Question about Alesis Sr 16 Stereo Drum Machine
I need program settings for my sr 16
  • Alesis Master
  • 5,603 Answers
For most Alesis drum machines the best way to get programming is to find an identical unit and clone/transfer from it. Try a music store that sells Alesis.
A second possibility is to go to website(s) and download a SYSEX file to transfer via MIDI to the unit.
Posted on Sep 24, 2009
ALESIS SR-16 won't save patterns
Really Quick.
Two problems are unrelated.
Assume older unit.
Needs memory battery,
and new display.
Nov 08, 2014 | Alesis Sr 16 Stereo Drum Machine
How to program drum beats from one alesis sr16to another alesis sr16 drum machines
5.4J Copy a Song to Another SR-16 Via MIDI
The SR-16 can send Song system exclusive information to another SR-16 via MIDI. If you have only one SR-16, you can skip this section.
1. The source SR-16 should be in Song mode and stopped. Connect the source SR-16 MIDI out to the destination SR-16 MIDI in.
2. Select the Song to be copied.
3. Press and hold the COPY button, and keep holding it down until step (5). The display says COPY TO SONG.
4. Do not enter any destination Song number-just press PLAY to send the data out over MIDI. It will end up in whatever Song number had been selected at the receiver. If the Song was not empty, the new Song steps will be appended to the existing Song steps.
5. Release the COPY and PLAY buttons.
Caution: This does not transfer Pattern information, only the song steps. To transfer Patterns to another SR-16, see section 3.3D and 3.3E.
Hopefully this helps, it comes out of the SR16 Manual, page 40 I think
Cheers Pete
Sep 25, 2014 | Alesis Sr 16 Stereo Drum Machine
How do i ceeate and save a waltz pattern on my sr 16 drum machine ?
go to the ballad #4 setting you will find a 3/4 beat in a 12 beat time.
This is a preset pattern
May 12, 2014 | Alesis Sr 16 Stereo Drum Machine
I have a alesis sr 18 with a quick start guide that is not very clear on setting user programs to match to my music.The problem I've been haveing is when I try to create programs the issue is getting past...
Hello there Ken, i can help you with this unit but i need more information as you know this thing is huge it can do a lot . so do you want help on how to setup RECORDING PATTERNS or CREATING DRUM SETS and so its a very fun tool to have .
Let me know and lets get Started
Jan 26, 2011 | Alesis Sr 16 Stereo Drum Machine
Sr-16 drum machine need part
The pot is PROBABLY an audio taper so check the suffix on the old one.
Many pots you can find at Digikey.com or Mouser.com.
You MAY have to cut the shaft length
For an exact replacement you will probably have to go to Alesis.
4.7 K is NOT a standard value for pots. 5K ohms is.
Apr 04, 2010 | Alesis Sr 16 Stereo Drum Machine
I bought an Alesis SR-16 drum machine from an online seller advertised as "new". I plugged it in, and it appears that my "new" machine has had all the factory preset patterns erased! Is there a way to...
Hi.
The SR-16 has 50 preset patterns that are built in, I do not think they can be deleted, if there are no patterns the unit may be defective, even if patterns can be reinstalled using an rmidi file or re-flashing the unit.
To reset an Alesis drum machine you have to hold down both Play and Erase buttons while you power on the machine at the same time.
If that does not work, the presets are held into an rmidi file , the Rmidi file is not available for download. I think it can be purchased contacting Alesis or Rmidi.
I quote from Alesis Rmidi page:
"A rMidi Import/Export File named 'Sr16PresetKits.xml' containing the Sr16 Preset Kits has been installed within the folder named 'Sr16' within the directory in which you installed the rMidi FrameWork software. You can Import these Kits into the rMidi Drums Control if you wish. "
Check if you have the file in the folder.
If not the Sr16 will allows you to export your User Drum patterns, but I do not think you can export factory patterns.
Nov 20, 2009 | Alesis Sr 16 Stereo Drum Machine
I need to find the instuction manual for an Alesis SR-16 drum machine. I was told that it is available for free on line. Where?
Go to alesis.com/sr16 the reference manuel, program chart etc. are all there. I just went there to double checkit and it is there.
Aug 31, 2009 | Alesis Sr 16 Stereo Drum Machine
SR-16 gives message "ERROR: 01" when powering up
You likely have lost the internal memory data. This can be due to a power surge or that the internal battery has been depleted. The battery may need to be replaced.
You should reset the unit and reload the data, The manual is available online. Search Google for it.
The manual STRESSES the importance of backing up the data.
If you don'thave the backup, you MAY need to find another SR-16 owner to clone the data from.
Jul 01, 2009 | Alesis Sr 16 Stereo Drum Machine
Alesis Sr 16 stopped working altogether
I have never experienced this problem, but I know that you can reset the SR-16 to all default settings by doing something like holding down play when powering up. Try that & I'll look into the matter and get back to you with a definite answer. Peace and good luck until then.
Sep 21, 2008 | Alesis Sr 16 Stereo Drum Machine
Alesis Sr 16 Stereo Drum Machine Logo
244 people viewed this question
Top Alesis Music Experts
Michial Gueffroy
Bernie Scott
Level 1 Expert
Will Halftowaite
Are you an Alesis Music Expert? Answer questions, earn points and help others
