Question about Kenmore Washing Machines
I need to replace the motor drive coupler 285753A in my top loading kenmore washer -- can you give me instructions
    President:
  • 1,937 Answers
This is a relatively easy fix for the basic Kenmore / Whirlpool washers.
Please see GURU JSROCK516 Description of how to remove cabinet and access the transmission.
http://www.fixya.com/support/r699497-replacing_gearcase
Follow the instructions for removing the cabinet and pulling the pump, motor and motor mounting plate.
The coupler has two plastic pieces with three prongs each. In between is the rubber coupler with six holes.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
Posted on Sep 24, 2009
How do I replace the motor coupling
Washer Motor Coupling (part #285753A) - How To Replace ...
? 8:35
https://www.youtube.com/watch?v=MYB5x-IqtIM
Aug 4, 2011 - Uploaded by AppliancePartsPros
Follow these simple step-by-step instructions to replace the drivemotor coupling on top load direct drive ...
Motor coupler replacing Whirlpool direct drive washer ...
? 5:08
https://www.youtube.com/watch?v=H0o95LEjBtM
May 22, 2011 - Uploaded by theapplianceman
For more videos visit my website at http://goo.gl/WdE9
Nov 23, 2015 | Washing Machines
My washer doesnt twist black and force
sounds like you have a belt broken that moves the drum...replace and should be ok...
Nov 27, 2014 | Kenmore 2942 400 3.2 cu. ft. Top Load...
Believe that my problem can be fixed with a belt replacement but cannot figure out how to get washing machine apart in order to replace. Kenmore 22442 top loader.
this video shows step by step how to replace the MOTOR COUPLER which the manufacture of that washer has used instead of a belt for about 15 years now
http://www.youtube.com/watch?v=9K1KHEogf3c
Part number for that coupler as shown in the video is 285753A
Aug 26, 2011 | Kenmore 22442 Top Load Washer
Model 110 wont spin, just click click click.
sounds like the motor coupling....................YouTube - Washing Machine Drive Motor Coupler Replacement (part #285753A)
Mar 05, 2011 | Kenmore 22642 Top Load Washer
Drum will not spin in any mode. Pump works but get a grinding with any spin cycle
replace your drive coupler
tip unit back
you will see the pump
attached is the motor
behind the motor is your coupler
part number 285753a
take the pump off by 2 clips
take the motor off with 2 clips and 2 screws or just the clips
let me know if you need more instructions
Jan 08, 2010 | Kenmore 24032\24036 Top Load Washer
MY WASHER WILL NOT SPIN. iT MAKES A LOUD BUZZING
Sounds like a broken motor coupler for sure, the motor shaft will still spin the drain pump, but drive between the motor and transmission is lost. Part# 285753A. Have fun. If you need breakdown info let me know.
Dec 30, 2009 | Kenmore 22422 Top Load Washer
My kenmore model # 11020802990 stoped spinning a
Check the motor coupling. Remove the cabinet, pump and motor and see if the coupling (designed to break if the transmission or motor jams) is broken. Check the Sears site
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=11020802990
for part number :
pd_0026_110_285753a?$pddetailsth$ #13 on diagram Coupling, motor Number:3364003Substitution:285753A $18.50 In stock Quantity Add To Cart
Manufacturer authorized substitution: 285753A may differ in appearance, but is a functional equivalent to prior parts including 3364003. If it isn't the coupler, it most likely is the motor.
Sep 14, 2009 | Kenmore 24902 Top Load Washer
The drum is not spinning. I hear a noise like when you stick something in your bike spokes.
Assuming that this is a Kenmore / Whirlpool top loader with a direct drive system, the first thing to check is the motor coupling.
The transmission and motor have plastic parts that connect through a rubber coupling.
pd_0026_110_285753a?$pddetailsth$ #13 on diagram Coupling, motor and isolation Number:661560Substitution:285753A $18.50 If the coupler rubber piece wears out, the pins on the motor and transmission sides will rub together making the sound.
If the coupler looks good the problem is likely in the transmission.
Sep 10, 2009 | Kenmore 22422 Top Load Washer
Kenmore 70 series washer, clothes are soaking wet after spinning
If it fill and motor runs but will not agitate it likely is the coupler. If you have the cabinet off and see the motor here is what you do.
there are 2 metal straps that attach the motor to the transmission. take the screws out that hold the straps on and pop the straps out of their slots. the motor will then come off and the coupler is between the motor and transmission. One section goes on motor shaft and one on the transmission shaft with rubber bushing in between.
Coupler part number is 285753A
May 16, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Have to replace motor coupler. Need instructions.
Here ya go. Click on the following link:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
Please follow the advice in the link provided. The part number is included if you need it. If you have questions, please let me know. I hope you find this information helpful.
Apr 20, 2009 | Kenmore 42822 Front Load Washer
Washing Machines Logo
413 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
