Question about HP Officejet 5610 All-In-One InkJet Printer
No connection with computer but printer is recognized
The printer still shows on the PC as being Ready and active however the printer claims there is no connection with the computer and refuses to pring.
  • 788 Answers
Try this, Disconnect the USB printer connection.
Remove the printer from the printer list. The list should be empty.
Re-boot your computer.
Check and make sure their are no other printers in list.
Find your install disks for the printer.
If you do not have a install disk, go to HP and download the printer installation files.
Install the software and do not plugin the printer until it is asked for.
After you install the new drivers and software the printer should be seen by the computer.
Posted on Sep 24, 2009
How do I config HP L7590 Officejet Pro printer to a wired network?
skil, your usb connection is to the cpu. Go to printers and devices from start and see if this printer is your default printer. If it shows ready, it's working. Test print.
Dec 01, 2014 | HP Office Equipment & Supplies
Hp printer 7510 will not print or scan
mac or pc
try connecting hardwire to router to see if it sees the ip address or you might need to update drivers
Mar 22, 2012 | Office Equipment & Supplies
Why won't my printer print after I installed the software? It says its ready but nothing will print
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print/scan again.
Aug 18, 2011 | Lexmark PhotoJet Z705 InkJet Printer
MY LEXMARK 1270 CANT PRINT NOR SCAN BUT ITS STATUS IS READY
2. Unplug and re-plug the printer into the power source to reset it.
4. Reboot your pc.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list again, then try to print again.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/aKlcOJ. Select your operating system, download and execute the file.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 15, 2011 | Lexmark X1270 All-In-One InkJet Printer
I can't figure out how to connect my computer with my printer through wireless. The printer says its connected to the same network as my computer but I can't figure out how to find it on available...
For installing a wireless printer on Windows XP, wireless router is an essential device.
Follow the recommended steps mentioned on the installation CD of the router, and set-up a wireless network.
Since several computers or laptops will access the printer, it0 1is recommended to connect the wireless printer to the main computer through the USB port.
To begin the installation process on Windows XP, access the network setting in the Control Panel, and activate the file and printer sharing option in the LAN setting.
This will allow the operating system to recognize the availability of a wireless printer.
Now, click the Start button, go to Devices and Printers, select Add a Printer option.
Click the second option- Add a network, wireless or Bluetooth printer.
The computer will search for available printer and reflect it on the screen.
Click Finish; and the printer is ready to begin the printing process.
Apr 10, 2011 | Brother MFC 7840W Printer
My Epson 4180 scanner will not turn on. I tested the power supply and it is O.K. Frank
Ascertain that the computer recognizes scanner connection. For example, once ascertained the device connections to circuits been attained, trace the connections to the computer also from where programs should recognize the new feature required. Usually scanners turn on from computer programs. Once click activated would power on scanner ready to capture picture graph displays.
Feb 27, 2011 | Epson Perfection 4180 Photo Flatbed...
How to install printer
First thing to do is install your drivers and/or software for your printer on your computer. Do not connect the printer to the computer until you are finished loading these files.
If its a brand new printer, it should have came with a disk to install the software. Find the disk and put it in your CDROM on your computer. The computer usually recognizes the CD automatically and the installation program will appear on your screen and give instructions to follow. If your computer does not auto recognize the CD and start the install then you need to manually locate the program to start it yourself. To locate the installation file on the CD double click "my computer" from your desktop and find the drive that represents it. Your CDROM should be either "D" or any letters in sequence beyond that point. The name of the install program should show up under the drive letter that represents the CDROM. When you locate it, double click on it and find the application for installation. Double click on the install file and then just follow the prompts to complete it. After the installation of the software is complete, connect your printer to your computer and turn it on. Your computer will automatically recognize the printer and tell you that your device is connected and ready to use.
Happy Printing!
Oct 29, 2010 | Canon Office Equipment & Supplies
Lost ip/connection on Dell 1720dn
try resetting the "print spooler"
  1. start
  2. control panel
  3. admin. tools
  4. computer management
  5. services and applications
  6. services
  7. scroll down till you see "print spooler"
  8. left click once
  9. "restart"
Jan 06, 2010 | Dell 1720dn Laser Printer
USB DEvice not recognized
Turn off the CPU unplug the power cable and all usb cables, let it sit for about 15-20 minutes. Plug power cable back in, turn on CPU, plug in your usb devices.
Mar 06, 2009 | Canon PowerShot SD790 IS Digital Camera
O2 xda 2 mini pocket pc usb connection problem
how i get my o2 xda ii mini drivers?
Aug 12, 2008 | O2 Xda II mini
HP Officejet 5610 All-In-One InkJet Printer Logo
173 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
