Question about RIM BlackBerry Pearl 8130 Cellular Phone
Can you help me? Blackberry pear 8130 radio won't stay connected to service. Even after an update of software
  • kh_20002 Sep 24, 2009
    I don't have any of these phones. The blackberry is made by Research in Motion or RIM. Is anyone behind them? I don't know.
I have a Blackberry Pearl 8130, the mobile network shuts off by itself. When it try to provision, the phone states that the radio is shut off. How do I fix this problem so the radio stays on all the...
This is unfortunately a known issue with the Pearl. There are a couple reasons to why this happens. If your battery is defective, then your phone will sporadically believe that your phone is low on battery (even when its not), this will cause your phone to kick the radio off by itself--even every 5 minutes. Try cleaning the battery contacts or even try a new battery. Another reason is a faulty OS, if the battery replacement doesn't work, then the problem is with your OS and will have to be re-installed. I know this sounds like a hassle, but its a known issue and it should take care of your problems.
Below is the procedure :
http://crackberry.com/blackberry-101-lecture-12-how-reload-operating-system-nuked-blackberry
This would be a long procedure.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 12, 2011 | RIM BlackBerry Pearl 8100
My Pearl 8130 radio turns off every 2 minutes
You need to reinstall the factory settings on your handset using the disk that came with the phone. You may be offered a software update this will also work
Jan 14, 2011 | RIM BlackBerry Pearl 8130 Cellular Phone
Radio keeps turning off on pearl 8130 tryed battery reset but still turning off like every minute or less
This is a device issue. You will need to contact your service provider for replacement options!
Mar 06, 2010 | Verizon Communications BlackBerry Pearl...
My radio seems to turn off randomly, and i cannot call/text/email/browser or anything. i can't even charge it, it wont connect at all.
First, download and install the latest version of BlackBerry Desktop Manager software from: https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=DA5FB46338C8C0DCB1039F7898184FC5
Once installed, connect your BlackBerry to your computer via the USB sync cable. Open Desktop Manager, and click the Application Loader. On the right, you will see Update your device software. Click the Start Button, and if your BlackBerry is not on the latest Handheld Software, an update will appear. Select the update, and run the install. Be sure to select the option that backs up and restores your data. Once started, do not shut down your computer, or disconnect the USB sync cable as this could damage the device.
Once completed, your BlackBerry will restart and you will have the latest version available. This version has been known to correct various issues.
If the issue is still present, then it could be hardware related, and may need to be repaired or replaced. I would then suggest contacting your Provider for Hardware Support.
Could also be that your USB Port on your BB is damaged. You can use an external Battery Charger to charge your battery http://www.amazon.com/External-Battery-Charger-Blackberry-Pearl/dp/B001RW4ZT2/ref=sr_1_5?ie=UTF8&s=wireless&qid=1263526365&sr=8-5
Jan 15, 2010 | RIM BlackBerry Pearl 8130 Cellular Phone
When turning on my blackberry pearl 8120 all i
We suggest you to reinstall the software and check the handheld. If you face the same problem even after reinstalling the software, you need to visit the outlet where you have purchased the handheld to service the handheld
Oct 23, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
Blackberry pearl 8130 flashed to cricket wont connect to internet
You can call cricket and ask them to "refresh" your internet, wait 5 minutes and try again. Worked for me.
Aug 26, 2009 | RIM BlackBerry Pearl 8130 Cellular Phone
Radio keeps shutting off
When there is no signal around ur blackberry will shut off the radio instead of constantly searching for one which really kills battery power just make sure you arent in a real signal dead area and you should be fine to turn it back on just go to manage connections and click it back on,if this is not the problem then there might be some problem with ur phone.
Jul 12, 2009 | RIM BlackBerry Pearl 8130 Cellular Phone
I would like to find out the maximum GB SD Card you can use on the Blackberry pearl 8130. I Take allot of pictures and have allot of music on my blackberry and need more memory
It All Depends On The Software
BlackBerry Device Software Media Card Size Limit
BlackBerry Device Software 4.2.0 Up to 2GB
BlackBerry Device Software 4.2.1 Up to 4GB
BlackBerry Device Software 4.2.2 Up to 4GB
BlackBerry Device Software 4.3.0 Up to 8GB
Jun 14, 2009 | RIM BlackBerry Pearl 8130 Cellular Phone
Blackberry 8130 disconnects from Network after 10-20 seconds
You can always try and reprovision your phone and resend the Host Routing Table (HRT) but if it is constantly dropping service it is probably a hardware issue and not something that can be permanently fixed. It could also be a radio issue but I would take it back and request a new one.
Dec 31, 2008 | Verizon Communications BlackBerry Pearl...
RIM BlackBerry Pearl 8130 Cellular Phone Logo
360 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
