Question about LaCie (300803) 60 GB Hard Drive
LaCie external harddrive won't format
I have a 1TB LaCie external that will not be formatted by my MacBook Pro OS 10.6
SOURCE: LaCie 500 GB hard Drive - does not register on my desktop
if it is a USB (or you have low disc space), it does take longer to show up on desktop and patience is required... on my iBook it takes over a minute for my Brick to show up... Whether it is USB or firewire, do try another cord (I had similar problem with my lacie firewire external... I used a different firewire cord and all was fine. If you have tried these already, I hope you find the answer... good luck
Posted on Jun 10, 2007
IB4G2008
  • 3587 Answers
SOURCE: Lacie 1TB external hd won't mount!
check wires connecting them together first, ok?
then, turn off the LaCie, connect to your MacPro, and then turn on the drive..
that should show as a mounted drive.
need printer drivers update?
Posted on Mar 09, 2008
SOURCE: Lacie 1TB External Drive flashing blue light, not being found
Hey
I know this arent a solution
Tho I have the same problem atm, this is just a networkstorage device, and this is a newly 1.
Posted on Feb 05, 2009
  • 69 Answers
SOURCE: Toshiba 500 GB External Hard drive cant be detected by windows xp
yes you could simply format the harddrive in Fat32 using your macos that would be the best solution but don`t forget to backup your data by copy pasting the files on your mac or something else and after that to move them on the external hdd again to be available on the windows machine
Posted on Mar 11, 2010
Testimonial: "It worked... I never thought it could be that easy... Thanks a lot!!!"
  • 3 Answers
SOURCE: lacie 1tb external hard drive into ps3 is not regconised
I have the same issue, however with my verbatim 500g its ok. i believe it is because the lacie is a desktop external and therefore is compatable with windows xp and 7 alone.
Verbatim is a "portable" external hard drive which makes it compatible with several different systems. I would suggest returning it, I just formatted my old verbatim harddrive and set up mediaasharing. Through my router. You can actually route the lacie harddrive by going to my computer and right click the icon. Next go to share with; advanced settings and allow all. Then when you turn your ps3 on search for media servers... I would suggest to google media server for ps3 to get it all seet up. GOOD LUCK
Posted on Sep 13, 2010
My mac laptop suddenly won't recognize it
you may need to swap the usb port it's plugged in
Jun 11, 2012 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Can a lacie rugged external hard drive be connect to a macbook -not macbook pro?
Yes - If the unit is USB it will work with any computer that has a USB port - if hooked up to any Mac though it normally will be formatted for use only with other Mac's. You can usually specify what type of filesystem you want to use when you have it hooked up.
Mar 16, 2011 | LaCie Rugged All-Terrain (301017) Hard...
It wont show/mount on my desktop
Have you ever connected this external harddrive to a macbook?
If you formatted it with your mac, it typically formats to a mac filesystem. What you would need to do is plug it back into the macbook, open up Disk Utilities, and then, after choosing your ext. hdd. you tell it to format into the EXFAT format. which is compatible with both systems.
Mar 12, 2011 | Iomega 1TB Desktop USB 2.0 Hard Drive
Installing 1tb External Hardrive from Freeagent onto Macbook Pro
I would be tempted to format the drive using the disk utility whch can be found under applications and then utilities once opened choose your drive in the left hand window and on the right hand side click on erase. If you are using the Seagate drive for the Mac only, format it as a Mac OS Extended (journaled) Choose your volume format and name and then erase. Hope this helps.
Dec 28, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Lacie 1tb external hard drive into ps3 is not regconised
Jun 07, 2009 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Hey
Feb 04, 2009 | LaCie d2 Extreme 250GB External with...
Formatted (on PC) 1TB WD hard drive cannot be altered on Macbook
What OS are you running? What is it formatted as FAT32 or NTFS and how big are the partitions. Various operating systems, hardware and formatting schemes have different limitations. If you want to use the drive in Leopard formatted with NTFS which is the only way to create partitions larger than 20 or 30 GB you may need to install an NTFS file system driver like FUSE.
The other option is to format it as HFS and install Macdrive 7 in Windows to use Mac formatted drives in Windows.
Hope this helps.
Dec 27, 2008 | Western Digital 250GB MyBook External USB...
One Touch 4 Maxstor 750 external hard drive installing on a macbook pro
If you have a hard-drive that is formatted as NTFS which stands for (New Technology File Ssytem), Mac OS X can only read the partition. It cannot write to it.
The trick is to use your drive manfacturer's disk-formatting software which will allow you to format your drive as one large partition. Formatting your drive as one large FAT 32 partition is the easiest way to make a drive so it can be used with both PC's and Mac's.
Another option is to use a third part utility so that you can read a MAC formated harddrive's from your PC. Here is one option: http://www.macdrive.com/.
Good luck.
SeekPCRepair
Feb 08, 2008 | Computers & Internet
LaCie (300803) 60 GB Hard Drive Logo
393 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
