Question about HP LaserJet 9500mfp All-In-One Printer
Okay, where do I start on this machine...... Initial call the machine would not power on so I replaced the power supply. Machine then would turn on but would tell you doors were open and throw 57.07 and 57.06 errors, after testing voltages I replaced the T-CRG board with no change. I then replaced the DC controller and had no change. I did more voltage readings and found that I only have 1 24v lead coming from the HVPS so I then replaced the HVPS. After all of this the machine still had not changed the way it acted. Out of desperation I changed the little voltage regulator on top of the power supply(used to one from the old one) The machine no longer said doors were open, all the fans turned on, no more 57.XX errors. Now to the problem at hand. When the machine initializes it tells me no cartridges and no drums are installed, I have changed the supplies, I have also changed the memory reader PCB. I am stuck, has anyone else run into this? edit: I can disable cartridge check and the printer will printer perfectly.
5 Suggested Answers
EPIJAB
  • 89 Answers
SOURCE: Insert C toner cartridge
Have you tried upadtaing the firmware?
Posted on Mar 24, 2008
komguy
  • 2306 Answers
SOURCE: A challenge for you experts HP CLJ5500
Sounds like the timing gears that drive the carousel could be off by 1 tooth. If the timing isn't right when the carousel turns to the cartridge it can give that error.
Posted on Oct 28, 2009
SOURCE: 10.10.00 supply memory error coming on HP Laserjet 5200 Printer.
Dear Sir,
I has change the printer cartridge. After changing the printer cartridge above mentation comming. When I am making printer power on the (10.10.00 supply memory error) display. Please tell me how to solve this problem. Best regards,
Thanking
Ajom Khan Hero
Mobil No.092 5192797.
Al Nahr Co.Ltd
Tripoli - Libya
Posted on Feb 20, 2010
  • 38 Answers
SOURCE: I am getting error: 10,1000 supply memory error reinstall
You are using re manufactured toner and it has a bad chip. Replace the toner.
Posted on Jul 12, 2010
My Bosch 1244E will not go on I plug it and no power?
Washing Machine Won't Start - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jun 21, 2013 - If wall socket & fuse are OK but washing machine won't start ... didn't work - so I tried plugging my Hoover washing machine into another plug and all systems are go! ... I have a bosch washing machine which is 16 months old.
Washing Machine Fault Diagnosis - How to repair
www.how-to-repair.com > Home > Washing machines
Nov 11, 2014 - Washing machine will not start, no power. ... So begin at the plugand make sure that there is power to the socket and that the fuse is okay ... I have aBosch washing machine which is leaking from underneath and the water is coming out the front at the bottom. .... It washes but won't go into rinse or spin.
Washing Machine Will Not Start - What To Check - How To Fix
removeandreplace.com/.../washing-machine-will-not-start-what-to-check...
Apr 10, 2015 - Be sure the washer is plugged into the electrical outlet in the wall. ... If the lid switch is faulty, then the washing machine will not start. ... If the lid switch is being pressed but no power is being supplied to the washers motor, ..... October 28, 2014; Bosch Washing Machine Error Fault Codes October 28, 2014 ...
Dishwasher Will Not Turn On - How To Fix ...
Jan 19, 2016 | Bosch Washing Machines
Will not power up
If it's not the battery or the power supply cube, it may be a motherboard power component.
Also, if there are two memory modules try removing one and if the machine doesn't boot replace the first and remove the second.
May 25, 2014 | Computers & Internet
How to fix samsung washing machine model TORNADO 7.0kg WA90B error
E1: Water Supply Error
-Display Shows 'E1'
-Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the water level presetting for 20 minutes or more at the time of initial water supply.
-To help fix this problem please check the Hot and Cold water intakes, there is a filter screen in each input valve, remove and clean these filters. ** Make sure you replace the filters, they are very important for the operation of the Washing Machine.**
-The error status can be cleared by turning POWER S/W OFF and resuming the POWER ON initial status.
Nov 01, 2012 | Washing Machines
Error E1 samsung washing machine model TORNADO 7.0KG WA90B
-Display Shows 'E1'
Keep me posted!
My acer laptop power switch does not turn on the unit whilst the power supply is okay. what could be the problem?
the inlet power could be okay but the power that goes in to the laptop could be faulty try another adaptor from your friend if it works then buy new one
if not please service your machine
Sep 13, 2011 | Acer Computers & Internet
Fault code 116-324 what can i do to fix this problem
116-324 System Controller RAP
An exceptional Controller error shut down the processor.
Initial Actions
Power Off/On
Procedure
Pull out and insert or replace the DIMM (PL 11.2).
If the problem persists, replace the ESS PWB (PL 11.2).
116-325 ESS Fan RAP
The ESS fan failed.
Procedure
Replace the ESS fan (PL 11.2).
Apr 30, 2011 | Xerox WorkCentre 7132 PCL 6
Dell inspiron 6000 dead when connect power adeptor to laptop the led light on psu goes off is this mother board fault or psu.
If the led on the power supply turns off after connecting it to your laptop, the problem most likely lies with the power supply especially if the machine will run on battery power. This can be tested by
1. Turn the laptop off.
2. Remove the battery and power supply plug.
3. Press and hold the power button for at least 15 seconds to reset the laptop.
4. Replace the power supply plug into the laptop without replacing the battery.
5. If the computer will not start and there are no lights turning on on the laptop the power supply is bad.
6. Replace the battery and attempt to start the machine both with and without the power supply plugged in.
Apr 04, 2011 | Dell Inspiron 6000 Notebook
Washing machine stops and flashes 4E
1. WATER SUPPLY ERROR – Display shows 4E.
Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the preset water level after 10 Minutes or more at the time of initial water supply. The error status can be cleared by turning the POWER switch OFF and back ON.
Feb 23, 2010 | Washing Machines
I push the Power button--but usually have to go thru many tries before machine turns on. It was suggested to remove the PWR plug from the ASUS motherboard and replace it with the RST plug. First time thru:...
hi , by your description i would say the relay in your power supply is deffective , its not a cost effective repair , so change the power supply
hope this helps
Jan 10, 2010 | Antec CASE |P180B BLACK RT
Emachine 180 (bought 2004)
I have this type of computer (just sitting around , not for my main computer) and I had a smilar problem. I took it to a guy I know (who owns a computer repiar shop) an he said the motherboards on this model go haywire about four years after initial power-up. On mine, it caused the power supply to blow-up (literally) and blew out most components. (Floppy drive, Sound card, USB ports, Keyboar/mouse plugs)
I really don't know if What he said is true, but I replaced the power supply, and now it works fine.
Jul 16, 2008 | E-Machines eMachines Refurbished EMA...
HP LaserJet 9500mfp All-In-One Printer Logo
Ben Johnson
