Question about Hotpoint Kitchen Ranges
Re-engage bottom latchrs on door
I HAVE A HOTPOINT DIAMOND SERIES RANGE. To facilitate cleaning I managed to remove the front door. However re-installing it
is a problem as the bottom
latchs do not re-engage. I do
not have the manual - can you
help?
  • rsgirardau Sep 24, 2009
    I REALLY JUST WANT SOMEONE TO SIMPLISTICALLY
    TELL ME HOW TO RE-ENGAGE THE RANGE DOOR LATCHES.
    I indicated that I did not have the manual for the range
    expert no 2 came close but did not cover the
    HOTPOINT TYPE WHICH IS PRESUMABLY VERY COMMON
    IN NORTH AMERICA
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Try and reset it by Pushing and holding the Cancel/Off button for 10 seconds. Please check if you are getting any loud buzzing or clunking noise heard when locking or unlocking the door. The door is latched with the help of door lock solenoid. When you close the door the solenoid gets activated and dis engages when a cycle stops. The solenoid coil is a common failure point which is often mounted on the back of the range. The door solenoid mechanism is mounted towards the front, under the top.
Failure of a solenoid style lock is most often caused by a bad solenoid. Once the lock is located, the solenoid coil shouls be checked for continuity. These latch assemblies also have micro switches in the power supply that will need to be checked for faults too. And, if these switches are faulty the solenoid will not engage due to open circuit due to micro switches.
Be certain to unplug or remove power from the range before undertaking any repairs yourself and follow all standard safety precautions.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Sep 24, 2009
    President:
  • 1,714 Answers
Go here and watch the short video and it will help you:
  • 11,896 Answers
Kitchen.manualsonline.com/ex/thread/view/.../1077902
www.appliancejournal.com/...manuals.../download-use-and-care-manuals-for-any-appliance-239/
www.repairclinic.com
Copy and paste any of these links in you address bar to get a manual
Ffa52 hotpoint diamond freezer running too warm
change condenser fan clean condenser coil dust at bottom of ref stopping cooling processes.Just like if you put cardboard in front of your car it will over heat or if fan is not blowing air on condenser coil
will not cool it fan and coil at bottom of ref. remove back you will see the dust pet hair a big problem with ref.
Mar 04, 2015 | Hotpoint Refrigerators
Which fuses for Hotpoint Range Diamond Series?
The higher Amp fuses are for the oven elements and the lower amp fuses are for the burners on top and the lighting if applicable. Some models have it printed on a piece of paper next to the fuses holders. Let me know if it helps!
May 08, 2013 | Hotpoint Kitchen Ranges
I need to replace the rubber seal on my Hotpoint ice diamond freezer door I can't find any fixing screws on the inner door panel can I assume then that the panel clips on.
Me too, I have a Hotpoint Iced Diamond Under counter fridge that needs a new seal and i also cant see any fixings to remove it. I did read somewhere that you can't replace them you need to buy a complete new door.
Dec 14, 2010 | Hotpoint HTS16HBR Top Freezer Refrigerator
I removed the range door to clean oven. Now I
NOTE: The door removal pins you inserted must still
be in both sides of the door.
1.
Grasp the door on the sides with your fingers on
the front of the door and your thumbs on the
inside surface.
2.
Rest the hinge hanger so that it is flat (at the
bottom of the hinge hanger on the bottom of the
front frame slot).
3.
Position the door with the hinge hanger slots
almost parallel to the front frame.
4.
Push up and in until the hinge hanger slots
become fastened to the range. Lower the door
and rotate it slightly from the front to the back
until the slots are fully fastened. The hinge
hanger will be close to the bottom of the front
frame slot.
5.
Pull door open about halfway and remove the
door removal pins. Save door removal pins for
future use.
6.
Close the door.
Dec 25, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
How do I remove/clean the filter on my Hotpoint Aqurius condenser drier?
There are 2 filters to clean on this dryer.
1 is at the bottom front left, pull all the way out, and wash clean under running water, quite in order to do this.
The second one is at bottom front right, again pull out to clean, but do not use water on this one.
Some dryers also have one located inside the door opening, pull out to clean if yours has one.
Please leave feedback.
Thanks
Nov 13, 2009 | Hotpoint TDC32 Electric Dryer
How do I remove and then replace a new door seal on my hotpoint WD420 washer / dryer
First switch off electrics , Remove door interlock , leave wires on .remove soap dispenser,remove front panel with controls 3 screws top of machine 3 screws bottom remove front casing you can now see door boot. remove sring note how boot came off refit is oposit to this noting top / bottom of seal ..Hope this some help-
Oct 03, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Whirlpool range
Hello dolphin 1 mom
Welcome tofixya.
You said, accidentally removed the door to my range and now it won't go back on. The door won't go back into the slots on the range.
Send me your e-mail address and I'll e-mail the diagram with the door instructions for removal and replacement.
It will not fit in here with the diagrams.
Waiting for you.
Huuum
Please do not forget to enter a rating when we are done
These are the installation instructions, but with no diagrams
To Remove:
1. Open the oven door. Insert door removal pins, included with
your range, into both hinge hangers. Do not remove the pins
while the door is removed from the range.
2. Slowly close the door until it rests against the door removal
pins.
3. Grasp the door on the sides with your fingers on the front of
the door and your thumbs on the inside surface.
4. Pull door straight up, then toward you. Hinge hangers will
slide out of front frame hinge slot. Do not remove door
removal pins until the door is replaced on the range.
To Replace:
1. Grasp the door on the sides with your fingers on the front of
the door and your thumbs on its inside surface.
2. Hold oven door so that the top edge of each hinge hanger is
horizontal. Insert hinge hangers into the front frame hinge
slots.
3. Tilt top of door toward range. Slide hinge hangers down onto
front frame support pins. Make sure the hinge hangers are
fully seated and engaged on the support pins.
4. Insert the door stop clip with its angular surface at the top of
the frame hinge slot, then push in the bottom of the clip until
its flanges are flush with the front frame.
5. Open the door completely and remove the door removal pins.
Save door removal pins for future use.
6. Close the door.
StorageDrawer
The storage drawer can be removed. Before removing, make sure
drawer is cool and empty.
To Remove:
1. Pull the storage drawer straight back past the drawer stop
notch and the end of the side rails.
2. Lift up the back of the drawer and pull the drawer out.
To Replace:
1. Lift up the back of the drawer and place it inside the range in
its fully forward position.
2. Lift up the front of the drawer to a level position.
3. Slowly push the drawer into the range until the drawer side
rails engage with the gap in the drawer glides.
4. Once the drawer is fully engaged on both sides, slide the
drawer back into the closed position.
NOTE: When removing and replacing the storage drawer, a slight
push may be needed to move the drawer stop notch past the
drawer glides.
A. Removal pins
B. Hinge hanger
A. Hinge hanger
B. Door frame hinge
C. Support pins
A
B
A
B
C
A. Drawer stop notch
B. End of side rail
A. Engage drawer glide
A B
A
Sep 09, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
We took the oven door off and now can't put it back on
i dont know how you got the door off the is a lock for each hinge
lay the door down with hinges facing up.take a towel pull long piece
of hinge toward you(BE CAREFUL) take other piece up and lock them together do the same to the other hinge it should then go on easy next time lock before taking off
Dec 09, 2007 | Hotpoint RB757 Electric Kitchen Range
Kitchen Ranges Logo
67 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
