Question about Cell Phones
I9+++ answering calls automatically
Hello why is my i9+++ answering all incoming calls automatically, when i first got it this was not happening. how do i fix this
Receiving faxes whilst connected to a phone line automaticly
Check video for 'fax receive set up' in similar model:
Manual receive: In coming call receives like telephone
Fax/tele: Incoming call rings like telephone if its not fax, if incoming is fax it will entered in fax mode automatically
Automatic: Incoming call converts in fax mode after ring count ends( ring to answer option also avail in fax set up mode rage 1-6 rings)
Fax: Incoming calls straight away converts in to fax mode.( this option only for dedicated fax lines)
Set up your best option as per your requirement.
Nov 29, 2012 | HP LaserJet 3050 All-In-One Printer
What is the barring code for Nokia n70?
The @ represents pressing the "Send" key on your mobile
##002#@ all call diverts off
*#06# IMEI Number showing
**004*DestNo#@ set all conditioned call diverts to DestNo on and active
##004#@ all conditioned call diverts (busy, not reachable, no answer) off
**21*DestNo#@ Automatic divert all calls to DestNo on and active
*21#@ Automatic divert all call DestNo activate
##21#@ Automatic divert all calls to DestNo off and inactive
#21#@ Automatic divert all calls to DestNo deactivate
*#21#@ Automatic divert all calls to DestNo status
**61*DestNo#@ Call divert when not answered on and active
*61#@ Call divert activate
##61#@ Call divert when not answered off and inactive
#61#@ Call divert deactivate
*#61#@ Call divert when not answered status
**62*DestNo#@ Call divert if not reachable on and active
*62#@ Call divert activate
##62#@ Call divert if not reachable off and inactive
#62#@ Call divert deactivate
*#62#@ Call divert if not reachable status
**67*DestNo#@ Call divert when busy on and activate
*67#@ Call divert activate
##67#@ Call divert when busy off and inactive
#67# Call divert deactivate
*#67#@ Call divert when busy status
**03*330*oldPW*newPW*newPW#@ Changing the password for call barring
**33*PW#@ Barring all outgoing calls on (PW one row before)
#33*PW#@ Barring all outgoing calls off
*#33#@ Barring all outgoing calls status
**330*PW#@ Barring all calls on
#330*PW#@ Barring all calls off
*#330*PW#@ Barring all calls status
**331*PW#@ Barring all outgoing international calls on
#331*PW#@ Barring all outgoing international calls off
*#331#@ Barring all outgoing international calls status
**332*PW#@ Barring all outgoing international calls except homecountry on
#332*PW#@ Barring all outgoing international calls except homecountry off
*#332#@ Barring all outgoing international calls except homecountry status
**333*PW#@ Barring all outgoing calls on (PW one row before)
#333*PW#@ Barring all outgoing calls off
*#333#@ Barring all outgoing calls status
**35*PW#@ Barring all incoming calls on
#35*PW#@ Barring all incoming calls off
*#35#@ Barring all incoming calls status
**351*PW#@ Barring all incoming calls if abroad on
#351*PW#@ Barring all incoming calls if abroad off
*#351#@ Barring all incoming calls if abroad status
**353*PW#@ Barring all incoming calls on
#353*PW#@ Barring all incoming calls off
*#353#@ Barring all incoming calls status
*43*#@ Call waiting on
#43##@ Call waiting off
*#43#@ Call waiting status
**61*DestNo**Seconds before divert#@ Divert call if not answered for 'seconds' (Note: Seconds must be 5, 10, 15, 20, 25, 30)
#30#DestNo@ No presentation of the number of the incoming call (CLIP)
*30#DestNo@ Presentation of the number of the incoming call (CLIP)
*#30#@ CLIP status
#31#DestNo@ Your number will not be send for the actual call (CLIR)
*31#DestNo@ Your number will be send for the actual call (CLIR)
*#31#@ CLIR status
*76#@ Presentation of the number under which I reached the other one (not his number if he has turned on a call diversion!) (COLP) on
#76#@ Presentation of the number under which I reached the other one (not his number if he has turned on a call diversion!) (COLP) off
*#76#@ Presentation of the number under which I reached the other one (not his number if he has turned on a call diversion!) (COLP) status
*77#@ Presentation of the number under which the caller has reached me (not my number if I have turned on a call diversion!) (COLR) on
#77#@ Presentation of the number under which the caller has reached me (not my number if I have turned on a call diversion!) (COLR) off
*#77#@ Presentation of the number under which the caller has reached me (not my number if I have turned on a call diversion!) (COLR) status
Jun 10, 2011 | Nokia N70 Cellular Phone
How do I set up the fax feature?
Introduction The HP All-in-One can receive faxes automatically or manually depending on the Auto Answer setting. If the Auto Answer option is set to On (the default setting), the HP All-in-One will automatically answer incoming calls and receive faxes after the number of rings specified by the Rings to Answer setting. (The default Rings to Answer setting is five rings). Refer to the given instructions to receive faxes automatically or manually. Receiving faxes The HP All-in-One can receive faxes automatically or manually. Receiving a fax automatically To receive faxes automatically, set the Auto Answer option to On (the default setting). The HP All-in-One will automatically answer incoming calls and receive faxes after the number of rings specified by the Rings to Answer setting. (The default Rings to Answer setting is five rings). Receiving a fax manually If the HP All-in-One has been set up to receive faxes manually (the Auto Answer option is set to Off ), or you answer the phone and hear fax tones, use these instructions to receive faxes.
  1. Make sure the HP All-in-One is turned on and you have paper loaded in the input tray.
  2. Remove any originals from the document feeder tray.
  3. Set the Rings to Answer setting to a high number to allow you to answer the incoming call before the HP All-in-One answers. Or, turn off the Auto Answer setting so that the HP All-in-One does not automatically answer incoming calls.
  4. If you are currently on the phone with the sender, instruct the sender to press Start on their fax machine.
  5. When you hear fax tones from a sending fax machine, do the following:
    1. Press Start Fax Black or Start Fax Color on the control panel of the HP All-in- One.
    2. When prompted, press the down arrow to highlight Receive Fax Manually , and then press OK .
  6. Press Start Fax Black again.
  7. After the HP All-in-One begins to receive the fax, you can hang up the phone or remain on the line. The phone line is silent during fax transmission.
    Trust this is helpful. Please vote. :)
Dec 11, 2010 | HP Photosmart C7280 Laser Printer
What is answer mode?
The answer mode determines whether the HP Fax answers incoming calls or not.
Different answer modes are :
* Fax
The HP Fax will automatically answer all incoming calls using the Rings to Answer setting. This is the default setting.
* FaxTel (unit with handset model only)
The HP Fax automatically answers all incoming calls using the Rings to Answer setting. If the call is a fax call, the HP Fax will receive the fax. If the call is a voice call, the HP Fax will create a special ring to indicate it is a voice call. The incoming voice call will need to be answered using the attached handset.
NOTE: If the HP Fax determines the call is a voice call, only the HP Fax will ring with the special ring tone. The other phones on the same phone line will not ring at all. You will not be able to pick up the voice call using the other phones.
* Tel
The HP Fax will not automatically answer calls. Faxes will need to be received manually.
* AnswerMachine
The HP Fax will monitor the line when an incoming call is answered by a person or by the answering machine. If the HP Fax detects fax tones on the line, it will receive the fax.
Jun 07, 2010 | HP Officejet 4315v All-In-One InkJet...
How do i answer an incoming call when the phone is
if you are saying that it is panel locked, just press the call key and it will be unlocked automatically once you received incoming call..
Feb 03, 2010 | Samsung Jet S8000 Cell Phone
How can I change a handset to automatically answer an incoming call when you pick it up
In most handsets in the phone settings menu u have an option called automatic answer.Once the option is enabled u would b able to answer calls automatically
Aug 06, 2009 | Lands Phones
Incoming calls to message bank
You have to give priority to recieve call option.
or change time of automatic answer
Jul 08, 2009 | Uniden Cordless Phone
Please let me know how to change the ring tone cect I9
Phone on, 'slide' to 2nd screen (put your finger anywhere on the screen and push to LEFT , same way you unlock push to right ...), Profiles, General (or any other one you want to change), Customize, Tone setup, Sim1 incoming call (or Sim2 incoming call)
Jun 10, 2009 | Dual Electronics CECT P168 Cellular Phone
How can I set my Cect i9 to vibrate for incoming calls or sms?
go into the profiles tab or icon on 3 page meni it is on second page. go to meeting tab click on it then activate, then ok it will set it to vibrate.
Apr 08, 2009 | Dual Electronics CECT P168 Cellular Phone
Cect I9
how can I download music and videos on my i9 phone
Oct 30, 2008 | Cell Phones
Cell Phones Logo
89 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
