Question about Epson Stylus CX3200 All-In-One InkJet Printer
Foam Strip on underside of print cartidge slider
I have put through some thick card which has picked up the foam strip on the underside of the catridge printing area and mangled it beyond repair.
Is there any where I can just pick up this foam strip or is there an easier solution. I just dont want to bin the printer as it is one of Epsons better printers.
  • BobSacrament Jan 11, 2008
    So did the foam in mine came out about the same time. I have had no luck on line to find any parts outlet. Epson was no help eigher .Bob,Sacramento CA.
  • Epson Master
  • 691 Answers
Try Express Terminals in the UK or your local Epson repair place may have a scrapped one you could beg the foam out of. Failing that why not just leave it out?
Posted on Feb 13, 2008
Okidata 320 turbo will start printing and then just stop. Alarm comes on and print head locks in place even after turning off. reset it and it and print just sort of jumps in same place.
Look for a strip of plastic running the full width of the printer. Its called an encoder strip. The sensor in the carriage looks at the encoder and counts the markings on it so it knows where to be. The strip can be dirty or marked and the carriage will have trouble reading it. Gently use a foam cleanser and wipe the strip clean. be careful as it is easily damaged. If you still have problem then a new "Space motor" is required.
Feb 05, 2018 | OKI Office Equipment & Supplies
What kind of weather strip i can use around the doors on my house?
i had the same problem with the kitchen door leading the the exterior back door (really bad fit).
there was nothing available so i double layered the foam weather strip which has worked fine for the last 6 years.
Sep 04, 2017 | Cars & Trucks
I have a 2004 new beetle convertible, automatic transmission. The cover strip on the shift mechanism disintegrated. Is it safe to shift the gears when that's gone?
I cannot see any immediate problems as it is only a trim cover. IT may be contributing to the reverse problem by bunching up and not allowing full selector movement. Some heater defroster units used foam strips around the core to prevent air from being drawn around the core and not through it as it lowers the heating efficiency of the heater unit. IF you are really interested you may check out the heater unit otherwise face the vents on the dash down so that you do not get foam bits in your eyes while driving.
Feb 01, 2014 | 2004 Volkswagen New Beetle Convertible
When printing from my hp 7150 photosmart printer the words are not printing straight, they are lopsided
Cleaning the ink cartridges with the HP Printer Toolbox
  1. Click Start .
  2. Click Settings .
  3. Click Printers .
  4. Right-click the icon of the printer in use.
  5. Click Properties .
  6. Click the Services tab.
  7. Click Open the HP Photosmart Toolbox or Service this device.
  8. Click the Device Services tab. This tab does not display in Windows XP; proceed to the next step.
  9. Click Clean the Print Cartridges .
  10. Follow the onscreen prompts.
Manually cleaning the ink cartridges
  1. Turn the printer on and lift the top cover.
  2. After the ink cartridges have moved to the center of the printer, unplug the power cord from the back of the printer.
  3. Remove the ink cartridges and place them wide side down on a piece of paper.
  4. Prepare a clean, foam-rubber swab or a lint-free cloth slightly dampened with water.
  5. Locate the copper-colored circuitry strip on the back of each cartridge.
  6. Clean the copper-colored strip with the dampened swab or cloth. Do not wipe the nozzle end of the cartridge or touch the nozzle plate.
  7. Clean the carriage contacts on the back wall of the ink cartridge carriage with a damp foam-rubber swab or lint-free cloth. Use a dry foam-rubber swab or a lint-free cloth to remove moisture from the contacts.
Cleaning the ink cartridge cradle
  1. Assume an eye level position with the HP Photosmart printer.
  2. Locate the ink cartridge cradle.
  3. Using clean, moistened swabs, wipe the underside of each wall of the carriage where fibers may collect and come in contact with the paper. Repeat until no ink residue is seen on a clean swab.
  4. Reconnect power cord when finished cleaning.
  5. When finished cleaning the ink cartridges and the cradle, print a test page.
Apr 05, 2011 | Office Equipment & Supplies
A thick black line prints out on back of paper every time i print.
called the local Canon printer repair facility, and a serviceman said that the black line is caused by too much ink in the ink absorber device below the paper path. He said to fix it requires disassembling part of the printer, replacing the absorber foam, installing a longer tip for the excess ink, and reassembling and testing the printer. I asked if this would be a permanent fix. He said no, that the problem could reoccur as the absorber foam would eventually fill up again.
This was posted 2 years ago by Shadyman.
The foam he is talking about is underneath the gray metallic strip that you see when you open the cover.
I used strips of electrical tape to cover that area where the ink is being picked up.
You can open the cove more by dislodging the piston on the right side. Needs two people, one to push the flaps apart and the other to pull the joint out.
Cut a 4 inch long strip, than fold the tape on it self such that there is about 3/4 of sticky tape left. This will allow you to push that portion underneath the metal strip where the paper normally would go. Place it at the location where the black line is (on the Paper). This will create a barrier between the foam and the paper as it moves by. ( I just had to figure out how I can do that)
Secure the tape by taping it on the the black bar, the one with the little fins on it.
I was able to push the tape down a little gap between the black bar and where the white rollers are. Make sure that the tape lays as flat as possible on that bar.
You may need to use two tape strips to cover the area..
I can also see my strips as I look from the outside at the **** where the paper comes out the printer onto the tray.
I guess the the foam swells up and hits a roller, which than offset prints the ink onto the underside of the paper.
Now I have no black line any more.
I know it's a fix, not a repair, but it works so fare.
Thanks to Shadyman for leading me in the right direction.
Dec 04, 2010 | Canon Pixma MP500 All-In-One InkJet...
1 day when my wife was printing (or copying), a
The foam was likely used for sound or to reduce the range of motion while in transit. If you are concerned, you could post a photograph of the area where the printer heads move across and a photograph of the foam.
How long have you had the printer?
Jun 07, 2010 | Canon Pixma MP500 All-In-One InkJet...
Black smear on underside of paper
Sounds as though you have a leaking black cartridge and ink has got on to the platen.
Open the machine as if you replace a cartridge. Remove the whole print head unit. You can do it without taking the inks out. What does the underneath of the print unit look like? Pretty messy I'm guessing.
Clean all the surplus ink of the base of the print head and put it to one side. Now look at the platen (that's the long strip of metal that will be underneath the paper while the print head is passing). Clean that with a damp tissue. If you look carefully at that metal strip you should find a long wiggly piece of foam inset into a cut-out in the metal. Gently prise it out and wash it in warm water - take are not to stretch it or break it.
Now with a torch or lamp look at the right hand end where the print head goes when it is resting. That may well be messy too. Using dry paper towel try to absorb as much ink out of that area as you can (you'll get you fingers very dirty!).
When you think you have got as much out as you can use a damp tissue to clean off any dried on bits.
Now carefully refit the foam bit back into its slot - it will only go in one way - and then refit the print unit.
Close the lid and do a print. Hopefull y everything should be OK.
May 18, 2010 | Canon PIXMA MP830 All-In-One InkJet...
HP Photosmart 7760 wierd colours and white lines
In this case I would suggest you to clean the cartridges of the printer.
  1. Click Start .
  2. Click Settings .
  3. Click Printers .
Aug 03, 2009 | HP Office Equipment & Supplies
How to back light the keyboard?
Just about the best question i've seen on here in 10 months!!!
How to backlight the keyboard???? Well.... most people buy a customized keyboard from the manufacturer or elsewhere that specializes in them.
The other way is to customize it yourself. What you would have to do is pinch a power supply from the laptop motherboard with positive and negative wires, say the fan connector plug for example as they only run on a few volts and are 2 pinned, then you'd have to find an place to install a strip of LED lights and connect the wires, somewhere under the keyboard if you can in a place that's not going to damage the laptop or interfere with the electronics.
Put the strip as close to the motherboard as you can and cover the backside of the strip with sticky foam pads and don't put it near the processor or the northbridge because the get very hot and will melt the foam.
Depending on the layout of the motherboard and the components you are going to have some figuring out to do.
Some people suggest drilling small holes in the underside of the keyboard, don't do this as you can damage the membrane that controls the keystrokes.
Good luck with your project.
Jun 28, 2009 | Toshiba Satellite A105 Notebook
Epson Stylus CX3200 All-In-One InkJet Printer Logo
203 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
