Question about McCulloch FHH18A Electric Pressure Washer
Pump burned out?
I have a McCULLOCH FHH18A pressure washer. Unfortunately I left it plugged in overnight and now it doesn't maintain adequate pressure. I'm thinking that perhaps the pump is burned out. Can this be repaired or is it toast? I can't seem to find a list of repair service dealers for McCulloch either. I bought it from Menard's in Champaign, IL, but they don't carry this brand any more and won't/can't help me. What to do?
  • donlmeier Sep 29, 2009
    I called the number you suggested and found out that the part I required would cost $210, which is more than I could buy a whole new machine for. Thanks for the suggestion, but I think that the repair option is economically inadvisable.
  • Joy Marshall Sep 27, 2013
    I don't have brand name or serial number because this washer belongs to my granddaughter, will have to get back with you.
4 Suggested Answers
  • 19 Answers
SOURCE: Where can I purchase oil rings that go into the
I assume you mean the rubber O rings inside the wand. I had to replace mine as well. I had to visit several plumbing supply stores to find one that fit. I ended up taking the end of the wand with me so I could make sure the O ring fit. The ring you are after is a number 5, but you need to make sure it is thick enough to make a good seal.
Posted on Sep 14, 2009
kel1guy2002
  • 3740 Answers
SOURCE: I need a manual for a McCulloch pressure washer
Your manual can be downloaded from here:
http://weborder.husqvarna.com/order_static/doc/MOUS/MOUS2006/MOUS2006_7096H18A01.pdf
If the above link does not work start here: http://www.mccullochpower.com
Which should get you to this page where you type in FHH18A as the model number
http://www.mccullochpower.com/node7877.aspx (Use for ANY McClloch
Course of last resort.... Call them at this number: 1-800-521-8559
Thanks for choosing FixYa,
Kelly
Posted on Oct 18, 2010
Asbestos 56
  • 191 Answers
SOURCE: I have a McCulloch FHH18A
I would guess there is a leak somewhere inside the unit that is spraying water on some electrical component and causing a ground fault.
Posted on May 16, 2011
Trigger don't release
I have a hose and gun that fits the McCulloch FHH18A that I no longer need as I had to buy a complete universal hose/gun and wand unit since I had broke the wand and the replacement wand was no longer available. If you are interested in it, email me at burmakow@nwciowa.edu and we can figure out a price.
Apr 28, 2012 | McCulloch FHH18A Electric Pressure Washer
McCullock Powerwasher FHH18A - All hooked up, but pump won't turn on. Is there another switch/button somewhere?
look for 2 things. 1. the GFCI button on the plug, you may have to press the 'reset' button to turn it on. 2. there may be a reset button on the motor or the unit somewhere this will usually be round, and often red, but maybe black also. hope this helps
Jun 24, 2011 | McCulloch FHH18A Electric Pressure Washer
McCullough pressure washer
I nedd a manual for a FHH18A pressure washer
Apr 07, 2010 | McCulloch FHH18A Electric Pressure Washer
Red light on power cord stays on powerwasher wont turn on
The red light means you are getting power. It sounds like the bypass (unloader ) valve is stuck. This is inside the actual pump
Sep 12, 2009 | McCulloch FHH18A Electric Pressure Washer
Where can I purchase oil rings that go into the spray wand of a McCulloch FHH18A electric power washer.
Sep 10, 2009 | McCulloch FHH18A Electric Pressure Washer
I need a manual for a McCulloch pressure washer FHH18A. Download did not work.
I need a manual for McCulloh 1600 PSI pressure washer > Its motor is working but there is no pressure
Aug 23, 2009 | McCulloch Garden
Fhh18a water flows INTO the tanks during operation.
There should be a ball and spring in the valve where you attach the soap suction hose.
Jul 05, 2009 | McCulloch FHH18A Electric Pressure Washer
What are the steps to use Mc Culloch FHH18A powerwasher? What is the liquids I should use?
Hello awseibel:
  1. attach your garden hose to the inlet (at the back I believe)
  2. Attach high pressure hose with gun wand/nozzle
  3. turn on the water
  4. plug into electrical outlet
  5. turn on/off switch on
  6. spray away
  7. Any non-caustic soap can be used
  8. You must set the machine on low pressure to apply soap.
McCulloch M#FHH18A High Pressure Jet Washer,
On hooking up to a water source and plugging it in to an electrical outlet any attempt to test the unit is unsuccessful to include having the on/off switch in either position. With the switch in the on position pump does not operator. The last time I used the unit was July of last year and prior to storing it I did drained the hose.
May 29, 2009 | McCulloch FHH18A Electric Pressure Washer
McCulloch FHH18A Electric Pressure Washer Logo
173 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
