Question about LG Xenon GR500 Cell Phone
The music sync wont work for my phone - LG Xenon GR500 Cell Phone
How do i sync selected music from my itunes library on to my iphone? it wont let me select selected tunes only. i dont want the entire library transferred to my iphone
You add your selected music to a playlist and then sync just that playlist. You also need to enable either wi-fi only syncing or use the usb cable, manually managing music and videos.
Oct 20, 2012 | Apple iPhone4 4G iPhone 4
When i download the lyrics into my ipod it says unkown error 13019
  • It is a problem with the Voice Memos.Delete the Memo in iTunes.Delete the Memo on the phone.Synced. Success.
  • The problem is not limited to voice memos. The work-around listed of unchecking the "Sync music" box, then syncing, then rechecking the box, and syncing again, does seem to work.
  • Another solution would be
  • Go into iTunes while phone is plugged in. you will have a list of tabs across, summery, info, ringtones, music. select music and where it displays sync music unselect that and hit apply in the bottom right (dont worry your music should be saved on the computer) once the sync is complete re check the music sync option. ive noticed this to work 95% of the time......hope this helps
Jan 30, 2011 | Computers & Internet
How do i put music on my sch-u450 with a usb connection
All you need to do is to plug your phone with the usb to a system.
Go to my computer, you will see a drive representing your phone, right click to open and create a folder you want to put the music.
Go to the folder where the music is stored and copy the music you want to put on your phone.
Go back to the new folder created and right click to paste the music on the new folder in your phone.
Safely eject the usb and open the folder in your phone where the music is stored to play.
Take care.
Apr 19, 2010 | Samsung SCH-U450 Cell Phone
I cannot sync music from ituneson windows vista to
i think the Iphone your using is already linked to another itunes library, so once you link to the current computers itunes library the song there after wont be deleted.
Feb 28, 2010 | Apple iPhone 3G
My music syncs wont work.
tune clone will sync music into your ipod
Nov 13, 2009 | Apple iPod touch
Wont sync to windows media player
so, im running into a terrible restarting problem after syncing, most likely because of corrupted music files from limewire or actually i was thinking it might be an excess of songs. even though windows media player 11 wont say filled (after sync) I have a feeling that the restarting issue (my phone is practically flashing on, then restaring one time after another) might be from not having space on the card for updates? haha im no phone tech, just conceptualizing. this is my problem. if it is yours too, take the music back off your card or just remove your card altogether and your phone will be just fine. if you cant take the music back off the card, just format the card. ANYWAYS
to use windows media player 11 to sync to env3
plug in usb from phone to computer, i know its a big step
either- select music from the sync menu when the phone asks you
or - go into the my music folder and press the right tab button from the inner keypad that says sync.
then after your phone hooks up to your computer and is identifiable in the My Computer menu under LG VX9200, open windows media player, it might take a while to read the phone on the media player, then drag mysic into the window on the right hand side of the windows media screen. I had trouble when i clicked the sync tab on the top of the player screen, (you know, the tabs at the top that show now playing, library rip burn and sync) so i'd suggest not clicking the tab, and when device setup pops up, click next and finish. if your wmplayer screen freezes when you click finish and your device name comes up with two squares for its name, restart the process,
Cancel sync on your phone, get back to the sync button on your phone, and do it again, this time, make sure wmplayer is closed, then open it after your computer recognizes the phone. if the computer shows the name of the device as two squares, change the name, it seemed to help me. then.... well yeah just drag music into the window, its best to make a playlist that is named sync list..........mmmm better yet, that might be why mine is restarting, because the entire library is dragged from one playlist, but it doesnt syc like that....... damn nevermind. yeah just drag songs onto your phone and click start sync when you are finished, start sync will be located under the list of songs you create in the sync list window k? that was the bvest way i figured it out, except for my restarting issue, but like i said... limewire loves me. good luck, and help me out with my problem if you have any idea whats wrong, enV3 restarts after sync with micro sd card.
Aug 08, 2009 | LG enV3 VX9200 Cell Phone
My memory card wont work !
You have to install the USB sync drivers from your supplied CD-ROM before you can sync music.
Then select the "Music" option this will likely give you a prompt on your computer as to what to do next...
Dec 09, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Zte c79 cell phone
nu need to copy and paste music to memorie card or dreg and droop if u sync music on there ur phone wont pick it up even if the music is in there. First insert ur memorie card in and ur phone will create files for images and music. Then if ur computer has a memorrie card reader insert your card onpen the music file and also open the music on ur computer. Make sure ur music is in mp3 format other wise it wont read it. You must have both windows open so you can drag n doop your files. I beliave that should work because ia had the same problem and thats what worked for me.
Oct 14, 2008 | Motorola Mobility V60c CDMA Phone Cellular...
Music to Phone
I've never used WMP to directly sync to my Chocolate. I have success with the VW Vcast software which uses WMP through it. Maybe check Windows's website for troubleshooting on recognizing devices.
Nov 12, 2007 | LG CHOCOLATE VX8500 Cellular Phone
LG Xenon GR500 Cell Phone Logo
237 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
