Question about Jet Equipment Chain Hoist 1TON 10 Ft Lift #111000
We have a jet 2SS-G1-10 2 TON SINGLE SPEED HOIST. WE HAVE A BAD CONTACTOR MODEL #754-10F-JS. WE NEED A NEW CONTACTOR. CAN WE GET THE EXACT SAME CONTACTOR AND IF SO WHERE AT?
  • venture22419 May 11, 2010
    I am a crane technician and i can tell you that jet is very difficult to order factory parts for. all you need is a reversing contactor with a mechanical and electrical interlock. you can get this from most electrical suppliers
Youtube repair
safety catch worn or spring weak.
Aug 13, 2014 | Jet 310015 JLH-100WO-15, 1 Ton Capacity...
Contactor replace
it is 42-25101-03 single pole contactor
Jul 25, 2014 | Rheem 13AJM60A01/RHLLHM6024JA 5 Ton 13.50...
Wondering how much power
Gas Mileage16 mpg City/24 mpg Hwy
EngineGas V8, 6.2L
EPA ClassCompact
Style NameCoupe 2SS
DrivetrainRear Wheel Drive
Passenger Capacity4
Passenger Doors2
Body Style2dr Car
TransmissionEngine, 6.2L V8 SFI (426 hp [317.6 kW] @ 5900 rpm, 420 lb-ft of torque [567.0 N-m] @ 4600 rpm) (Requires (MN6) 6-speed manual transmission.)
Apr 16, 2014 | 1998 Chevrolet Camaro
Contactor diagram ruud ac
The 030 model is a 2.5 ton system, so it is not going to utilize a very big contactor. If you're not that familiar with wiring, take a picture of the contactor, turn the power off to the outdoor AC, make notes on where all the wires are attatched & remove all the wires. (Note, you also need to turn off the indoor unit which supplies 24 volt control voltage to the outdoor unit...in other words, turn off you furnace power). Remove the contactor, take it to a local electrical supply house & they will match it. Replace it by reversing the above steps. If you are deadest on ordering online, look @ the white sticker on the side of the contactor in your AC for the ratings. Really the only thing you need to find is the VA rating. On a 2.5 ton system, it is probably only about a 20VA. Get a double pole contactor (brand doesn't matter), 24 volt coil, with the rating on the existing contactor (if you are not sure, a 30VA contactor will do) When it comes in, plug & play.
Dec 06, 2013 | Heating & Cooling
How much can my lever ratchet hoist lift?
Common ratchet lever hoists have the capasity to lift up to 5 tons, but some can only lift 1/2 ton its important to consult your user manual for exact numbers before use.
Nov 21, 2013 | Hoisting
Need wiring diagram for control circut
I am sorry but we have no wiring diagrams here at fixya due to copyright laws.
Jul 27, 2012 | Cars & Trucks
I have a 1.5 ton Tempstar condenser that keeps dropping the fan motor out after about 40 minutes.Have replaced all electric components except for the pump itself.Cap,contactor,motor,and the fan speed...
check the fan speed control,(should have a little dial on it or u have the wrong color wire pluged in)sounds like its on the wrong speed. motor is getting hot and shutting off due to thermo overload switch.
Aug 12, 2010 | Heating & Cooling
HELP, A/C wont come on in FL
Stopped up drain line caused float switch to trip. Blow out drain line. Blown fuse in Air Handler. Bad transformer. You have a 3 ton on a four ton air handler. You need to lower fan speed to low dor better effeciency. Could have bad Tstat butchances are control voltage problem.
Jun 06, 2009 | Goodman CLQ36AR49 Air Conditioner
I need assistance with swapping out a contactor.
I don’t believe changing the contactor to a double pole contactor will solve this problem. It appears by your description that bugs are being attracted to the contact points on the contactor. Changing to a double pole contactor will not eliminate that problem but only provide another contact point for the bugs to be attracted to. The most effective solution would be to replace the current contactor with a sealed design where the contact points are totally enclosed. Enclosed contactors are completely enclosed protecting it from bugs and dirt. These type of contactors are available in the single pole design so no further wiring modifications are needed. You can consult a professional A/C service company like mine for more information and assistance.
Hope this helps. Let me know if there's anything I can do for you!
Sam, The Service Expert
Visit Sam's Blog
1.888.HEATCOOL
ServiceExperts.com
Apr 30, 2009 | Ruud Central System Air Conditioner
Jet Equipment Chain Hoist 1TON 10 Ft Lift #111000 Logo
106 people viewed this question
Top Jet Saws Experts
woodzowl307
Are you a Jet Saw Expert? Answer questions, earn points and help others
