Question about Xerox Phaser 3250D Laser - Monochrome Laser - 30 ppm Mono - 1200 dpi - USB - PC, Mac Printer
Xerox phaser 3250 problem. We want to print from a DOS application using the PCL emulation. so far we are unable to get this to work. We tried using the Printer Setting Utility but it says printer is not responding. Printer is working and printing. This is a network printer.
Wiired
  • 122 Answers
SOURCE: Xerox Phaser 6250 yellow line at far left of page
Sounds like it is time to replace the imaging drum. This is a consumable and usually done every 15-20k pages. Cost is about $250-300 and very easily replaced, fast as changing a toner.
I am assuming that you tried changing the yellow toner already? If not, do that first...
Posted on Jun 18, 2009
  • 110 Answers
SOURCE: Xerox Imaging Drum reset ? for Xerox Phaser 2135
The only way to reset the image unit drum is installing a new one. The new image unit has a fuse which once blown it resets the counter on the machine. You can call www.iteminconline.com I have their information in my ad place. They are good techs. I once called for a 7300 image unit reset and they said it was almost the same as a 2135 and they gave me this information. well goodluck.
Posted on Jul 24, 2009
  • 526 Answers
SOURCE: Xerox Phaser 6250 keeps saying
check to see if the switch in the printer is not broken,
you can take the tray out and look inside and you will see a switch assembly that corresponds to the printer tray settings. also, look at the papen sensor and see if it swings properly.
if it all looks well, you will need to get a part.
116134300 1 SWITCH; PAPER SIZE ASSEMBLY
Posted on Jun 15, 2010
Testimonial: "Thanks, I'll check all that out."
  • 78 Answers
SOURCE: I have a Xerox Phaser
Quickly try to press cancel on the printer and then turn it off. Then Open the print queue and right click on the document and select "cancel" you may need to do this a number of times, and if you can't get it out of the queue, reboot the computer and delete it then if it is still in the queue.
Posted on Sep 30, 2010
  • 57 Answers
SOURCE: Xerox phaser 7760 saying "non-phaser imaging unit"
There is a snippet on the Xerox website to solve imaging unit recognition problems, link below. http://www.support.xerox.com/support/phaser-7760/downloads/engb.html?operatingSystem=winxp&fileLanguage=en_GB Usually this problem only occurs if the NVRAM has been reset or the engine board has been replaced without backing up the NVRAM. You can download the snippet to your printer through Centreware or by downloading the 'File Downloader' utility from the same page above.
Hope this helps.
Posted on Jan 22, 2011
Reset to factory settings xerox phaser 3250
Reset to factory settings xerox phaser 3250 - Fixya
www.fixya.com/.../t12176778-reset_factory_settings_xerox_phaser_325...
Mar 26, 2012 - A hardware module is used to reset Xerox Phaser 3100 which work as permanent solution. After that you can refill unlimited number of times without ...
Mar 26, 2012 | Xerox Office Equipment & Supplies
Setup vms dcps print queue for a xerox phaser 8500 -can't do pcl
Can you update this with the VMS version please.
Thanks,
Dan
Mar 30, 2010 | HP Computers & Internet
When I print jpgs with the Xerox Phaser 6180, they print with a pink box around them
Have you tried loading a different print driver? I know the PS Driver is recommended for a phaser, but see if they have a PCL 5 or 6 and see if simply replacing the driver resolves the issue.
Dec 29, 2009 | Xerox Phaser 8500/DN Printer
Phaser 3200 only printing code, not actual document
Try downloading and installing a PCL language driver from the Xerox.com site for the phaser 3200. It looks like that could be a PostScript issue. Installing the right driver is very important anyway. If that does not help, try and copy paste the document in a new document and save first as the old document could be corrupted. If this does not help either lemme know and I think of something else.
Nov 11, 2008 | Xerox Phaser 3200MFP/N Laser Printer
Xerox Phaser 7300DN will not collate
Try using the PCL driver from the Xerox website, rather than the Postscript one supplied with the printer.
I had the same problem and installing the PCL driver solved it.
Sep 27, 2008 | Xerox Phaser 7300DN Laser Printer
Distorted image printing from InDesign to Xerox Phaser 8560
Have you tried a different driver? Most of those phaser printers have a PS driver loaded, See if there are PCL drvers for that product, and try that. I went on the Xerox.com site and they have both PS and PCL 6 and PCL 5 drivers, I believe one of those will help your problem.
Now that being said, If you are getting the stretching on other programs, then the problem is the drum motor encoder is getting contaminated with silicon lubricant from the maintenance kit. That will cause that problem, But since you are saying it is with one specific program, I suspect a different driver will correct the problem.
Sep 26, 2008 | Xerox Phaser 8500/DN Printer
PCL PC-864
http://www.support.xerox.com/go/results.asp?Xtype=download&prodID=4500&Xlang=en_US&Xcntry=USA&source=XOG&prodName=Phaser%204500 Here is the site you need. They have a web based pcl driver update. Good Luck, Tim
Mar 05, 2007 | Xerox 4500 Laser Printer
Xerox Phaser 3250D Laser - Monochrome Laser - 30 ppm Mono - 1200 dpi - USB - PC, Mac Printer Logo
294 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
