Question about Samsung Propel A767 Cell Phone
Cannot get bluetooth to work and cant change off to on in options although bluetooth is on discovery is off and cant change it to on
Cant listen to music on my 975
The Plantronics Discovery 975 Bluetooth headset does not supports Advanced Audio Distribution (A2DP) and you need this Bluetooth profile to be able to stream music between two Bluetooth devices. The device you are streaming music from (example: cell phone) to the headset must also support Advanced Audio Distribution (A2DP).
Good luck from Headsets Direct!
Dec 07, 2011 | Plantronics Discovery 975 (8164001 P)...
I phone cant find bluetooth devices
On your phone, make sure bluetooth is turned on (settings, general).
While your phone is in discovery mode, turn your bluetooth device on and put it in discovery mode (usually you have to hold the power button for 7-10 seconds).
Your phone will find the device, and you will be prompted to enter the devises PIN number (often 0-0-0-0). Your phone should pair with the device then.
Nov 28, 2010 | Apple iPhone 3G
Bluetooth wont detect my phone
can it see other phones ? if yes the problem is in the settings of your phone... in phones bluetooth menu there is an option "detectable yes/no" or something like that (depends on the phone).
if it cant see any phones at all then you should try a software called "blue-soleil" as its the best bluetooth software i ever used and works 100% with no problems in all the pc and with all the mobiles i have tested it.
Sep 03, 2009 | Samsung NC10-14GW Notebook
My bluetooth wont activate when it does the icon is flashing and know one can find me and i cant find them
You have to go into the bluetooth options and change the setting to allow ([phone) discovery (which is off by default on most phones). HOPE THIS HELPS
Jun 15, 2009 | Samsung J700 Cellular Phone
Bluetooth not showing
Follow these steps to setup Bluetooth:
1. Double-click the My Bluetooth Places icon
2. In the initial Bluetooth Configuration Wizard choose where you want Bluetooth icons to be
3. Enter a name for the computer, select computer type and click Next 4) In the next Bluetooth Service Selection screen, select services that will be offered by this computer by Bluetooth 5) Click next Next button and then click the Skip button to close the Bluetooth configuraton wizard
Next you will set Bluetooth Discovery options 1) Right-click Bluetooth Icon and choose Advanced Config from Menu 2)Click accessibility tab 3)Select let other Bluetooth Discover this computer option 4)Click the Discovery Tab 5) Select Look for Other Bluetooth Devices option and choose how often you want to perform this check 6)Click Apply and then click OK to close the dialog box. Now when someone else with Bluetooth comes into range it will automatically connect
Dec 25, 2008 | Lenovo R61 T7300 Notebook
Sony erricson k800 cant recieve files via bluetooth although i can send via bluetooth.
Did you turn the bluetooth on and put the phone in discovery mode before attempting to receive something via bluetooth?
May 01, 2008 | Cell Phones
Bluetooth syncing
Usually to solve some pairing problems shut off bluetooth completely(no lights) Push and hold button until bluetooth comes on,flashes then steady light,you may have to hold button for ten seconds or more.Then put phone in pairing mode.
When asked for pass code enter 0000.Phone should show connected to bluetooth device.
Apr 24, 2008 | Jabra BT350 Bluetooth Headset Headset
P990i is not supporting headset bluetooth HBH-PV700
You must operate your bluetooth headset HBH-PV700 in discovery mode in order for your mobile to discover the headset and then pair the two devices. To activate the discovery mode of your headset, while it is switched OFF press the switch on button and leave it pressed for approximately 10 seconds, then search for it with your mobile and pair the devices. most of the times the code needed for pairing is 0000 (zeros)
Oct 03, 2007 | Sony Ericsson P990i Smartphone
Bluetooth connectivity
Bluetooth doesn't shut off on its own unless you turn off your phone. In the bluetooth options, you should be able to select "Turning Bluetooth On", "Turning Bluetooth Off", or "Using Discovery Mode (60 seconds)." Discovery Mode, which I believe is what your using, is only used when connecting to another device. My question for you is, what kind of device are you trying to connect to?
Sep 05, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Samsung Propel A767 Cell Phone Logo
29 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
