Question about D-Link AirPlus G DWL-G710 Wireless Range Extender
Can not access through the IP address 192.168.0.30.
  • 20 Answers
You have to plug it in to your computer with a network wire to configure it first. once you restart it with your configuration, then unplug it and it will start repeating your Wi Fi signal. Don't worry if you cant access it wirelessly. I've had one for a couple of years and it's funny that way sometimes. But it will still repeat the signal.
Posted on Nov 05, 2009
Can't find IP address 192.168.1.2
Your IP address 192.168.1.2 is a Local IP address. Local(Computer) IP address ranges from 10.0.0.0 to 10.255.255.255, 172.16.0.0 to 172.31.255.255, 192.168.0.0 to 192.168.255.255. Normally you can login the Local IP address within a single building (or) campus using LAN. If you need to access around the world, it should be a Public(Network) IP address. To check your Network IP address, visit IP-details.com .
Apr 16, 2013 | Zyxel Wap3205 Wireless N Access Point -...
192.168.0.1
Try this.
http://192.168.0.1
Mar 14, 2013 | Computers & Internet
How do I determine actual threats to my network while reviewing my wireless/network Router's Event Log?
Logs are meant to see the activities handled by your router. However, to determine any threat you can check for the IP address of the devices you have connected to your router. You can determine if any one else is trying to access your router by their ip address only.
Note down the IP address for all the devices that you have connected to your router. Than match the your devices IP addresses with IP addresses you found in the logs.
Matching IP address: Means your devices accessing the router. Unmatched IP Address: Someone else's devices trying to access your router.
You can always add security by using WEP/WPA2 key security. For further security you can encrypt the keys.
Jul 06, 2011 | NetGear WNDR3700 Wireless Router
JN763. Access rejected from your IP address.
To resolve this problem, follow these steps.
  1. Using the Internet Service Manager (Microsoft Management Console), open the Internet Information Server (IIS) snap-in and select the Web site reporting the 403.6 error. Right-click the Web site, virtual directory, or file where the error is occurring. Click Properties to display the property sheet for that item.
  2. Select the appropriate Directory Security or File Security property page. Under IP Address and Domain Name Restrictions, click Edit.
  3. In the IP Address and Domain Name Restrictions dialog box, if the Denied Access option is selected, then add the IP address, network ID, or domain of the computer that requires access to the exceptions list.
    In the IP Address and Domain Name Restrictions dialog box, if the Granted Access option is selected, then remove the IP address, network ID, or domain of the computer that requires access to the exceptions list.
Jan 31, 2011 | Microsoft Computers & Internet
How can i find the ip address of my Wireless Access Point device? (model DWL-G700AP)
Hi, here's how you can find your access point's IP address:
The access point is also your default gateway, because it's the device that you use to access the Internet, right? Open up a command prompt window (go to the Start menu, click on Run, type "cmd" and then hit Enter) and type "ipconfig" and hit Enter.
A bunch of information will appear. The one you want to look for is the one called "Default Gateway." The IP address that appears following "Default Gateway" is your access point's IP address.
Please rate this solution based on how helpful it was. (If you still can't find the IP address, add a comment and I'll be happy to reply.)
Sep 18, 2010 | D-Link DWL-G700AP 802.11g/b Wireless...
I don't know how to reinstall the linksys access point!!! Our wireless network that we made simply disappeared, so I'm trying to re-make one. However, when I tried that with a flash drive, it couldn't work...
T
o access the Access Points Setup, and the LAN IP address has not changed, then computer must have an IP address of 192.168.1.XXX. If the Access Point is plugged in via Ethernet to a Linksys Router and the computer is also connected a Linksys router via Ethernet, then the PC should already have a correct IP address (unless the LAN IP Address of the Router has been changed). If unsure, please assign the computer a Static IP Address so it will have an IP address in the same range as the Access Points IP Address.
If the Access Point is being connected to a hub/switch/router via Ethernet, then use the cable that was provided with Access Point. If the Access Point is being connected to the computer directly, then a Cross Over cable must be used. Cross over cables can be purchased at most electronic stores.
    Remember: When ever a change is made in the Setup of the Access Point, the Apply button must be used to save the settings to the Access Point.
  1. Open a web browser (such as Internet Explorer or Netscape)
  2. When the browser opens, go to the "Address" bar and input the IP address of the Access Point.
      Default IP addresses:
    • WAP11 v2.8 - 192.168.1.251
    • WAP54G v1.1 - 192.168.1.245
  3. A "User Name" and "Password" prompt will appear, leave the "User Name" field blank and input the Access Points password (The default password of a Linksys Access Point is admin) into the "Password" field.
May 14, 2010 | Linksys Wireless-G WAP54G 802.11g/b...
Jul 27, 2009 | Computers & Internet
Cannot acess ip address
HI! you can access the ip address of your router by connecting it directly to your computer.. if you are using a windows xp operating system. use your mouse and click on start and select run, from there it will show a box and type in on the box cmd and it will show you a dos prompt and from there just type ipconfig /all and it will show your ip address..
Jul 19, 2009 | Computers & Internet
You can get the ip-address by visiting this http://www.ip-details.com/ .It's used to search and find ip address's,domain name host's whois information including city, country, global latitude & longitude coordinates.
Jun 08, 2009 | Arris WA840G 802.11g/b (49832000100)...
Pix 515 E allow few websites only.
Do the nslookup for the three websites and write an access list to permit the traffic only to the said website ip addresses
Eg.
1. go to dos prompt
2. type "nslookup"
3. type "www.rediff.com
Note : You will get the ip address of the websites
4. Create an object group for these websites
5. Add ip addresses of the websites
6. create an access-control list element to permit the traffic from your circle office to this object group for port tcp 80 and 443
You are done
Mar 09, 2009 | Cisco PIX 515E Firewall
D-Link AirPlus G DWL-G710 Wireless Range Extender Logo
565 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
