Question about Kenmore 30464 / 30465 / 30469 Gas Single Oven
Oven Turn oven part on, however does not seem to ignite gas is escaping. Not broiler part comes on?
  • 943 Answers
Hi. thanks for the question .i would replace the bake igniter .thanks the appliance doc
Posted on Oct 02, 2008
The oven on my g70m no gas coming through the grill still operates
Good morning Mark, you most likely have a weak oven igniter. That would prevent the gas valve from opening causing a no heat condition in the oven. Also try the broiler if it's separate from the bake burner.at the top of the oven cavity as opposed to the broiler drawer underneath. That igniter typically gets used less often and takes longer to wear out and the broiler will come on. It could also be a bad gas safety valve but that is an unusual problem. Hope that helps.
Feb 10, 2018 | Ovens
Kitchenaid superba oven
check the igniter for oven and change
you may have a seperate igniter for the broiler
Nov 15, 2013 | Ovens
SET DIGITAL THERMOSTAT TO SAY 350 DEGREES WILL NOT TURN ON OVEN,,, ? IF I SET TO BROIL BROIL WORKS BUT OVEN WILL NOT TURN ON ?
Possibly the ignitor for the main oven burner has failed--
An observation question:
When the Broiler 'lights' and comes on, do you notice the ignitor glowing bright, before the gas valve (to the Broiler) opens, and you get the Broiler lighting---
Now-- for the main burner to come on, -- there has to be a similar bright glow from the MAIN BURNER ignitor, before its main burner gas valve can open-- No Ignitor?-- No ignition, and not Main Oven burner!
Let me know what you need from this point on --
Mack B
Dec 30, 2010 | Maytag CWG3100A Gas Single Oven
Oven and broiler will not come on.
go to www.repairclinic.com enter model number and look for the igniter it seems to me you need to change this part. Note it is very fragile.
May 02, 2009 | Ovens
Oven/Broiler Igniters for KitchenAid range KGST307
Oven bake ignites usually have lifetime 5-7 years. If igniter glows but gas not came in - replace igniter. Same with broil igniter.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Dec 09, 2008 | Ovens
GE Oven does not ignite, bute Broiler does.
Your problem is with the oven igniter. You have the stove MODEL# so you should have no problem finding the part you need.Shop around to get your best price. Good Luck Friend.
Oct 14, 2017 | GE JGRP20 Gas Single Oven
Maytag gas oven mgr5770abb Does not light when I try to use oven. Broiler works fine. When I try to turn on the oven, the broiler igniter does not glow. If the bottom igniter was bad, wouldn't the top one...
first I would check to see if you have power (120v) at the bake igniter..when you set in to bake...use a multmeter..(when you turn on the oven to bake only the bottom igniter will come )
good luck be safe
let me know if I can help
Aug 15, 2008 | Maytag CWG3100A Gas Single Oven
Top Broiler works, oven does not work at all
hi yes you could replace the broil for the bake but they are very fraglle so i would buy a new bake igniter replace
May 18, 2008 | GE JGRP17 Gas Single Oven
WHY WON'T MY OVEN HEAT UP?
Most modern gas ovens and many broilers use a "glow-bar" style of igniter that glows red-hot to ignite the gas. If the igniter doesn't reach the proper temperature, the gas valve won't open. You may need to replace the igniter.
Oct 30, 2007 | Frigidaire FEB27S5A Electric Single Oven
Kenmore 30464 / 30465 / 30469 Gas Single Oven Logo
57 people viewed this question
Top Kenmore Ovens Experts
Archie Ferrarini
Archie Ferrarini
Marvin
Marvin
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
