Question about Encon Industries (78018) Ceiling Fan
My ceiling fan isnt working right
My ceiling fan has three sppeed settings but it runs quite slow. Is it a problem with the switch gear and capacitor or is it coils on the motor?
  • nestwood2 Sep 24, 2009
    Yes I am aware of the function of the switch. What i am saying is that it does run to full speed.
    President:
  • 1,922 Answers
Dont you have a three position pull switch on the unit like a three-way light bulb or if you have a remote controlled fan it should have it on the remote control
Posted on Sep 24, 2009
My 3-speed ceiling fan is connected to an on/off wall switch that turns it on and off but the pull chain does not control the speeds. It is stuck on slow speed. I tried replacing the pull chain switch in...
Guess what? A standard dimmer switch will not properly operate a fan motor. In fact, it’s most likely going to damage the fan motor and it could even potentially cause a fire. I’ll admit I even went out and bought a dimmer switch and I sat down to just “make sure” I was doing the right thing when I figured this out.
Standard dimmer switches are designed for the wattage of lights. Fan controls are designed for the amperage of the fan motor. So if you want to control the speed of a ceiling fan make sure you buy a fan speed control that specifically says it works for fans. Fan controls come in quite a few styles. The most common type has been around for quite some time and that is the rotary or dial type. The next most common fan control I found was the toggle that has three pre-set speeds (slow, medium and fast). You can also get a fan control that has a slider control along with a toggle switch.
dimmer+switch.jpgThe type that I want to install is a toggle switch with a small slider switch next to it. I have a feeling I’ll have to order one of these but I’ll check with my electrician tomorrow to find out the scoop. The bottom line is you can’t use a standard dimmer switch to control a ceiling fan. You have to get a fan speed control switch that is specifically designed to operate fan motors.
the short wire leads coming from the switch should be attached to other wires with small wire nuts. Just unscrew the wire nuts, unscrew the finial type cap that holds the switch in place, remove the switch and take it to the store. If your lights are strictly "ON"-"OFF" there should be just two wires from the switch. If your lights are controlled - "One" "TWO" or "THREE" at a time the switch will probably have three wires coming from it.
http://www.ceiling-fans-n-more.com/
Thanks for contacting Fixya.
Jun 14, 2009 | Heritage (5BUW52WZ4HN) 52'' Ceiling Fan
Hello, I replaced a light fixture on my existing Emerson ceiling fan. The light worked right away but the blades didn't turn. I could hear power going to the motor so I went back into the switch cup and...
Signs of a bad capacitor in a ceiling fan include:
  • Fan runs slowly or not at all on all speeds
  • Fan will not start but will spin if started by hand
  • Certain speeds are slow or do not work
  • The motor hums and turns freely by hand but will not spin
    The capacitor is usually a black box inside the switch housing of the fan. If this box appears burnt or melted in any way, that is also the sign of a bad capacitor and it should be replaced.
    have a good day !!
  • Feb 17, 2011 | Emerson Fans CF705AW 52" Northwind Ceiling
    We have a Hampton Bay ceiling fan (about 10 yrs old) don't know the model. It will only turn 1 speed? When trying to change speeds with the chain pull it stays the same. It quit working for a while and I...
    the fan changes speed by inserting a capacitor of different values in series with the motor .. direct drive to the motor is the fastest speed .. a large capacitor in series slows it down a bit and a smaller capacitor slows it down more ... so if your fan is running at full speed all the time then one of the capacitors is shorted or the switch is bad .. if its stuck on one of the lower speed settings then the switch has a bad contact .. the capacitors are mounted together in a small box with several wires going to the pull chain switch .. you can replace the capacitor box .. and you can replace the 3 or 4 position switch ... or you can remove all that stuff and put in a remote controled system .. that involves a box that just fits inside the fan .. it is hooked to AC power and neutral .. it then hooks up to the lilght and the fan giving you control over both .. you can vary brightness and fan speed .. you would no longer need the fan or light pull switch or the capacitors ... you could also get a new fan having such a controller .. since yours is fairly old it might be worthwhile to upgrade .. some of the remote controls allow you to set a temperature ..if the room goes above that temp then the fan turns on automatically and the speed is determined by how much higher the room temprature is from that set value .. some remotes also give you an additional very low fan speed .. thats nice at night when you just need a gentle breeze .. some also allow you to set a delay before the lights go out after you have clicked "turn off" ... that gives you time to exit the room or get in bed before the lights actually go out ... kindof nice features that might make it worth while to up grade .. to get parts for your old fan see this URL
    http://www.ceiling-fans-n-more.com/hampton-bay-ceiling-fan-parts.php
    since Home Depot sells hampton bay .. then they might have parts as well .. worth a try .. you can also see new models there ..
    Jun 06, 2010 | Hampton Bay 52 In. White Redington...
    Altura 68" fans will not operate on high speed.
    I jtoo, ust bought The Altura (68" fan from home depot)
    Home depot makes hampton bay through various chinese manufacturers.................
    The fan ran slow on high speed, and barely ran on medium or low.
    home depot gave me a number for their tech department that knew right away.....that the capacitor(s) are defective in many of the Altura fans.
    They are sending the capacitors in 3 days to me no charge.
    They are located under the fan ( remember the white square plastic plug you had to connect and the 2 wires for the optional light kit?.....)That plug is for the capacitors that everyone is having a problem with.
    My guess is they are under rated for a fan that big and are sending better ones to those with problems.
    Hope this helps.
    The number is:
    1-800-330-3267
    Aug 18, 2009 | Hampton Bay 24002 Ceiling Fan
    New Hampton Bay ceiling fans spin too slow
    Slow spinning of the fan might be caused by a low voltage. Is there any way you can measure the voltage, and if the wires are properly connected, check for any loose wiring or rust in between connections. Maybe the breaker that supplies power to the fans has a loose connections inside, try putting a new breaker of same rated current. Check if those three fans are connected to the same breaker. Breaker can go bad from the inside not doing a proper connection and supplying a low voltage, this might be causing the slow spinning of the fan. Second the black box in the space with all the wires is called the capacitor.
    May 30, 2009 | Hampton Bay 24750 Huntington III Ceiling...
    Hampton Bay ceiling fan - will not reverse
    It sounds like the direction switch has a broken connection on the "reverse" side.  Should be an easy fix (but you might need a soldering iron).
    Dec 07, 2008 | Kitchen Appliances - Others
    Harbor breeze ceiling fan
    Your voltage is probably too low, probably a bad wire or source. Let me know if it worked.
    Or take a look at the link given here... http://www.ceiling-fan-wizard.com/harbor-breeze-ceiling-fans.html
    Aug 03, 2008 | Dryers
    Hampton Bay Ceiling Fan At Slow Speed
    I recently replaced my hampton bay fan for the same reason (slow at all speeds) and discovered scorched and melted capacitors and wiring inside the fan. My suggestion is to stop using fan and replace immediately.
    Aug 10, 2007 | Hampton Bay 52 In. White Redington...
    Encon Industries (78018) Ceiling Fan Logo
    309 people viewed this question
    Top Encon Industries Dryers Experts
    Dan Webster
    Dan Webster
    Are you an Encon Industries Dryer Expert? Answer questions, earn points and help others
