Question about Maytag MDE9700AYW Neptune 174 Electric Dryer
It sounds like an object has gotten between the drums. How do i remove the inner drum?
    Novelist:
  • 127 Answers
Disconnect from power, and give yourself some room.
remove screws from rear of top and slide top back, then up to remove.
disconnect harness from control panel, etc then remove screws attaching it to frame and set aside.
now you can get to the outer front covers top screws and i believe there are some on the bottom too, but can't be certain from parts blow up photo, may just slip onto a clip.
then the inner drum support will be visible with rollers, seal, etc. and your there.
just watch the metal edges, it is often very sharp from the stamping process that cuts them out.
hope this helps,
best of luck,
ttfn
Posted on Oct 27, 2009
How do you remove inner drum on top loading LG Washer WT5170HV?
The whole top of machine must be removed.
unplug electronics and hoses remove upper splash ring remove cap in center of agitator remove bolt holding down remove .
remove inner tub Nut center tube should lift up and out.
next step if your changing shaft is all from bottom.
lot more down there. Take picture b4 and as you remove for ref. to resemble
Jul 03, 2016 | LG Wave WT5170HV 27" Top-Load Washer with...
Scraping noise from drum, not bearing.
Could possibly be a broken drum cross. The part where the bearingshaft is connected/srewed on the inner drum. Could also be a foreign object stuck between innner drum an the outer casting
Feb 17, 2016 | Washing Machines
Dryer drum bearing and glides
it sounds like a pocket object has gotten traped between the drum and the gasket.to the cabnet ,with the power off use a thin dull object like a butter knife see if you can find it.
Dec 03, 2013 | Dryers
The machine sounds as though someone is dragging a stick along a metal palisade fence just as it goes into the spin cycle
You probably have some object stuck between the inner and outer drum. You will most likely need to remove the inner drum to get to it, which, depending on the model and type of machine, can be quite a difficult job.
Jul 06, 2011 | Washing Machines
Electric Dryer Model DCSR473EVOWW has loud scraping sound when drum turning .... sounds like metal on metal
There is likely to be something stuck between the inner drum and the outer casing. In my experience this is most commonly the wire from an underwired bra! (belonging to my wife!)
If the inner drum has holes in it feel the surface carefully all over to try to detect a wire or other object protruding into the drum. If you find something it can often be pulled free with a pair of pliers or pincers.
Jan 04, 2011 | GE Dryers
WHEN SPINING MAKING A LOAD NOISE
your drum bearings have gotten water in them from the lip-seal on the drum drive shaft,you need to remove the rear access panel,remove the belt remove the pulley,then remove inner tub and remove the spider that holds the inner drum on,then remove old seal and replace the inner and outer bearings,dont do just the inner bearing as the outer one isn't that expensive and may go out later,and its very labor intensive,anywhere from 2 to 7 hours depending on how stuck the old bearings are in the machine
Mar 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
We are trying to get drum out to remove trrapped object please help. have been told it pops out easily HOW??????
remove front seal from front panel then undo front panel to expose the drum at this stage you may be able to remove object if you can see it if not undo pulley and inner bol should pull out let me know how you went
Nov 05, 2009 | Zanussi ZJ1217 Front Load Washer
Have a front loading washing machine, it is making a horrible noise when it turns
Either something has gotten between the inner and outer drums or the inner drum support bearing has gone bad. Almost complete tear-down to fix it. Lift up and down on the inner drum (when machine is off) to see if it seems somewhat loose and makes a clunking sound when you do so. If it does, that indicates a failed shaft bearing.
Aug 06, 2009 | Da-Lite Standard Fast-Fold® Projector...
Whirlpool Duet metallic rubbing sound
if you've already ck inside front of door boot call repair acess from front can be tricky to almost impossible without removing complete door boot or worse
Sep 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Maytag MDE9700AYW Neptune 174 Electric Dryer Logo
151 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
