Question about Whirlpool Washing Machines
The machine is probably 6-8 years old and not used very much. Today it has started popping the GFI outlet on two different locations. I appears to be happening only on the first wash cycle; all other cycles are working fine.
  • restabrook Sep 24, 2009
    I can put the washer on a dedicated non-GFCI, 20 amp circuit, but I'll be out of code (Massachusetts). Why would this be happening all of a sudden? The washer's been in use for years.
  • 15,935 Answers
Have the motor cleaned - or clean it with some aerosol cleaner.
The added load of the dirt/dust/corrosion on the brushes is making the current draw high.
Eventually - repeated GFI trips can cause the GFI to wear out as well.
Thanks for using FixYa!!
Posted on Sep 25, 2009
    President:
  • Whirlpool Master
  • 1,922 Answers
Number one you DON'T want a G.F.C.I. ON a washing machine to start with, because of the water around the machine will induce a capacitive effect on the HOT lead of the 120 volt circuit and dump the G.F.C.I., another thing you only want ONE G.F.C.I.on any circuit so put one in the house panel to protect the people/property if you want, the N.E.C. does not require a G.F.C.I. on a washer anyway.
Posted on Sep 24, 2009
No power to Whirlpool awo/d5727. I have checked the fuse and the socket but still have no power.
You say you checked "socket" and the "fuse," did you mean the AC wall outlet (115V) and a fuse or breaker in the main power panel?
Nearly all circuits involving water are protected by a Ground Fault Interrupter that can be servicing several wall outlets (perhaps one not near the washing machine) or can be located as part of a circuit breaker in your main power panel.
The GFI outlets will have one or two push buttons located between the outlets and a combination GFI/overcurrent breaker will also have at least one button where others will have none.
If you find one that is tripped, try resetting it. If it will not reset, unplug the washing machine and try again.
If it now stays on, your machine may have an electrical path causing it to trip and using an unprotected outlet may be unsafe and an indication that the appliance itself may have electrical leakage which could be otherwise dangerous.
The circuit breakers in the main power panel can also fail (they didn't 20 years ago) and we have replaced 3 in a home only 5 years old already so they are not made well anymore.
Jun 22, 2013 | Whirlpool Washing Machines
Seacoast magic plus keeps tripping gfi breaker
try in different GFI outlet, if it trips the new one, the coffee maker is dangerous and you should return/replace it, it has a short.
if it doesn't, replace the GFI outlet, it is old.
Apr 16, 2012 | Philips Coffee Makers & Espresso Machines
Home fuse box breaker issue
Hi Rex,
It sounds as if the upstairs bathroom outlet and the outdoor outlet are on the same circuit. There's a very good chance that these are GFI or "ground fault interrupter" type outlets, as these locations (and others) have required this type of protection for over 30 years. It was a common practice to run a circuit from the panel to one of these locations (or another) and then run from here to the next outlet and then on to the next. Since the GFI outlet could be purchased for around $10 instead of $30 for a GFI breaker, electricians would install outlets instead - both offered the same protection. A "regular" breaker would supply power to this circuit - but the very first outlet would get a GFI type outlet. It would be wired to the LINE terminals and the cable that feeds the rest of the outlets on this circuit would be connected to the LOAD terminals. If there was a ground fault condition, this GFI outlet would trip, but the circuit breaker would remain on. You would locate and RESET the tripped GFI outlet to restore power. The only time the circuit breaker would trip is if the circuit was overloaded. Overloads would NOT cause the GFI outlet to trip.
Now that you understand how it was typically wired years ago (and still a lot of times today), you should check all the outlets outside your home, in bathrooms, basements, garages, and inside your home next to doorways that lead directly to grade of your lawn or deck. These are required places for GFI protection. Press the RESET on any tripped GFI outlet to restore power. If the outlet will not RESET, there is a condition where the hot wire (black, red or blue insulated wire) is in contact with ground, or a device or appliance connected to the circuit has a problem. Unplug anything connected to the circuit and attempt to RESET again. If still unable to reset, open the outdoor outlet again and carefully pull it out and away from the box. Inspected for damaged or crushed insulation and repair / tape as needed. Before reinstalling, try to reset again. If it holds, trip the GFI by pressing TEST button. The RESET button should pop out. Reinstall the outlet and make sure the wires are not crushed or cut. Press the RESET button again. If it trips, you will have to remove the outlet again and take more precautions against damage to the insulation. it is also possible that the GFI outlet itself has failed, in which case it should be replaced.
GFI circuit breakers and outlets are supposed to be tested monthly by simply pressing the TEST button and then the RESET button. Replace any GFI device that does not test correctly if wiring and devices / appliances connected are OK.
I hope this helps & good luck! Please rate my reply - thanks.
Jan 05, 2012 | Hammering
Solis Master 5000 trips GFI outlet during brewing.
It sounds like the power filter(capacitor) located under the pump is damaged.
Oct 23, 2009 | Coffee Makers & Espresso Machines
GFi breaker blows
There is an electrical problem with the brewer. If you will please get the model and date code located on the bottom of the machine, and call customer service, we will be happy to assist you with this. The machine has a 3 year warranty and if the machine is 3 years old or less, it will be replaced at no cost. If it is over 3 years old, it will be replaced at a reduced price.
Apr 23, 2009 | Bunn BTX-B ThermoFresh 10-Cup Home Thermal...
Frigidaire side-by-side refrigerator keeps tripping GFI outlet.
We had same problem with different fridge. Is the fridge cooling things? When ours did that we needed to replace the relay overload start capacitor it's called a three in one. It acts like a giant battery to give your compressor a n extra boost to get started runs about 25 bucks relatively easy fix only has three wires to connect
Jan 24, 2009 | Refrigerators
LG washing machine trips GFI Circuit Breaker
WASHING MACHINES ARE NOT TO BE CONNECTED TO GFI OUTLETS AND TRY TO CONNECT IT TO A CERCIUT THAT IS NOT WITH YOUR DRYER. (REG) OUTLET.
Jan 02, 2009 | LG WM2016C
Gfi outlet keeps tripping
try running an extension cord to the old outlet and see if the fridge works then you'll know if it's the fridge or outlet. good luck
Dec 03, 2008 | Whirlpool ED2FHEXN Side by Side...
Trips GFCI receptacle for laundry circuit.
I ran into this problem with a washer this summer. the gfi breaker needs to be replaced. it is weak and trips easily. if you can run an extension cord to an outlet without the gfi andrun your washer, you probably will not have any issues. that is what I found with the washer this summer. when it was plugged into the gfi, itwould trip. but when I had it plugged into a regular outlet, it was fine. Joe
Nov 18, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Fridge is popping my GFI switch
refrigerators are not supposed to be plugged into gfi outlets as they can operate normally and still trip the gfi protector. try plugging the unit into an unprotected outlet and it should work fine. incidentally you'll probably have to replace the gfi outlet as it has probably weakend from being used on the refrig.
Jul 04, 2008 | Frigidaire FRS23R4A Side by Side...
Washing Machines Logo
Dan Webster
Dan Webster
Sal DeAngelo
