Question about NorStar M7310 Corded Phone
I have linked two lines together and they are in use and I cannot hang them up
    President:
  • NorStar Master
  • 860 Answers
The easist way to reset that is to reset the system. unplug it for a moment that should clear it.
Posted on Sep 24, 2009
Why do you have to put the phone on hold to use a different hand piece
because you have only 1 line and they all work together . I carry 1st one to the second and pick up the second before hanging up the 1st
Oct 10, 2014 | AT&T 1070 Phone
If I want to put out bird seed as a treat for the birds, how do I hang it? I don't want to use a table, I want to hang it from the trees.
There are recipes for homemade bird seed treats that involve suet or some other sticking agent that keeps it together so you can hang it in a lump. But I came across a very cute web posting with a recipe for a bird seed treat that is heart shaped! Check out this link http://kids.nationalgeographic.com/kids/activities/crafts/wild-bird-treat/
Aug 21, 2012 | Birds
The gas lines popped off on my fj 1100 there is a group of lines (about 4-5) tied together and two other ones just hanging around that just popped right off and leaking gas. where do they belong?
If you mean they are hanging below the carbs, these are carb overflow and breathers.
This would then mean your carbs are flooding and need a clean, and may also mean the fuel tap requires a rebuild, its a vacumn opperated tap, this means the fuel should not flow until the engine is running
Aug 12, 2011 | 1984 Yamaha FJ 1100
Bostitch 1850BN will not cycle. Had a piece of a brad get hung up and the piston was stuck forward. I took it all apart to remove the hung up piece of brad and free the piston. I'm afraid I didn't pay...
Check the link below for directions to a website that has complete diagrams. I suspect that a seal may be damaged and the air is not flowing correctly. I would first examine all of the orings. Also, using the diagrams as a guide, check for proper movement by hand while the gun is partially dis-assembled. Update this if you have further questions.
Dan
Link: http://www.fixya.com/support/r5812776-bostitch_nailgun_dis_assembly_assembly
Sep 14, 2010 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
Can I transfer the incoming calls to a different number
The best way is to use the Flash button. You will have to have Call Transfer on each phone line you have with your phone company to do this.
So when you have a caller tell them you will transfer them, press the Flash button and you should hear a new dial tone. Dial the number you are transferring to then hang up or press the Flash button again to conference the three of you.
This is better than conferencing two calls together because as soon as you hang up your line is open again. If you conference two calls two lines will be tied up for one call.
May 14, 2010 | Vodavi 30-Button XTS Telephone
1987 pontiac fiero won't shift out of first gear automatic transmission. engine was just put back together from pieces. vacuume lines are hanging out don't know where to connect.
heres a vaccum diagram and alao make sure the passing gear cable is connect and adjusted if this car has one which i think it does, also check electrical connections are hooked up,heres two diagrams i labeled them, one is for the 2.5 engine and the other for 2.8 engine connect the vaccum line and retry it, hope this helps.d09847a.gifc3e18c5.gif
Apr 28, 2010 | 1987 Pontiac Fiero
I somehow how line 4 and 5 conferenced together...I cannot pick up either line and hang up?????
What has probably happened is you have conferenced the two lines together on a phone and they can't release by themselves.
The easiest and quickest way to fix it is to unplug the power to the phone system cabinet. It saves you from unplugging the lines as they appear on the phone system.
Carl
Oct 01, 2009 | NorStar T7208 Corded Phone
My ABS light just came on in my 2002 isuzu axiom,
Funny thing is my ABS light came on and when I climbed under my truck I found out my dog got up in my wheel well and chewed the ABS line, causing the ABS light to come on. I simply spliced the line back together. Probably not the answer you'r elooking for but if you have dogs in your garage, it's worth getting under their to see if there are any hanging wires.
Aug 11, 2009 | 2002 Isuzu Axiom
Conference call
To make a Conference Call
1. While on a call, press Cnf/Trn_____.
2. Dial a [DN] (or access an outside line and
dial an external telephone number).
3. Press Cnf/Trn after the called party answers.
All parties are conferenced together.
If you added an outside line to the call, press
Cnf/Trn again before hanging up to allow
the outside parties to continue talking. (If
you do not, the call is disconnected).
Note Some types of outside lines
(“unsupervised”) do not automatically
disconnect when conferenced parties
hang up. In this case, press one of the
flashing buttons to monitor the
conference.
If the parties are still on the line, press Cnf/Trn
+ Spkr, then hang up. When no one is
on the line, press Spkr to disconnect the
lines.
Mar 19, 2009 | Toshiba DKT-2020 Corded Phone
Hang
format mobile by pressing *,3 & green (dial) key together & start cell whie keeping that three keys together, cell will get formated
Feb 21, 2009 | Nokia N70 Cellular Phone
NorStar M7310 Corded Phone Logo
43 people viewed this question
Top NorStar Lands Phones Experts
Oloyede Monsuru
Jose Ma DM.
Jose Ma DM.
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
