Question about Garden
MY RIDING LAWNMOWER IS NOT TURNING OVER? I HAVE CHECK THE BATTERY AND THE FUSE AND STARTER AND I THINK THEY ARE OK. IT'S MAKING A CLICK SOUND EVERYTIME YOU TURN IT OVER...
  • 389 Answers
Replace your starter solenoid
Posted on Sep 24, 2009
No click or sound from engine while turning key can be fuse
This is usually not a fuse but there is an ignition fuse that MAY control the solenoid operation on the started. Check your fuses first.
Also check your battery. Confirm it has a charge. If battery is charged and fuses are OK it may be the starter is shot. You can test this by disconnecting the wires from the starter, having someone turn the key like they are starting the car and testing the trigger wire of the starter for 12 volts DC.
Feb 05, 2016 | Cars & Trucks
Battery fully charged, fuse is OK but it won'tstart
check starter, is it making any sound while trying to start a click, slow turn, anything let me know more, thanks
Jun 16, 2015 | Garden
Where is the fusible link in a John Deere LX 255 lawnmower?
First thing to check is make sure you blade switch is in off position, brake/clutch is down and locked. There is a 20amp fuse in a fuse holder by the battery in engine compartment. Is it not turning over or not starting?
May 08, 2015 | John Deere Garden
Where is starter relay fo '06 zafira located?
Where is the starter solenoid on zifira b 1.9 cdti it won't start it's just making a clicking sound any one no why it's got a new battery on it help
Jun 28, 2012 | Vauxhall Cars & Trucks
Will not start fuse ok battery ok they said try new starter, its ok turn key on hear click Sound sounds llik up at carberator, AMP gauge gos negetive and starter will not ingage, belt for mower is...
I would try to jump the starter. Pos cable on the starter then ground out the neg, it the starter turns over that isnt it. then check the smaller wire going to your soleniod, when you turn your key to the start position it should have power. then check to see if there is power from the battery to your soleniod then with the key turned power from the soleniod to the starter.
Aug 20, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
20a fuse replaced, makes a clicking noise when
the starter could be bad take a medal hammer tap on side of starter see if that help if it works & starts then the starter is going bad & may need to be replaced but you can also have a bad starter sylinoid
Jun 26, 2010 | Garden
I have a riding lawnmower. Troy-Bilt Bronco. It
check the battery i.e. load test it they dont last long,most of 2 seasons,then if this is o.k. clean all terminals as any corrosion will cause this also and make sure all connections are tight,it doesn't hurt even if theres no corrosion to loosen and re-tighten all connections
Apr 09, 2010 | Garden
Starting problems with my cub cadet 2166 lawn mower? Battery is good, not turning over, sometimes it clicks? I can jump start but it is a pain. I have taken this to a dealer last year for this problem....
If it works when jump started, then I would suspect a bad battery or lose or corroded connection. check wires from battery to starter relay also known as solenoid to starter,if it is making a click,the ignition is most likely ok . safety start switch is ok ,I still suspect Battery..can you have it load tested or try a known good one?PS if above test OK, then starter or starter solenoid /relay.Hope this helped you fix it. please let us know if this helped.thank you.
Mar 22, 2010 | Cub Cadet Street Sign- tractor lawn riding...
My lawnmower won't start. WHen I turn the key it
Check battery cable for correct hook up. Red positive to starter and black to ground. If battery connected backward starter rotates in opposite direction and can burn up starter. If correct battery hook up check plastice gear on starter for wear.
Mar 11, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I have a three year old Snapper riding lawnmower, recently it stopped starting with the electric start. I put a multimeter on the battery and consisently get 12.6 to 12.7 volts, so I dont think its the...
Check your solenoid to starter output. If you are not getting 12 volts out, replace the solenoid. If you are getting a full 12 volts, check the input to the starter, if you don't get 12 volts there, check your cable for loose or corroded connections, if you do get 12 volts, replace the starter
Oct 04, 2009 | Garden
Garden Logo
182 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
