Question about HP Officejet Pro L7680 InkJet Printer
How do I adjust the margins - HP Officejet Pro L7680 InkJet Printer
    President:
  • 803 Answers
To adjust margins click "File," "Page Setup" and adjust your margins to meet your personal specifications.
Posted on Sep 24, 2009
Toshiba e233 photocopier does not coincide with the top margin of the original copy
Top margin??? SEF or LEF
1. If it is the lead edge registration, go to 05 mode and adjust the values of the following...
440 > start > adjust value (for upper drawer margin)
441 > start > adjust value (for lower drawer margin)
442 > start > adjust value (for bypass drawer margin)
443 > start > adjust value (for LCF)
2. If it is the side registration, adjust it from the drawers.
Nov 30, 2012 | Office Equipment & Supplies
I am trying to print a booklet 2 pages per sheet double sided. Printing is OK but spacing is no good for the binding when the pages are cut in two. What instructions should I give the printer to allow...
Hi
By spacing, I assume you mean the margins at the centre.
The default margin settings are not the same for the right and left hand side of the page, so the printing on the reverse side is offset from the printing on the first side.
The right margin is always wider to allow for punch holes in file paper.
It is not the printer settings you need to adjust, it is the page layout of your word processing software.
Adjust the margin settings manually. In MS Office 2007:
Page Layout > Margins > Mirrored Margins.
Hope this helps.
Aug 24, 2011 | Canon PIXMA MP610 InkJet Printer
How do I change margin setrtings foe Lexmark P4350
If you are preparing to print a document that you have created in Microsoft Word, you may be concerned that all the text on the page will print exactly as you see it on your screen. This is not always the case. You can adjust your print margins to ensure that your text prints on each page exactly the way you would like it to appear.
Opening Your Document
Open your Microsoft Word document by double-clicking the Word icon on your desktop. If you do not see the icon on your desktop, then you can locate it where it is buried on your "Start" menu. Click "Start," followed by "All Programs." Then click "Microsoft Office," followed by "Microsoft Office Word." A new document will open on your screen. Click the "Office Button," followed by "Open." Scroll through the files listed, and double-click the one you would like to print. It will open on your screen.
Check Your Margins
By default, your page margins are set to 1-inch margins on the top, bottom, right and left of your page. You can check your margins or change them by clicking "Page Layout," followed by the "Margins" button.
Select New Margins
Select a different margin size, such as "Narrow," which indicate 1/2-inch margins, or "Wide," which indicate one-inch margins on the top and bottom and two-inch margins on the left and right. You also can select "Moderate," which indicate one-inch margins on the top and bottom and 3/4-inch margins on the left and right. Finally, you can select "Mirrored," which indicates one-inch margins for the top, bottom and outside. The inside margins are set at 1 1/4 inches.
Print Your Page
Print your page. Press "Control" plus the "P" button. The printer dialog menu will come up. Make sure that "All Pages in Range" is selected. Press "OK." If your printer cannot print your new margins, then a new menu will pop up telling you to adjust your margins.
I hope you find it very helpful. Best regards.
Aug 22, 2011 | Lexmark P4350 All-In-One InkJet Printer
I have an SX-4000 Electronic Typewriter and use it from time to time BUT I do not know how to reset the margins....basically expand them beyond the norm. Please help - I did do the ALT and then the 4 or 5...
Try this procedure to set and adjust the margin:---- Use the "Space" and "Backspace" keys to set the margins by positioning the carrier where you want each margin. Press the "Alt" key along with the "L Mar" or "R Mar" key, depending on which margin you are setting, left or right.Press ALT with L Mar key to adjust margin on left side.Press ALT with R Mar key to adjust margin on right side. ----------------- For more help.Click this link below and check page number 11:---- http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_SX4000_EN_219.PDF ------------
This should help.Thanks.Helpmech.
Jan 05, 2011 | Brother SX-4000 Typewriter
Margin too wide
File menu, Page Setup, Margins Tab, use arrows to adjust margin value, or enter numbers directly. Inches and tenths.. Example, Normal standard margin is 1.25" You could enter 0.75 (3/4ths ")
Jan 02, 2011 | Microsoft OFFICE 2003 BASIC OEM ENGLISH MS...
I am trying to print on forms that are tractor fed and are 8 X 5 1/2, how do I adjust the printer so it will print on this size form. How do I adjust the printer to this size. I have already adjusted in...
select file at the top left hand corner of the page from the drop down list select page setup you should see a margins box you can make your adjustments in this box left.right.top.bottom also you might select print preview where you can look at the size and detail of the document you are about to print
hope this helps
Nov 24, 2010 | Office Equipment & Supplies
Adjust margins
If the margins are off, it is usually the paper in not sitting correctly in the paper tray, check the edge guides on the paper tray, make sure they are firmly against the paper.
Hope this is of some help.
Ed
Apr 28, 2009 | Office Equipment & Supplies
How do I adjust margins on Smith Corona WordSmith 100?
Return to the L. margin Press code and 1 release kets backspace to where you want L. margin press L mar key.
DickyO
Jan 06, 2009 | Smith Corona Wordsmith 100 Typewriter
HP Officejet Pro L7680 InkJet Printer Logo
261 people viewed this question
Seeker5211
Seeker5211
