Question about Ruud UAKA030 Air Conditioner
I tried changing the thermostat (unsuccessfully) and may have blown a transformer. My AC unit will not turn on. Is this an inexpensive repair?
  • 3,361 Answers
If you did not turn off power and or have a hot wire touching a common wire you blew the transformer. There is a possibility your air handler has a 3 amp fuse on a control board. Check it first. If it is OK,replace the transformer.
Posted on Sep 24, 2009
AC chronotherm IV plus thermostat has no display and AC has gone off and will not come back on.
Either the 5 amp fuse is blown on the indoor unit, transformer is bad or float switch is tripped.
May 28, 2017 | Amana Heating & Cooling
Compressor want come on
Here is what to do . Pull out or turn off Electrical disconnect behind unit . Carefully remove panel covering controls in unit . Note most units have a flat panel with a few screws, but some GE units have a welded metal box on top of unit which needs to be removed. After exposing controls. replace or turn on disconnect. Then take a plastic handled screwdriver and push in on center of contactor (boxlike part with a lot of wires hooked ) If the compressor now comes on release contactor , and check for 24 Volts AC at base of contactor where thermostat (small wires that run on outside of black refrigerant line ) with thermostat on and calling for cool you should measure 24 to 28 volts . If voltage is present replace contactor after disconnecting from power. If no voltage go inside , remove cover from thermostat, and check for 24 volts between red ( R) and yellow (Y ) terminals on thermostat , If voltage is present , replace thermostat , no voltage check voltage in heater / air handler if you have voltage at air handler , replace thermostat wire from heater to thermostat / if no voltage check for blown fuse in heater , this should be either an inline fuse or an automotive type fuse plugged into circuit board (with power to heater disconnected check broken wire or black mark in fuse when held up to light. If fuse good turn on power to heater and check for 230v to one side of transformer, if you get voltage to Primary (incoming side ) of transformer, check output side of transformer for 24 - 28 volts. If transformer shows input but no output replace transformer after turning power off. If you heard a buzzing or grinding noise , when pushing in contactor , but compressor didn't start look at run capacitor (this is round or oval shaped object with wires going to contactor and compressor ) Looking at area where wires plug this should be a flat surface , if it looks domed shaped or bulging out , it is blown and needs replaced , use same mfd rating and 440 Volts to be on safe side. / If there was no noise from compressor when contactor was pushed in , put your hand on top of compressor (black object in center of unit ) If hot , allow to cool for at least three hours with power to unit turned off and retest . If compressor comes on after cooling , check for bad fan motor in outside unit (it may make a squealing or wining noise and stop runing for a while , also check for / clean outdoor coils
Hope this helps .
Thanks,
Alex
Oct 04, 2014 | Carrier Comfort 3.0 Ton 13 Seer Ac Only...
Thermostat has no power
I think that most likely shorted out your low voltage transformer. Transformer is most likely located in air handler. You may find a blown fuse for transformer or bad transformer.
Jul 05, 2014 | Ruud UBHC Air Conditioner
Thermostat blank ac wont come on
Hello, some units have a condensate safety switch that will cut off power to the thermostat when the drain line is clogged, A wet/ dry vac must be used to clean out the drain line before the thermostat will receive power again. Amother reason could be either a blown fuse or burned out transformer.
Jul 09, 2012 | Amana 4.0 ton 16 SEER AC / Goodman Gas...
My dog chewed the thermostat wire by the compressor, i replaced the chewed wire now the thermostat won't turn on, therefore; no ac.. could it have blown a fuse? if so, where are they?
Either you have blown the low voltage fuse located inside the air handler (if there is one) or you have blown the transformer feeding the low voltage control wiring.
If the transformer is blown due to no fuse installed, I would recommend installing a low voltage 3A fuse in line with the red terminal coming off the transformer. This will protect the transformer in the future.
Aug 01, 2010 | Goodman CKL42AR42 Air Conditioner
I replaced the thermostat because it wouldn't turn on, it still doesn't turn on. What else can I check?
Jump the two thermostat wires together at the thermostat, if it fires up; it is a bad thermostat. Jump the terminals where the thermostat connects to at the gas valve, if the unit fires it is a bad thermostat wire or connection. If the unit does not fire, check for 24 volts AC out of the transformer. If yes, bad gas valve, if no bad transformer or no power to transformer.
Dec 27, 2009 | Cozy (W352E) Heater
My heater fan wont turn on in auto mode but will in manual
Well you have a good transformer and the fuse is not blown. So I would look for the most obvious thing which is the relay. Why the relay? Well most units do double duty as air conditioner and heater. AC and heat require different fan speeds. The relay shifts the fan from low to high for ac. The fan runs on low for heat. In rare instances it could be a bad wall thermostat but most times not. You know the fan is good because you can get it to come on manually.
Some Repair Photos
Dec 24, 2009 | Heating & Cooling
Have a Ruud AC unit the problem I have after installing a new condenser fan motor when I throw the circuit breaker the unit will not turn on but when I push the contacts on the contactor in manualy the fan...
The contactor engages from low voltage power from the thermostat as does the outside condensing unit. You may have blown the low voltage transformer or have a loose thermostat wire. Check line voltage(220 volts) to the transformer. Check load voltage(24 volts) from the transformer. If no voltage out,replace the transformer. If you have voltage out(24) check the thermostat wires and the thermostat. If you have a digital thermostat there is a 5 minute delay in the thermostat after power is restored before it activates.
Oct 08, 2009 | Ruud Central System Air Conditioner
Having a problem with my AC/Furnace. AC was working fine and was turned on for about 3 weeks. Thursday night it cooled off and we opened up until Saturday morning. On Saturday morning the AC would not turn...
I think your problem is poor usage of the device,i.e. overloading the system. try running better cables to your furnace and ac. The reason i am lead to believe that is. If you already hired a pro to come and fix it for you,and he/she could'nt then what else could it be? in my experience ac units use electricity like microwave ovens.and power tools
Sep 12, 2009 | Heating & Cooling
As I was cutting weeds away from my outdoor ac unit, I accidentaly cut through a small wire that has a red and white inside of it, we wired them back together and still have no ac or heat or air, we just...
first try turning off the power to the furace for 15 sec and tunr it back on (reset the computer) you may have blown a control fuse on the contol board inside the furnace, turn off power and becareful of hazardous voltage conditions
Aug 15, 2009 | Intertherm P3RA-048K Air Conditioner
Ruud UAKA030 Air Conditioner Logo
101 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
