due to the PS3 is running component and cannot control sync to this set.
Aug 01, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Proview PA-32JK1A 32 in. LCD Television Logo
105 people viewed this question
Top Proview Televison & Video Experts
Steven Wander
Steven Wander
joncin91
Level 1 Expert
Are you a Proview Televison and Video Expert? Answer questions, earn points and help others
