Question about Nintendo Professor Layton & the Curious Village Games for DS
On No. 94 ive tried and tried to move the blocks to allow the red ball out Ive used the 3 given tricks---then HELP!!!
    Novelist:
  • 180 Answers
You can see a step by step illustrated solution here
http://professorlaytonwalkthrough.blogspot.com/2008/02/puzzle094.html
Posted on Sep 26, 2009
My ignition switch won't turn, my steering wheel is locked. How do I remove ignition switch w/o removing steering wheel? I have a '94 Suzuki Sidekick 4WD 1.6L (1590cc) MFI 16V engine
get front tries off crubs, or rocks or other things blocking them.
then turn key gently, (wiggle it)
and then turns steering (L/R wiggle it)
bam it unlocks, the operators guide covers this topic.
the lock is bad, needs wheel off.
ive done 2 this year,
the lock also has 2 anti tamper screws (clamp there) by LAW.
they must be removed with vise grip,et cetra.
then replaced with new 6mm bolts.
1: plastic shells off. (under neath shells)
2: see IGN switch, see it now> see how it surrounds the shafts>?
if you and seen that first, youd not be asking here, now.
ok>?
3: wheel off..
4: remove the 2 clamp bolts from switch assembly.
5: this lets column drop and free up switch assembly
6: now it can be removed
i had to.
The steering casing shaft at the floor firewall down low,, only loosen the 4 bolts 4-5 turns.(trick 1) there.
allows column to move more easy.
the FSM covers this, 96 car is nearly the same
and book is rare free, but is here.
turn to 3F4 page 7, and read,
http://www.acksfaq.com/2016bp.php?urlname=http://www.acksfaq.com/HTML/trackerfsm.htm
Mar 07, 2017 | 1994 Suzuki Sidekick
My phone is locked ive put a number in but ive
PIN CODE:
HI If you are asking for pin contact your service provider , he will give you a default pin .
If you try pin more than few predefined no of times your phone will ask PUK code which can also be given only by your service provider which is specific for each and every mobile number . Do not try PUK(new pin code) code many times or else your sim will be blocked and you will need a new sim.
Contact your sim customer care department over phone. Its free of cost to get the pin or puk no.
Go to the nearest service outlet of your service provider they can also help you.
There is no other go than the above procedure only your service provider can give it nobody else in this world nor any software.
Jun 28, 2010 | Samsung Tocco Ultra Cell Phone
I need a diagram for fuel injection pump for toyota estima 94 model(japan made} 3C-TE, 2.2 ltr, 4cylinder, model;Y/CXR1DG/RRSET
ive undone all nuts, including cam wheel nut but its stuck. the pump turns slightly side to side , but it still seems to be fixed to the cambelt pully. ive tried using a drift on the pump shaft but it doesnt move back
May 09, 2010 | 1997 Toyota Previa
My 94 gmc sierra 6.5 td keeps blowing the clutch master cylrnder
It needs a clutch pressure plate force is to great do lining & reface flywheel then good to go for a longggggg time
Sep 01, 2009 | GMC Sierra 2500 Cars & Trucks
Same thing
try flshing the software it means u need to format n install new software in it it wil work....
Jul 15, 2009 | Dell Dimension 4600 PC Desktop
Ford Focus T Reg (UK) Key Fob Not Working.
it might be the 60 amp black fuse my partner just said
Apr 13, 2009 | 2000 Ford Focus
Stuck on puzzle 94 (Get the ball out) 4 Can anyone help. Game Nintendo DS Professor Layton and the Curious Village
094 Get the Ball Out! 4
1. If you're persistent in your efforts, you'll eventually get the ball to
the hole, but there are tricks to streamline the process.
The large block in the puzzle is relatively limited in range of
movement, so you're going to have to do more work with the smaller and
more maneuverable blocks. If you focus on them and plan out a route,
things should go smoothly.
2. If you move the green block on the right down, you can fill the space
you create with a purple block from the right. If you can pull that off,
you'll be able to move the blue block in the upper left, which will
allow you to move the red ball out of its slot.
It may seem complicated, but give it a try.
3. There is no set solution to this problem.
Here's one way to start out. Move the lower-left purple blocks, then
slide the lower blue block to the left.
Next, drop the green block on the right down.
The rest is up to you.
However, I have found the following sequence if you can follow it to get it done in 21 moves:
Purple block = P
Yellow block = Y
Green block = G
Red ball = R
(l)eft (r)ight (u)p (d)own
P[d],P[l],B[l],G[dd],P[dd],P[rd],B[rr],R[dr],G[uu,Y[l],P[rd],
B[d],R[rru],B[ul],R[ddl],P[uuu],R[rd],P[u],R[l],G[uuu],R[rdd] = 21 moves
Thanks and please take a moment to rate as fixya.
Feb 23, 2009 | Nintendo Professor Layton & the Curious...
Iphone blocked?
hey listen ziphone is inapproriate 2 unlok instea use iliberty software 2 unclok dats d best and safest 2 use
enjoy
Jun 01, 2008 | Apple iPhone Smartphone
My mouse isnt working it has a hard time moving to the left it is difficult to placethe pointer where i want it like to open up mail the mouse is connected to the only port available on the tower ps/2 when...
are you using the mouse on a mouse mat because you get this prob if the place you are using the mouse is greasy or dust are you using an infra red mouse or does it have a ball in the bottom if it has a ball in the bottom a rubber one undo the clip holding the ball in tip it up so the ball comes out you should now see three rollers the one at top is up n down and one at side is left and right the third is just to hold the ball against the other two all these rollers should be smooth usually they get a build up of dirt in the middle of each roler scratch this of with your finger do this with comp on and try rubbing the rollers up and down and see if the mouse is moving on the scrren how it should clean all three of these rollers check theball is clean and not greasy if you can move the pointer using you fingers on the rollers then you know the problem is not your mouse so put back together then the only other thing could be wrong is the mouse mat you will need to replace this or clean it properly try using the mouse on a book and see if this is any better if you have infra red mouse you dont need mouse mat and should have no problem if you still have problems post back and i will try again hope this is some help to you ............................................
Nov 15, 2007 | HP Pavilion MX70 17" CRT Monitor
Nintendo Professor Layton & the Curious Village Games for DS Logo
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
