Question about Tomtom One Europe v2 GPS Receiver
Tomtom xl eurpoe switching off
My tomtom xl europe keeps switching itself off seconds after switching on can anyone help please. Thanks
Chris
  • bluey52 Dec 16, 2007
    Thanks I've tried that but it did'nt work,I've emailed them to see if they can sort it out. It does seem to be a common fault with these.
    Novelist:
  • 158 Answers
The switching off problem can be generaly be attributed to 3 causes:
  1. Battery is not being charged enough ( charging via USB from a PC will take days ) your charger could be putting out the correct voltage but not enough current.
  2. The battery is on its way out. TomTom batteries have a set lifetime where they gradualy take less and less charge. if your battery capacity is low then you might just have enough power in it to allow the TomTom to start up but then it shuts down again shortly after. ( You can check this becuase if powering the tomtom via a power supply the tomtom should remain switched on ). If this is the case , then it probably proves the battery is the problem.
  3. Faulty software ( very possible ) . I have found that where certain files are corrupted on the SD card the TomTom will shut down at some point in the loading up cycle. The reasoning being that if the TomTom cannot procede with boot up , it will either hang or shutdown or load up incorrectly.
If you made a backup of your SD card then formatting and reloading the files from your PC might cure the problem.
GOOD LUCK
Posted on Sep 16, 2008
How hard is it to replace that battery in a tom tom 300
Posted on Sep 14, 2008
    Scholar:
  • 143 Answers
Reset the unit by pushing a bent paperclip or pin into the hole on the bottom marked 'reset' turn it back on, plug it in & charge it via USB overnight or as long as you can in the car, make sure the led on the top is green, tap the bottom right of the screen & check the battery symbol on the unit says charging underneath.
If this doesn't help.
contact them about the problem...
http://www.tomtom.com/support/support.php?ID=2
Posted on Dec 16, 2007
  • Aaron Prentice
    Aaron Prentice Dec 16, 2007
    Yep, I have had 2 so far myself.
    a tomtom one v1. - Died totally. - took it back after 11 months.
    also had issues after updates with the tomtom not recognising the SD card.
    a tomtom one Euro. - Failed to turn on after update. - Reset - ALL OK.
    Have had to send back a 300 for a blown tranny.
    Have had to replace a battery on a 300 after 1 year.
    Unfortunately, the cheaper, the samller & didposable things get the shorter the life span.
How do I enter map coordinates into my tomtom XL Europe?
I'f your American, the europe tomtom wont work for you unless your planning on taking a trip to europe some time soon.
But for help on this product, here is the manufactures manual in PDF format
http://download.tomtom.com/open/.../TomTom-ONEv5-XLv2-en-GB.pdf
May 03, 2011 | Computers & Internet
TOMTOM XL 325 SE Language problem
Please view this FixYa Tip which gives a complete walkthrough on how to change the language back on your TomTom.
If this helps, please do leave a vote for the solution.
Thanks.
Dec 27, 2009 | Tomtom ONE XL 330 GPS Receiver
Www.tomtom.com/10
i just bought a tomtom one iq. how can i register and get the £10?
Jun 21, 2009 | Tomtom GO GPS Receiver
My Tomtom XL won't turn on. No reset button apparent
The reset button is on the bottom of your device. On my older model XL it is just above the sd card slot. If you have the newer model XL 330 then you have to hold down the on/off switch for 20 seconds to do a reboot. If you have not used it in a while let it charge for 30 monutes before doing a reset.
Hope this helps
May 12, 2009 | Tomtom GO 720 GPS Receiver
My tom tom keeps looping on the start up menu
I to had this same problem. I just about pulled my hair out. The way I fixed mine was to use Tom Tom Home to operate the Tom Tom. It was able to get past the loop and finish the initial set up. I then unhooked it from the computer and it was working by itself.
Mar 10, 2009 | Tomtom One Europe v2 GPS Receiver
Reset Button
hey mate, sorry I was making coffee.. I just checked some forums and apparently the XL has no reset button.. pfff.. but to reset on these or later models, just hold down the power button for 15 seconds.
try that..
i'll definitely still be here, if you need a second opinion.
good luck this time hopefully hoho
chris
Dec 17, 2008 | Tomtom One XL GPS Receiver
Cannot get map to work
First make sure you have a backup of your NEW ONE XL. You should be able to connect your XL to your PC using USB but not use TomTom home software. Your TomTom should appear in "my computer" as a drive . OR , put the SD card in a USB reader connected to a PC , that way you can look at and copy from or to the SD card.
You should be able to copy the map you have to the SD card directly ( if there is enough room on it ) , if theres not enough room , get a new bigger card , copy all the backup files you already have on your PC + the map you want. You might / should be then able to activate that map in the XL using the codes you say you have for the maps. if you try to do this using TomTom home it might have some restiction to stop you activating the required map but hopefully you should be able to do it manually as described above rather than use TomTom home. ... GOOD LUCK .
Please rate this reply if you find it useful .
Nov 12, 2008 | Tomtom GO 700 GPS Receiver
TomTom XL V2 EasyPort Mount
I wish I had that problem...mine won't stick at all!
Sep 16, 2008 | Tomtom One Europe v2 GPS Receiver
Tomtom One Europe v2 GPS Receiver Logo
632 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
