Question about Apple PowerBook G4 Mac Notebook
My powerbook G4 won't boot up.
Normally when I press the on button the orange light changes to green, but tonight it is doing nothing. Is there another battery which controls the date etc? which might need replacing? I haven't used the laptop for a while and the last time I did so I got a message saying that the date was wrong.
    Scholar:
  • 94 Answers
Yes, there is an internal battery that keeps the time, it is called the cmos battery and belive it or not, if the time is not set, it won't boot, you can get a cmos battery for your laptop pretty cheap on ebay, and east to install, just pop the old one out and put the new one in, must open the laptop to do this, or take it to someone to do it for you.
Posted on Sep 24, 2009
Reset button on a powerbook g4
The Powerbook G4 power button functions like a reset button if you hold the power button in for a few seconds until the computer powers down.
  1. Hold the power button in for a few seconds (until you see the screen turn off/go black and hear the fans & hard drive stop spinning).
  2. Press the power button again to turn your computer on.
  3. If you have more trouble, you may need to boot in Safe Mode or "perform a Safe Boot":
    Press and hold down the "Shift" key immediately after you hear the start-up tone. Release the "Shift" key when the gray Apple icon appears on the screen.
May 02, 2014 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
My powerbook G4 froze with flyspin going.. I shut it down but when I restarted it it went to a blue screen with no activity. Clearly it is not starting up OS X. Any ideas what to do?
Boot it into single-user mode holding down Command(Apple) and S buttons when powering up. Then in terminal console, use chkdsk -fy. Use it and use it again until comes back with something like "Volume appears to be OK". Then use command: mount -uw / and then type reboot and try booting normally.
-juuko
Nov 18, 2010 | Apple PowerBook G4 Mac Notebook
Turn on my powerbook G4 but there isn't a chime and nothing comes on the lcd screen
If there's no chime, your problem could be anything from a dead battery or bad AC adapter to a dead logic board.
Does the tip of the adapter on your AC connector light up? If not, that's a problem.
When you push the button on the battery, do you get at least two glowing LCDs? If not, that's a problem.
Otherwise, try the following: remove the battery and the AC jack to make sure the machine is off. Now insert the AC jack, and reset the power management unit by pressing the following multi-key combination:
Shift Control Option Power-button
Wait five seconds, then press the power button to attempt to start the computer normally.
The instructions above are for the 1.5GHz PowerBook G4; the instructions MAY be different if that is not your model.
Nov 01, 2010 | Apple PowerBook G4 Mac Notebook
My powerbook g4 won't reboot. It freezes at the grey screen with the apple and won't let me log on .
Power the machine down. Press the power button, then immediately press and continue to hold the shift key. This will perform a "safe boot," skipping any of the boot-time software you may have added to your machine. If it still fails to boot, more involved diagnostics are required.
Jun 22, 2010 | Apple PowerBook G4 Mac Notebook
My mac G4 powerbook doesnt start up. There are
It sounds like the system is corrupted. What I would do is to get your instal disk and boot up holding down the c key on your keyboard. Once you have booted up go to the file menu and run disk utility to verify and repair the hard drive if necessary. Then go to the instal menu and instal a fresh system remembering to preserve the users data so you do not wipe anything. Hopefully this will work.
Nov 11, 2009 | Apple PowerBook G4 Mac Notebook
Powerbook Aluminum G4 15 booting up problem
The backup battery connects directly to the logic board. From the symptoms you are describing (rather clearly, thank you), it seems apparent that your logic board may be faulty.
There are two more things you can try.
1) Reset Open Firmware: Unplug-replug your backup battery, then boot the system holding down Control-Option-O-F. Your machine will boot into Open Firmware. Type the following commands, pressing the "return" key at the end of each one:
reset-nvram
set-defaults
reset all
Your machine should restart at this point. If it starts successfully, you should be done. Otherwise,
2) Reset the Power Manager. Turn the machine all the way off (no power). Simultaneously press Shift-Control-Option-power button, then release. (Do not press the fn (Function) key during this sequence.) Wait five seconds, then press the power button. If it starts successfully, you should be done. Otherwise, you will need to see a man about a logic board, which is probably not a cost-effective repair on a 1GHz G4.
Nov 01, 2009 | Apple Powerbook G4 1.33GHz 512mb 60GB...
Powerbook G4/17. Had been running on battery, now dead
Hello, You can test your adapter using a voltmeter and see if the power comes in Best regards. The best is actually to test with another adapter
Jun 10, 2009 | Apple PowerBook G4 Mac Notebook
Powerbook won't start up
If you have the original install CD or the OSX CD, boot to CD. To do that you must insert CD, restart PowerBook and hold letter "C" on keyboard while computer is starting, then take the first steps towards installing the OS, when you get to the bar on the top go to Tool>Utilities>Disk Utilities then select the drive a do a disk repair. That may fix the problem and bring your system back to booting normally.
Mar 15, 2009 | Apple PowerBook G4 Mac Notebook
Powerbook g4 will not turn on
pull the battery out, put it back in, plug the mac in, and hold down the power key till u hear the chimb
Feb 16, 2009 | Apple PowerBook G4 Mac Notebook
Apple PowerBook G4 Mac Notebook Logo
285 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
