Question about Cameras
WHEN IT TURNS ON YOU COULDNT SEE THE PIC AND NOW IT WONT EVEN TURN ON
My 2008 gran prix wont start with the key ,but will start with remote,the key turns but wont crank, the car will stay running after I put key in and turn key on.
suspect a fault with the ignition switch on the back of the steering lock barrel,but without a look i couldnt tell you correctly .Suggest you ask a local mechanic but if iam right then i would fit a push switch under steering column
Oct 31, 2016 | Cars & Trucks
Wont turn on blinking 5 times fast
can you please provide make and model of the tv
Offhand it sounds like a hardware fault.
Jul 14, 2015 | Televison & Video
Lawn tractor wont turn over
if your oil level is low there is a safety stop fill the oil and gently tap the area where the plug is
Aug 06, 2014 | Briggs & Stratton Garden
1992 nissan sentra starter replaced, inhibitor relay replaced still wont start. googled to replace the starter relay couldnt find location and was inform this year and model has none. Please help , has...
my 1992 nissan sentra will not start. It will trun and turn but will not start. when it does start.It missing alot and turn off very fast then it just turns but won't start
Dec 16, 2010 | 1992 Nissan Sentra 4 Door
Installing KD-HDR20 and I get a red power light but nothing works
I have had the same issue and I tried until I found the problem.
1) I had no power to my remote wire.
(The wire that only allows the radio to work when the care ignition is on.)
2) The radio has a fuse or maybe two.
But the auto mobile may have blown its fuse.
In my case it was the remote fuse.
3) I have had a bad ground and only need to find a good place.
4) I have even found insufficient power to my radio because too many devices were also using that power.
5) Heck I have even forgot to start the care or at least turn the ignition.
6) My battery was so dead it couldnt even power my radio.
Mar 16, 2010 | JVC KD-HDR20 Car CD/ MP3 Player
PSP cannot turn on
i think youll need to call to get service done............if your psp warranty isnt up they may give you a new psp
Aug 03, 2009 | Sony PlayStation Portable (PSP) Console
Zoom error, Fujifilm J150w
I just pulled apart the camera, everything inside was intact. No cogs broken. couldnt find anything to fix (not a camera expert by the way).
In desperation even put some WD40 on the lens barrel - still no luck.
Camera turns on - barrel is stuck out. Wont zoom, wont go back in and wont take a photo.
Daughter's camera and she says she didnt drop it but just saw it on her desk with the lens out...
Would be good if someone could shed some light on the problem.
Jul 05, 2009 | Fujitsu Cameras
Samsung NV3 wont turn on
take out an reinsert the battery...that works always for me.
Dec 18, 2008 | Samsung NV3 Digital Camera
Cameras Logo
12 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
