Question about Radio Shack Accurian ADR-0106
Ny Accurian vhs - dvd player recorder will record from vhs to dvd ok. (following manual). I have direct TV and want to record my "Tivo'd" content from my direct TV "box" to Accurian dvd. When I turn on Accurian however it takes over the TV and blanks out the screen picture as if it were getting ready yot play a VHS or CD. How can I recored to DVD from content playing my TIVO? I have TIVO'd several football games I would like to recodr to DVD. I suspect it may be sometning in th eway I have wired up the system but have no ideas how to proceed. Can you help?
  • 11,896 Answers
Take the video and audio rca jack cables going fro direct tv box ouputs and hook them up to recorder rca jack inputs. Place recorder on AV or Input channel to record. Then from recorder to televison. Or have it go to both tv an recorder at the same time. You can do the same with coaxil cable as well.
Posted on Sep 24, 2009
Green tint on TV screen when playing DVD's or Videos 2nd problem and can't record anything
1: Hi i would recommend trying the recorder on a different tv to check if the problem continues. If the green tint is gone then its the tvs inputs. If it is still green then its the player or the cord. Try a different cord if the green tint is still there then the player has a problem.
2: Now for the VHS to DVD. There are general a lock out encoded on the VHS if it is a store bought movie. This is to protect the content on the VHS from piracy and that would case the DVD to be blank. The VHS to DVD are made for converting your home videos like family vacations and stuff you record your self and not for commercial movies like the ones you bye at the store. If you want to convert old VHS movies to DVD you would have to get another VHS player and another device in between the VHS player and the VHS to DVD recorder.
Mar 19, 2014 | Televison & Video
Using a JVC /DVD/S-vhs dual dubbing Deck model jvc sr-mv55u Trying to do a straight dub from an edited S-VHS tape to a formated for video DVD for archival library. I am following the instructions in the...
now days dvd player comes with advace tacnoloy
u not need make vedio dvd u make to your dvd as a data dvd & dvd plyer read it isely so dont need to do vhs or vcd
Mar 29, 2008 | Televison & Video
Want to record VHS to DVD on my Toshiba DVR620KU but do not want to connect to my TV set. Is this possible? My TV is older and does not have the input/output jacks. I just want to put in a VHS tape and a...
If the entire VHS is full then you can easily transfer the VHS contents to the DVD. The video will play while it is recording onto the DVD, but you don't have to have it hooked up to any TV for it to record. Now if you don't know how long the VHS content is that you want to record to DVD, then you will have to hook up the player to a TV so that you can press stop when you reach the end of the content you want recorded. At least this is true in the way that I use to transfer VHS to DVD:
1) Turn on the unit
2) Insert VHS tape
3) Insert DVD-+R or DVD-+ RW
4) Using remote, press VCR
5)Using remote, press play then pause the tape where you want to start recording.
6)Using remote, press DVD
7) Using the remote, press DUBBING. The VHS should start to play and the DVD should start recording
When using this method, don't hit the RECORD button!
I hope this helps!
Sep 05, 2011 | Toshiba DVR620 DVD Recorder/VCR
How do I record a vhs onto a dvd on the combo?
I have researched the manual for this particular device and you will not be able to convert/record VHS tapes to DVD discs. You can however record content from a DVD to VHS tape as this model only has a readable disc player not a DVD burner. Sorry, but you may want to research DVD recorders that also have VHS playback.
May 02, 2011 | Insignia IS-DVD040924 DVD Player/VCR
How to record a vhs tape to dvd on a samsung 1080
Hello
1.The VHS/DVD player must have recording capabilities.
2 Connect both players to a television so that you can make sure you are recording the appropriate content. You can also monitor the speed at which the VHS is copying to DVD.
3. Place the VHS in the VHS player and the blank DVD in the DVD recorder. You will need to use your remote and go through the menu options to choose the correct format for recording. The formats should be clearly labeled and outlined in your instruction manual. Choose the option that will read something like "VHS to DVD." You may also have to choose recording speed, which varies per blank DVD that you purchase. Every player is different, and every menu will vary slightly. If you have questions, refer to you individual manual.
4. Select the option that works best for you and hit "Play" on the VHS player and "Record" on the DVD recorder. To play the finished DVD, you will select the playback option.
THANK YOU
Dec 14, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
I have a Magnavox ZV427MG9. I follow all directions in manual for dubbing VHS home movies to DVD but when I try to play the DVD back there's nothing on them.What am I doing wrong?
Depending on the procedure you may be pressing the record button instead of the D.Dubbing or Dubbing button. When recording from VHS to DVD you must first, load the blank DVD and VHS home movies, then play the VHS movies, then PAUSE the VHS movie when you want to START recording... then the only the you have to do is pressing the D.Dubbing button or the Dubbing button. If your VHS tapes starts to play after the Dubbing button is pressed you have been successful in Dubbing.
Aug 13, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Accurian DVD Recorder/Hi-Fi VCR combo
You need to finalize the disc u recorded in order to play on other dvd's. press setup, press disc, press finalize then press yes. Finalization will start, this may take some time depending on the amount to be finalized. Be patient. Good luck.
P.S If u have the manual those steps are on page's 36-37.
Nov 30, 2007 | Radio Shack Accurian ADR-0106
Radio Shack Accurian ADR-0106 Logo
85 people viewed this question
Top Radio Shack Televison & Video Experts
Computer Repairing
Computer Repairing
xxxxxx xxx
Are you a Radio Shack Televison and Video Expert? Answer questions, earn points and help others
