Question about Gestetner C7435n Laser Printer
Ricoh 7100cl How do I reset the fuser oil unit code on a ricoh 7100 or gestetner c7435n? The fuser oil unit has been changed out, but it won't let me print because it is still saying Replace fuser oil unit type G. Thank you Chas
    Sniper:
  • 58 Answers
I belive this is the cartridge type oil unit. If you look at the top of the oil cart you will see 3 metal contacts.....clean these and look for where they make contact in the machine clean those and gentley pull down on them so that they make a little better contact this should clear your message provided there is oil in the carttridge
Posted on Feb 26, 2010
Ricoh Aficio SP 4210N- Code SC 543
This is a common error code for Ricoh copiers, Savin and Gestetner copiers that need service. Recently Ricoh has purchased Lanier and now is naming all their new machines Lanier instead of Gestetner, Savin and Ricoh. However, the copier service error codes have remained he same.
When you get this copier printer service code it means the fuser or fixing assembly (same part) has thermistor problem. The copier fuser's thermistors help regulate the temperature of the fuser assembly. The fuser assembly on all copiers including Canon, Kyocera, Ricoh, Sharp and other brands is the part that melts the toner onto the page.
Getting back to the repairing the copier on Ricoh, Savin, Lanier and Gestetner models that have the fuser or fixing code error. The majority of the time the fusers' thermistors (Middle and read) need to be replaced. Just cleaning them will not solve the copier repair service code.
It is usually, depending upon the machine, its a 1 to 2 hour copier repair job because the copier repair service technician will need to dissemble the fuser, insert the two new thermistors, re-assemble, reset the error code and test the copier machine repair. Also, ask the copier technicians to to do a copier cleaning maintenance while on site.
Aug 18, 2011 | Ricoh SP 4210N Laser Printer
Gestetner 3225 error code SC544 - functional problem
SC544 indicates low fuser temperature during the warm up process. This means you have a problem with the fusing unit heating up. The fusing unit is located right where the paper exits the machine. Most common failure on these Ricoh's (Your Gestetner 3225 is made by Ricoh model aficio 250) is the fuser thermistor. This is a small electronic part that measures the temperature of the fusing roller. When they go bad they do not "see" the heat and therefor the code pops up. You are going to need to have a tech look at this for you as you will need to determine for sure which part is bad then you have to go into the service mode to reset this SC code before the machine will run.
Good Luck and Thank You for using Fixya.
Sep 07, 2010 | Gestetner Copier
I HAVE A RICOH MODEL MP2510 THAT SHOWS ERROR CODE SC541. I CALLED THE NUMBER FOR THE LOCAL SERVICE CENTER I'VE USED IN THE PAST BUT GOT A RECORDING THAT THAT NUMBER HAS BEEN DISCONNECTED. HOW WOULD YOU...
SC541 is a fuser heat failure. This means the fuser, which heats up and fuses the toner onto the paper, is not heating properly. Most of the time on Ricoh's this is caused by failure of the thermistor(s) which are responsible for reading the temperature of the fuser unit.
I would look in your local phonebook's yellow pages under copier service/supplies. Either find an independent servicer, such as someone listed as "services all makes and models" or look for a Ricoh, Gestetner or Savin dealer. The Gestetner and Savin makes are exactly the same as Ricoh so they may be able to help.
Aug 05, 2010 | Ricoh Office Equipment & Supplies
Ricoh fuser oil replace message
That is not a good idea. The oil is kept track of by counting pages, not by a sensor that measures the oil level. The oil runs out and the machine can't tell and now you have ruined the fuser. Which cost a lot more than the oil tank.
May 26, 2009 | Ricoh Aficio AP3800C Laser Printer
Ricoh Aficio 2238c: Fuser Oil Unit
It is what it is. No, you can't refill it
Apr 06, 2009 | Ricoh Office Equipment & Supplies
you really can not refill the bottle but I would recommend two things. One find a fuser oil unit on ebay and order it quickly. Next hit the yellow clear modes button, then hit the numbers 1 0 7 , then hold the red clear stop button till the display panel changes. hit copy sp, select 7 data log. now use the page down arrows located in the middle of the disply till you see 7804 push it then go to #10 oil supply and hit execute. this will reset the oil counter and allow you to use the machine till you get the new unit.
Oct 25, 2008 | Ricoh Aficio CL7000 Laser Printer
Ricoh 7100
fuser oil is a necessity in ricoh machine, it is entirely different consumable than toner (cyan) you dont need to repair the unit only to add oil or fuser oil, pls contact your supplier to buy one and install asap
no need to send to repairshop
Sep 17, 2008 | Ricoh Computers & Internet
Gestetner C7435n Laser Printer Logo
157 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
CheckitRight
CheckitRight
 Larry
Larry
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
