Question about HP Color LaserJet 4600dtn Printer
How do I replace a fuser kit in such
Where I can get the "FUSER KIT" for HP 4600dtn, how much does it cost and how do I replace such kit in the printer?
    President:
  • 2,306 Answers
Check www.precisionroller.com and look under your model of printer. It's expensive but well worth it. The instructions are packed with the kit.
Posted on Sep 24, 2009
Hp lj 4100 50.2 error
is this error on a lj4100 or on a cm1017?
if on a 4100- then the complaint is that the fuser has not reached the required temperature in the allocated time- replace fuser kit with CORRECT fuser ( lm4100MKIT) and not a 4000 fuser which is not the same even though they look like each other.
if its a cm1017 then the error is poor communication with the thermal resistor measuring the fuser temp. again replace fuser kit to resolve
Dec 17, 2013 | HP LaserJet CM1017 MFP All-In-One Color...
Printer keep says replace fuser kit
These is a part on the fuser called a fusable link that blows the first power up cycle and resets the replace fuser message. It sounds like the fuser you installed is a remanufactured unit that was not professionally rebuilt. Contact the place of purchase and get a replacement. The message can only be reset with the fusable link on the fuser.
Feb 13, 2012 | HP LaserJet 4700 Printer
I just replaced the Fuser Kit on the Office''s HP 5500 laser color printer but the error is still there and as in the instructions I never received the question: "Is this a new fuser...
To reset fuser status, on the printer:
1. Press the "Menu" button
2. Navigate to "Configure Device"
3. Select "Reset Supplies"
3. Select "New Fuser Kit"
After doing so, the printer will reset the count on the fuser.
May 09, 2011 | HP LaserJet 5550 Printer
HP laserjet 3600 error message 50.9 Fuser Error
Thank you for the inquiry.
Yes you will probably have to replace the fuser. If this is a new printer still under warranty and the page count has not reached the service life of the fuser, contact HP for warranty replacement. Once the new fuser in installed you will need to restore the service count.
nav?h_pagetype=z-001&h_lang=en&h_cc=us&h_client=z-a-r1002-1&h_product=501046
Fuser Kit Part Number: (Sometimes Called a Maintenance Kit)
RM1-2665 This fuser is compatible with the following printers: HP Color LaserJet 2700, 3000, 3000N, 3000DN, 3000DTN, 3600, 3600N, 3600DN,
Link to Installation pictures and instructions:
http://printertechs.com/tech/mkinst/3000/mk-3000-2fuser.php
Restoring the maintenance count after installing new fuser.
This printer tracks the number of pages printed on the fuser, and a reminder message will appear when the fuser reaches a certain page count. The message will instruct you to replace your fuser. Whenever you install a new fuser, you should reset the fuser page count so the warning message will not appear prematurely.
To reset the fuser count :
1. Press MENU to enter the MENUS.
2. Press Down arrow to highlight Configure Device.
3. Press Checkmark to select Configure Device.
4. Press Down arrow to highlight RESETS.
5. Press Checkmark to select RESETS.
6. Press Down arrow to highlight RESET SUPPLIES.
7. Press Checkmark to select RESET SUPPLIES.
8. Press Down arrow to highlight NEW FUSER KIT.
9. Press Down arrow to select NEW FUSER KIT.
10. Press Down arrow to highlight YES.
11. Press Checkmark to select YES.
The fuser count will be reset and then the printer is ready to use.
Thank you for being a FixYa Valued Customer.
Hope this helps helps. Please keep us updated and remember to rate this answer.
TF
Jan 19, 2011 | HP LaserJet 3600 Printer
Replaced fuser kit with a new one, still saying to replace fuser kit. did this once before, 1 year ago and now doing again, had HP come out here to replace CD Controller last year, cost $650.00 do I have...
If the fuser did not correct it, then it sounds like the c'trlr again,. You are correct, it is cost prohibitive.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Thanks, Joe
Jan 12, 2011 | HP LaserJet CP4005n Printer
How to replace image fuser kit for hp laserjet 4700n
turn off the machine. open upper front cover. remove the old fuser and insert the new one. turn on the machine and enjoy your printer with new fuser kit.
Jan 20, 2010 | HP LaserJet 4700 Printer
From the printer indicator,the printer is requesting for transfer fuser kit. the percentage is low,down to 0%. What is transfer fuser kit?
GENUINE HP COLOR LASERJET 2600 MAINTENANCE KIT - Kit Includes: 120V(220v) Fuser Unit, Tray 2 Paper Pickup Roller (D-Shaped Roller), Tray 2 Separation Pad Assembly - Includes The Spring Loaded Separation Pad In Holder Assembly - Genuine HP Part
Oct 21, 2009 | HP Color LaserJet 2600n Printer
50 .2 Fuser Error in HP Laserjet 4100N
you need an maintenance kit 4100
ACC C8057A 4100-mk-c4110a-mini.jpg Maintenance Kit, Fuser, 110V, LJ 4100 LJ 4100 Series ACC C8057-67901 4100-mk-c4110a-mini.jpg Maintenance Kit, Fuser, 110V, LJ 4100 LJ 4100 Series ACC C8058A 4100-mk-c4110a-mini.jpg Maintenance Kit, Fuser, 220V, LJ 4100 LJ 4100 Series
Selected Item RG5-5069-000 See RG5-5069-090 Not Available 0
Alternate Item(s) RG5-5069-090 Fuser Film ***'y, 220V, LJ 4100 180.50 2 http://www2.printerworks.com/cgi-win/tpwall.exe/find?RG5-5069-000
HP LJ 4100 Fuserkit RG5-5069 HP
Dec 11, 2008 | HP LaserJet 4100n Printer
I have just fitted a new image fuser kit to our HP 4650 laser printer. However, the error message "replace fuser kit" reappeared on switching the printer back on. Any ideas. Have taken it out...
To reset the fuser count, do the following:
1 Press to enter the MENUS.
2 Press to highlight CONFIGURE DEVICE.
3 Press to select CONFIGURE DEVICE.
4 Press to highlight RESETS.
5 Press to select RESETS.
6 Press to highlight RESET SUPPLIES.
7 Press to select RESET SUPPLIES.
8 Press to highlight NEW FUSER KIT.
9 Press to select NEW FUSER KIT.
10 Press to highlight YES.
11 Press to reset the fuser count.
Thanks and please take a moment to rate as fixya.
Nov 06, 2008 | HP Computers & Internet
Hp 4650 n - New Fuser Kit
Under the menu>Configure Device>Resets>Reset Supplies>New Fuser Kit
Oct 28, 2008 | HP LaserJet 4650n Printer
HP Color LaserJet 4600dtn Printer Logo
88 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
