Question about Microsoft SideWinder Precision Racing Wheel
Sidewinder v1 connected through USB port. I'm running vista. When I try to calibrate through control panel, game controllers it is treated as a joystick. The brake pedal is looked at as Y-axis. Any ideas please.
Can the microsoft sidewinder force feedback wheel with usb plug work with xbox 360. part # X04-97607 12v 1.3a
The core gaming functions in both Windows and XBox 360 are based in part on DirectX API's so if it works in Vista/Win7 it should work with a 360 game that's not just a cheap port from a different version. The only issue I can see (if it does work) would be control mapping.
Feb 23, 2015 | Microsoft Video Game Consoles & Games
Usb plug to 9 pin game port
This is a problem. Even USB gameport adaptors don't seem to work with the sidewinders. Shame cause that's a great stick.
Best bet would be a PCI soundacrd with gameport(that you can find drivers for) on XP, since vista and up don't support analog inputs.
Nov 14, 2013 | Microsoft SideWinder Force Feedback Pro...
Unable to connect Joystick in Game Controlers
What game are you trying to play? Most newer games don't know about the old game ports anymore. That could be the cause.
Nov 11, 2012 | Microsoft SideWinder Force Feedback Pro...
I have a Sidewinder 3D Joystick with the old standard gameport 15-pin connector. I bought a new motherboard that didn't come with a gameport, so I bought a PCI soundcard with a gameport incorporated. I...
Make sure you get the latest drivers for your soundcard. The drivers will include the software for the joystick port so its recognized properly by windows. Also you may want to go to the support page for your soundcard to see if any settings would need to be changed as well.
Sep 22, 2010 | Microsoft SideWinder 3D Pro 2.0...
Just loaded flight sim to m/soft vista and have lost the driver disc for sidewinder pricision 2 joystick. Is this unit compatable with vista? If so, can someone direct me to the best free driver download...
Sorry it will not work with vista.
Operating System Requirements: This product is designed to run on the following operating systems:
  • Windows 98
  • Windows 95
Additional Requirements:
  • Windows 95/98
  • Pentium 166 or higher
  • 16MB RAM
  • USB port
  • DirectX 7.0 or later
You can try this also
Usually, Windows will find and automatically install the necessary drivers when you plug your game controller into your computer.
• Plug the game controller into the USB port on the computer. The computer can be turned on when you do this. Windows will recognize the new hardware and set it up to work properly.
Note: Controllers that use game ports (and other ports) are not supported in this version of Windows.
Try this second:
You must be logged on as an administrator to perform these steps.
1. Open Device Manager by clicking the Start button , clicking Control Panel, clicking System and Maintenance, and then clicking Device Manager.‌ If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
2. In Device Manager, locate the device you want to update, and then double-click the device name.
3. Click the Driver tab, and then click Update Driver and follow the instructions.
Sep 23, 2009 | Microsoft SideWinder Precision 2 Joystick
Microsoft sidewinder
Maybe ...or not ... I have a joystick that has 15 o0ut to USB in .(m \???? )
they ar4e available !!!!
Jan 25, 2009 | Microsoft SideWinder Force Feedback Pro...
I want to run my sidewinder joystick on my vista home premium.
try go to the products home page and download the latest driver for the joy stick. you should be able to calibrate it too =)
Dec 31, 2008 | Microsoft SideWinder Precision 2 Joystick
Microsoft sidewinder force feedback 2 joystick
Well, I just noticed this exactly same problem with my new PC, so i try it with my older PC and it works fine, I´m not sure if this has something to do with the USB 2.0 or the driver, but i was not able to find the version 5.X for it, microsoft page only has the version 3.2.
the extrage part is that both PCs are using the same version of WXP.
Feb 22, 2008 | Microsoft SideWinder Force Feedback Pro...
Device driver required
here are the drivers, I have the same gamepad, and CD drivers is like new
link here http://www.megaupload.com/?d=OZ6SJ6XX
sorry for my bad inglish, I'm from argentina
Dec 08, 2007 | Video Game Consoles & Games
Microsoft SideWinder Precision Racing Wheel Logo
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
