Question about Kodak i40 Path-Through Scanner
Red light blinking on the scanner. it is not scanning any more pages. Page gets stuck inside the scanner.
5 Suggested Answers
mohanchennai
  • 490 Answers
SOURCE: Getting vertical lines on scanned pages when
It is dust on the glass, clean it thoroughly. You will find it at the same location for all drawings and may get faded for lower brightness!
S. Mohan
Posted on Jul 10, 2009
komguy
  • 2306 Answers
SOURCE: I have a canon dr-9080c scanner and it is having
Sounds like you need a new CIS unit, the scan assembly or its lamps are flickering.
Posted on Jul 28, 2009
  • 16 Answers
SOURCE: i have a Kodak i620 color. All of a sudden the red
What does the KDS Log say? find it in the SVT info tab and save it for more info. its probably your ultrasonic sensors dirty or faulty. good luck
Posted on Sep 24, 2009
  • 43 Answers
SOURCE: HP7800 scanner scans multiple pages, only saves last page to PDF
Hi
i had the same problem- I unistalled all the software and then reinstalled and load this patch PDF patch from HP solutions centre and it fixed the problemhttp://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=15179&prodSeriesId=1151021&prodNameId=1151022&swEnvOID=181&swLang=8&mode=2&taskId=135&swItem=cs-75419-1
Regards Liz
Posted on Feb 22, 2010
My scanner is now adding a page with a black line that runs from top to bottom of the page and the actual document scanned is page 2. But the document is fine with no line through it. Does this mean that...
Check your scanner software settings. It is probably set at duplex ever time you start to scan. That is why you get two pages for every pass, the front and the back. You must place the document in the feeder in a way that the front side of the document is page 2. You may want to flip it next time you scan. So the main question is why there is black line from top to bottom? That is because there is a piece of dirt stuck on the glass of the scanner. You see, this scanner actually does two scanning when a page runs through it: the front and the back in duplex mode. So there are two scanners in side the box. The front page scanner apparently is dirty and needs to be cleaned with clean cloth and lens cleaner.
Aug 31, 2010 | Canon DR 3060 Path-Through Scanner
Why does my HP 1500 prints a test page every time I begin touse it???
HI
As soon as the printer prints the test page or alignment page place it on the scanner glass (Place the printed side down) before that Examine the scanner glass and white scan backing. Clean the scanner glass and scan backing if they are not clean. To clean the scanner glass and scan backing, use a soft cloth towel slightly dampened with clean water.
After That press scan on the printer button panel it will resolve your issue.
Try to double check it by turning it off and turning the printer back on after 2 minute's. If still the problem exists call HP Total Care 800 - 474 - 6836 if you are from US/Canada.
) Lift the lid of the product.
2) Place the top of alignment page face down in the right front corner of the glass.
3) Place the alignment page face down
4) Close the lid.
5) Press the Start Scan button.
6) The Power button light will blink during the alignment process.
7) After the Power button light stops blinking, alignment is complete.
Aug 04, 2010 | HP Office Equipment & Supplies
I have an hp 3150 all in one printer. Every time I turn it on to print a document it prints a test page. I am out of color ink so it doesn't print the additional numbers and lines to align the printer. I...
I know your problem and i want to know that have you changed or refill your cartridge?.
if yes
place one plain paper in the tray.
it will print the test paper
print it and place it on the scanner with the printed side down.
press the scan button from the printer
printer will blink the light for some time and stop blinking
now it didn't print test print every time you print
thanks
Jun 26, 2010 | HP PSC 1315 All-In-One InkJet Printer
9080c fails to scan single page; has trouble scanning a batch.
Hi
what size page are you trying to scan, if they are smaller than the gap between the transport rollers, they will not feed.
the single sheet problem you have:- the scanner knows when there is paper to feed when the sensor is pushed up beside the pick roller and it will put the tray down again when the rollers are pushed up. sometimes the little plastic sensor to the left of the roller gets a bit stuck and needs to be freed, it wares itself out where it hinges inside the cover around the pick roller. just unclipping it and cleaning it is usually enough.
good luck.
Oct 07, 2009 | Canon DR-9080C Path-Through Scanner
Black at the bottom of scanned pages
There should not be a thick black line at the bottom, but could be from several things, light coming in from somewhere is my first guess, toner is almost out or the ribbon is getting stuck on the inside at that point. You may have to call Cannon and ask them.
Aug 21, 2009 | Canon DR-2580C Path-Through Scanner
Red light is blinking. Do not know why. How do I
Unfortunately, only way to see the error codes you have to get the printer to give you a green light so you can print out the configuration page. Far as the red light blinking, there could be a number of things it could be.
First, make sure the toner cart is installed correctly
- Check to make sure that there is paper in either the pull out for fold down tray.
- Check to make sure that there isn't a paper jam. Remove the toner cartridge and check to see if there is any paper stuck inside.
If you get the green light after checking those things, press both buttons down for about 2 seconds and release. On the configuration page there will be a set of numbers that indicate what the error codes are. If you can get me that information I can tell what they mean.
Aug 03, 2009 | HP LaserJet 2100 Printer
Everytime I turn my PSC 1510 on it prints a test page, I have new cartridges in how can I stop it...it using all my ink unnecessarly:-(
yes, when you get test page face down the page on sccaner and press scan button after some time you get green light still, further u don't get test page again.
Jul 08, 2009 | HP PSC 1315 All-In-One InkJet Printer
I dont want to print test page
as when you get the test page while you on the printer.to stop it.just place the printer side of the test page on the scanner glass.and press the scan button on the printer.the green light will blink for 1 minute.then automatically stop.after that remove the paper from scanner glass.and now you will not get the test page again n again.
Mar 09, 2009 | HP PSC 1410 All-In-One InkJet Printer
Test Page
thats not the test page that is allignment page which is printing.
keep the the printed side of that page which comes out on the scanner glass.press the ---scan ---button.the on /off light will blink, wait till it stops blinking.and after that everything will be normal.
for any thing else let me know.
thanks.
Sep 17, 2008 | HP LaserJet 1200n Printer
Canoscan 9950f red line on scan
Try running a calibration. This is done thorugh ScanGear in Advanced mode. Once in Advanced Mode, in the Image Settings section there should be an option for Calibration (you may have to scroll down in this section to see it). After running the calibration, try performing a preview scan with nothing on the scanner glass. If the red line shows up on the preview now, then most likely the scanner needs to be serviced.
Mar 12, 2008 | Canon CanoScan 9950F Flatbed Scanner
Kodak i40 Path-Through Scanner Logo
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
