Question about Intertherm Heating & Cooling
Inside blower won't come on in cool mode now just blower mode. it all works ok in heat mode
  • 3,361 Answers
Replace the thermostat based on your description.
Posted on Sep 24, 2009
Fan doesn't work in heat mode it works on all other functions. Heat does come out but fan doesn't kick in. Outside unit is operating
AC inside fan doesn't come on AUTO - DoItYourself.com Community Forums
www.doityourself.com > ... > Air Conditioning and Cooling Systems
Jul 21, 2004 - The inside FAN doesn't run when in AUTO mode. If I leave ... Is the thermostat not working correctly or something in the AC unit causing it to do this? Thanx ... The unit is electric central air-conditioning(heat and cool). It made ... Carrier A/C condenser fan not working
Jul 27, 2012
Heater Fan Doesn't Work on AUTO
Jan 23, 2006
Blower doesn't work in ON position after repair
Mar 25, 2005
Central AC/Heat, Blower Doesn't work on Auto
Nov 30, 2004
More results from www.doityourself.com
Nov 01, 2015 | Heating & Cooling
Dryer runs but won't heat
You will need a professional to diagnose the thermal limiter, small version of a fuse, heating element and the dryer/blower assembly.
Aug 17, 2012 | Frigidaire Electric Dryer
So the in door unit is comming on and blowing air but the out door unit is not... i ck power to the unit and all the leads inside no wires looked burnt....i thinking it is the top power supply,black box on...
Toget proper heat, keep your temp setting at 30+ degree and also mode in "heat"position. If still no heat, check your heating sensor for closed circuit by anOHMs metre.It it's with RV, check power to RV.If it's with heatingelement check power to element. If power is there but still no heat meanselement defective. Replace new heating element. Thanks. Toget proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Checkindoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3degrees less than room temp.6.Check compressor is working with correctpressure.
Jan 12, 2011 | Soleus KFGHP18 Air Conditioner
No heat inside van
THERE IS A DOOR UNDER THE DASH THAT MOVES FROM COOL OR AC AIR TO HEAT CHECK AND MAKE SURE ITS MOVING WHEN CHANGING SETTINGS
Jan 21, 2010 | 2000 Mazda MPV
I have a coleman Evcon model AH16-0 . I am
Typical Thermostat Wiring for 4 or 5 wire Heat/Cool Thermostat (not heat pumps)
4 Wire Termostat
R = Red One Side of 24 volt Transformer
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
with one transformer for both units
Rc One Side of 24 volt Transformer
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
With 2 transformers one for indoor unit
And one for outdoor unit
Rc = Red One Side of (outside) 24 volt (outside transformer)
G = Green Blower (outside transformer)
Y = Yellow Cool (outside transformer)
Rh = Blue One side of (inside) 24 volt (inside transformer)
W = White Heat (inside transformer)
COOLING ONLY Thermostat
G = Green Blower
Y = Yellow Cool
HEATING ONLY
R or Rh One Side of 24 volt Transformer
W = White Heat
Jan 06, 2010 | Heating & Cooling
Trying to figure out thermostat wiring diagham on a split system
4 Wire Termostat
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
G = Green Blower
Y = Yellow Cool
HEATING ONLY
W = White Heat
Jan 05, 2010 | Heating & Cooling
No Heat; Blower works fine and AC works fine
is your thermostat stuck open?  is your cooling system full and bled? are your cooling fans always on?
Mar 24, 2009 | 2001 Acura 3.2TL
Just a little question, guys!
The blower has absolutely nothing to do with outdoor air. Having the T-Stat set to auto lets the blower come on only when the A/C-heat comes on. With the switch in the ON position the blower simply runs all of the time. Depending on your living space (high ceilings, multi-level) having the blower on constantly while costing a small amount to run can actually save some money and make you more comfortable in the summer. However most people will leave it in auto in the winter so they don't feel as if they have a draft from the air movement as the blower is in high speed in fan on position and cool modes and low speed in heat mode. Many furnaces today are equipped with a setting that allows the blower to run constantly at a lower speed or simply run for a min. or two after the A/C=Heat have turned off.
Jan 17, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Heating & Cooling Logo
26 people viewed this question
Top Intertherm Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Dan Webster
Dan Webster
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
