Question about Rheem Tankless Hot Water Heater Rtg-74pvp-2 7.4 Gpm
What does c4 error code flashing mean? - Rheem Tankless Hot Water Heater Rtg-74pvp-2 7.4 Gpm
    Champion:
  • 248 Answers
Refere to manual
Posted on Oct 30, 2009
C4 13
Could be bad thermocouple, or oxygen sensor, not enough fresh air to unit.
Probably bad PC board. Rheem will send new board and you can install yourself.
Bad PC board is kind of like the motherboard on your computer, so expect same level of performance after replacing motherboard ... which usually means the computer's days are numbered before another major problem.
Copy following links:
http://waterheatertimer.org/pdf/Fault-codes-11003.pdf
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
http://waterheatertimer.org/pdf/Error-code-13.pdf
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Sep 20, 2012 | Water Heaters
No hot water error codes 76, C4,C7
Before calling service tech, open following links for Rheem troubleshoot resources including rheem chat, error codes, possible maintenance and service manual.
Error codes are considered start-point for troubleshooting.
Multiple error codes can mean PC board failure.
http://waterheatertimer.org/pdf/Rheem-error-code-C7-76.pdf
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
Aug 12, 2011 | Rheem RTG-66DVN Direct Vent Natural Gas
I have a paloma tankless water heater, ptg-42pvn. It was flashing, C4, 13 and now it only flashes -0, 13 and will not even turn on. Tried to reset it by unplugging it and it only flashes -0, 13 even...
Multiple error codes can mean different things, including bad PC board.
C2 13 might be the oxygen sensor. -0 and no operation indicates bad board, but other things might be notched into same problem like loose connections.
Error codes are starting point for troubleshooting.
Before calling service technician, open following link for Rheem-Paloma troubleshoot resources including Rheem chat.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 28, 2011 | Rheem Paloma PTG-42PVN / RTG2-42PVN...
Paloma tankless ptg42 water heater error code c4/13
4 error message, the 4th (last) error code is #13, not enough oxygen.
Check the location of the heater, if it is fine the ODS sensor (actually is a thermal couple) is bad.
Dec 25, 2009 | Rheem Paloma Tankless Water Heaters...
Rheem tankless water heater error code C4 13??
check diaphrapm valve or micro/switch best of luck
Sep 13, 2009 | Rheem RTG-53PVN Indoor Natural Gas...
Heater shuts down with C4-13 code
your not getting enough fresh air to it. where is it located? you need 1 square inch per 1000 btu's. it's having irregular combusion.
Aug 01, 2009 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
C4 76
76 is a bad connection between the controller and the unit. try unplugging the controller and running it, also check the wiring between the two units. if that is not it. it means that one of the control boards it shot
Jul 18, 2009 | Water Heaters
Rheem Pronto RTG-74 error code C4
Error code 13 is "oxygen depletion sensor" activated.
The first number is a sequence indicator.
If you need the training manual I have it and can send it to you.
I got Rheem to send it to me a while back and it is a big help when working with these units.
It covers th RTG-42, 53, 66 and 74.
Apr 29, 2009 | Rheem Tankless Hot Water Heater...
Rheem Tankless Hot Water Heater Rtg-74pvp-2 7.4 Gpm Logo
210 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
