Question about Cameras
My Pentax Optio T20 camera switches on ok, but .....
My Pentax Optio T20 camera switches on ok, the screen lights up and all functions are working, but 1 second later the screen switches off and won't come come back on again. The camera will still take pictures and videos, but the screen is off so you can't see what you are taking the picture of, so you point it at the wrong place. It did this 2 years ago so I left it swithed off with the battery out, and some weeks later it started working ok again. Where can I get a new firmware program that might fix this?
Regards
Alan R
  • 641 Answers
SOURCE: Pentax Optio SV tunrs off immediately
I have the same problem with my camera and the following activities solved it. Remove batteries and clean contacts of battery's host (include cover). Check as well that contacts are not bended and didn't lost their springiness. Good luck !
Posted on Aug 06, 2007
jbreth
  • 69 Answers
SOURCE: Pentax Optio W20 digital camera
I found a step by step manual for this operation. I hope it helps you get to transferring movies. http://www.pentaximaging.com/files/manual/OptioW20_pc_web.pdf
Posted on Sep 04, 2007
SOURCE: pentax optio s5i
Hold the OK key for 5 seconds while powering on the camera. this unlocks the menu and key modes.
Posted on Dec 04, 2007
svenby
  • 66 Answers
SOURCE: pentax optio m20 .. on-off immdly
i got it!!! on my cam i hold down the menu button at the same time power on, it will showup a " ver 1.00" and lens move a little maybe u have to do it 2 times but second time it should work
Posted on May 30, 2008
Nova_1
  • 196 Answers
SOURCE: pentax optio s 60 driver
http://www.soft32.com/download_185396.html for Windows 98/Me/NT/2000/XP
Posted on Oct 14, 2008
TENGO UNA CAMARA PENTAX OPTIO E-35 Y AL ENCENDERLA ME MUESTRA UN CANDADO QUE NO ME DEJA USAR EL MENU, QUISIERA ME DIJERA QUE DEBO HACER PARA DESBLOQUEARLA
Its possible that your have locked the SD card; remove the memory card from the camera and make sure that the physical switch is in the "UNLOCK" (up) position. See photo example...
Keep us updated.
May 09, 2011 | Pentax Optio T20 Digital Camera
Pentax Optio S10 cannot take photos in flash mode
HI there check the battery first. Red light blinking in working mode when the battery not having enough power for flashing. So i suggest you charged the battery fully or if its old then replaced it. Thnaks.
Apr 04, 2010 | Pentax Optio S10 Digital Camera
Camera wont turn on!! help!!
Dear Texaslilly,
Although there is nothing much to do but you can still try the following.
  1. Try with different set of batteries
  2. Remove the memory card from the camera
  3. Cameras generally do have an option to plug-in external power supply..Try with external power supply .. if there is any.
  4. Now this might sound little crazy but no harm in trying .... Remove batteries... Press and hold the power button for few seconds... release the power button ... reinsert the batteries and try to power on without memory card.
Try the above and let me know if it works.
Regards,
Srinivas.
Jun 19, 2009 | Pentax Optio T20 Digital Camera
SD memory prohibits functioning of Pentax E30
I know that usually, you should format the card for the camera that your going to use. Try formating it in the camera and see if that works. Let me know if I can do anything else for you,
Rob
Feb 22, 2009 | Pentax Optio E30 Digital Camera
Digital camera fault
hey Lotusman - I don't have an answer but I do have an optio M40 with a broken LCD screen, want to sell me your camera?
Mar 18, 2008 | Pentax Optio M40 Digital Camera
Unlock Pentax Optio S5z
I had the same problem with the exact same camera (Pentax Optio S5Z) that happened the same way. I searched everywhere on the web and finally found this post that didn't have a solid solution. So I started experimenting with different button combinations and finally figured it out.
Hold the OK button while turning on the camera. The screen should indicate that it is in audio record mode. Now press the Menu button and use the navigation keys to find and execute the system reset option.
After turning it off and back on it should function normally.
Mar 16, 2008 | Pentax Optio S5z Digital Camera
Pentax Optio T10 turning off immediately
My optio t10 did basically the same thing...turned on, lens goes out, then automatically shut off. I took the advice of a solution listed here for another problem...hit the camera. For whatever reason it worked.
Apr 08, 2007 | Pentax Optio T10 Digital Camera
Open Questions:
Cameras Logo
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
