Question about Acer Ferrari 5005-5832 Notebook
Acer Ferrari OverHeating
Hi i've had this problem for a while now and it is starting to really irritate me
bascally my laptop is overheating under load
and hits the factory overheat turn off point and this is really annoying
What can i do as this laptop has run out of warranty
the model i have is the acer ferrari 5000
  • Anonymous Dec 25, 2007
    Well I have an Acer Ferrari 3000WLMi, about 3 years old, and have the same problem. It was always very hot when running. But just lately it gets hot enough that it shuts itselff off automatically. If I'm playing flight simulator I get anywhere from 10-60 minutes of playing before it just turns off.
    I'm going to buy a cooling pad for laptops I think to see if that makes a difference. Also will try to see if I can clean the fan/vents, but not sure if I can open up the computer?
  • poseidone Feb 03, 2009
    same problem... when i play some games the notebook overheat and turn-off
Another thing that you can do is remove the case, take the copper pipe off the video card and clean it off. Then clean off the video GPU to remove any old thermal transfer solution. Then apply some quick silver and reattach the heat pipe. It's possible that your not getting a proper heat transfer and it's causing the motherboard to overheat since the Radeon x1600 is integrated. I had the same problem, and fixed it by doing this. .
the thing I need more than anything right now. Is a new Lid, hinges, and bezil. If anyone has a dead Ferrari and are willing to seperate themselves from the spare parts. I could really use them. I need most is part 60.FR7V5.004 and 005 which is the Lid cover and Bezil. I can swipe the hinges off a Travelmate 8200 since they use alot of the same case materials.
Posted on May 10, 2011
  • kenneth184 May 10, 2011
    since the thread was more or less dead, i wonder Thevirus2068 if u think cleaning the machine and maybe re.doing the heatpipe is the solution. i have an ferrair one 200 and with flash applications the thing overheats since the fan doesnt turn on - but with a game (presumably since it uses the graphic card) doesnt. the thing that bothers me is that the fan stays steady at some 50% but wont go full throttle even while I can see that the core temp keeps rising and rising! is there a way to fix that ? speedfancontrol doesnt have acces and the F2 utlitly doesnt show any fan options, is mostly cosmetic - boot menus, passwords
    Sergeant:
  • 239 Answers
Your Fan speed may not be turning up to the right speed when it gets warm U can look in your bios and check your fan speeds and make sure all are working, and if the fans are ok, try some compressed air for electronics in the fan area and any other vents on the system. Sounds like maybe just dirty inside and can not cool properly. Try that let me know if that helps if not get a fan and run it to cool your laptop I know that sounds crazy but it will cool it down until you can 't get it fixed right, You may have to bring it in and get it fixed from a shop that can take it apart and clean everything inside.
Posted on Dec 31, 2007
My Acer laptop keeps restarting randomly whenever i use it.
Most likely cause would be overheating due to clogged fan intake/exhaust or failing fan. If you want to tackle yourself Google "disassemble Acer ______ laptop" (insers your model number). You can determine if overheating is likely by carefully blowing some canned air into the fan intake.
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Mar 13, 2016 | Acer Aspire 3935-6504 Notebook
Hi, does anyone happen to know why Acer Aspire FO would be shutting down (I assume from overheating because it is quite hot when it happens), sometimes even when there are just a couple of simple...
First try taking off the bottom access panels, and make sure there isn't a large amount of dust/hair that could be preventing it from cooling properly. If everything's clean, you should call Acer ASAP to use your warranty before it expires, as it is probably a hardware problem that isn't user fixable.
Apr 06, 2011 | Acer Ferrari One FO2001799 Netbook
My acer ferarri 1100 is overheating extreamly. Even cant touch the surface. This is happening only if I I change power profile to high preformance
You can get a USB cooling fan for laptop that will help with overheating.
Also to avoid laptop overheating, follow the information from this link.
May 19, 2010 | Acer Ferrari 1100 Notebook
My acer ferrari is so overheating and going shut off
if u know how to disassemble your laptop try it, and check if tha fan is working correctly... if no then replace it....
SocketX
Jul 09, 2009 | Acer Ferrari 5005-5832 Notebook
When i swich my pc on, my screen stays white with a red vertical line on it, wont start properly, why ?
Hi maurice_audr..
Maybe your CPU is overheating..
So wait until tomorrow .. Just to be sure...
And how did you post in here if that problem is still
occuring?
LOL..
NVM...
But really, maybe it is overheating ..
Or try turning it off then on .
Jun 23, 2009 | Acer Computers & Internet
Computer shutdown by heat.
The overheating can be caused by :-
The fan has stopped working - needs replacing
The vents and or fan is blocked with dust - needs cleaning
When operating the laptop it needs to be placed on a flat surface so the vents on the bottom of the laptop are ubobstructed.
Jan 26, 2009 | Acer Ferrari 4000 Notebook
Screen problems/overheating problems
If it's an overheating problem, updates won't help, cooling will. With the unit turned off, blow out all vents & screens on the bottom, sides & back of the unit. Get a cooling unit to put under the laptop. Mine dropped the temperature about 30 degrees and it hasn't shut off since I started using it.
If it's not from overheating, the way you have Vista setup to view different users windows should be changed.
Jan 04, 2009 | Acer Aspire 5100 Notebook
Laptop Heating up
this is a general problem, with most laptops not just Acer.
the more modern-faster and more memory installed, all contribute to these factors. battery power is standard for lasting anywhere between 45 minutes to 2 hours. 2 main causes of overheating, are that the fan exhaust outlet may be blocked or restricting warm air extraction from the cpu. secondly the heatsink material ( Thermal-Patch Or Paste ) between cpu and heatsink, is insufficient. there are other reasons but these are the 2 most common. if the laptop is warranted, i,d suggest returning it, for repair/replacement. if it isn,t then locate the cpu fan, and clean out any dust build up, usually between the fan and outer casing.
hope this helps you.
Mike @ Compurepair.
Aug 19, 2008 | Acer Ferrari 4002WLMi Notebook
Acer Ferrari 5005-5832 Notebook Logo
2,321 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
