Question about Samsung Digimax A503 Digital Camera
Batteries goes dead
My batteries goes dead after only one picture is taken why is that I use new batteries
SOURCE: batteries
use lithium ion batteries had same problem once I changed batteries they last for a long long time
Posted on Jun 28, 2007
  • 4 Answers
SOURCE: camera batteries drain quickly
Open the battery door and check the contact between the camera and the batteries. Most often then not there is just a bad contact and it's ruinning your baterry life.
Make sure that the contact are well placed and that there is no rust or dirt build up around there.
Posted on Dec 20, 2007
  • 148 Answers
SOURCE: Even with new batteries and they go dead before I take 3 pictures
Yes, there is definitely a fault with your camera.  You should be able to return it for a replacement.  I wouldn't experiment too much with batteries in this camera. batteries discharging this quickly are likely to overheat, causing unmentionable catastrophe.
Posted on Dec 11, 2008
SOURCE: Batteries keep dying
Camera was still under warranty & I sent it back to Canon after calling them. Service was incredibly fast. They found the optical assembly inoperative & focus not operating properly. They also sent battery recommendations. I think I am going to try the rechargables. They recommend: Panasonic Alkaline Gold, Duracell Ultra, and Canon Ni-MH. Will let you know how it works out. Thanks for the help as well.
Posted on Jan 01, 2009
SOURCE: New batteries show only a partial charge in
test test test
Posted on Jun 09, 2009
2yrs old. Went thru 3 sets of batteries to get 20 pictures. Dead again. What`s the story?
Sounds like you have a short in the wiring. This is repair shop stuff, or buy a new camera time. Usually, if it is a point and shoot , it is not worth sending for repair as you'll playas much as a new camera is worth. I would look for a new camera, personally. Good luck.
Oct 20, 2014 | Cameras
Will not power on. new batteries installed.
Hello
Thank you for using FixYa for your problem
Always check the batteries first but if is it still giving the same fault, your camera is faulty.
It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Dec 01, 2009 | Canon PowerShot A95 Digital Camera
NIMH Battery goes off after 20 shots for Nikon Coolpix L01
the camera takes just about any AA pair of batteries ... lithium will give you the most pictures .. your NiMH batteries should last longer unless they are old .. you may have one weak battery ... you can try a pair of standard alkalines to see if there is something wrong with the camera .. if those work ok then you need a new set of NiMH ... there is a new type out called "eneloop" .. they are just like normal NiMH except they dont go dead when you store them .. even after a year they are still charged .. with normal NiMH batteries as they age they will self discharge in 2 weeks or so .. so you have to charge them just before you use them ..otherwise they go dead on their own .. if you charge them then not use them for a week then you will not get nearly as many pictures ... the eneloop batteries fix that .. you can also recharge them many more times than standard NiMH batteries .. they cost about the same ..
Oct 06, 2009 | Nikon Coolpix L1 Digital Camera
Draining rechargable batteries;
Carry spare alkaline batteries - just in case...
Does the same symptom happen with alkaline batteries?
Lithium Ion batteries are 1.2volts
Alkaline are are 1.5volts
Rechargeable Alkaline batteries are 1.5volts
Perhaps you should switch to Rechargeable Alkaline batteries if the symptom goes away when you use alkaline batts...
Sep 17, 2009 | Samsung Digimax D53 Digital Camera
New battries won't charge.
Sounds like the batteries are completely dead, you'll probably need to replace them, sometimes you can only use batteries until they die, and that goes for Wheelchair Batteries too. If they won't charge or keep a charge then they are dead.
Mar 03, 2009 | Jet 3 Ultra Power Chair
Dec 11, 2008 | HP Photosmart M547 Digital Camera
Camera won't take pictures w/new batteries
You should replace the camera with the identical battery as recommended. REfer to your manual for the browsing of the previously taken pictures.
User manual also will tell you how to replace the battery.
may this help, melnavz
PS:
pls do not rate me if my solution not solve the issue and you need more further information. but if is invaluable solution rate me fixya.
Apr 22, 2008 | Polaroid i531 Digital Camera
Screen goes black and camera shuts off
Are you using lithium batteries?
All Kodak cameras seem to have issues with alkaline batteries.
Although lithiums cost more, they work well and provide better value and performance than alkaline batteries.
Mar 17, 2008 | Kodak EasyShare C613 Digital Camera
Battery?
i just got mine today, and the batteries were dead withtin a couple of hours, so yes. mines has decided to go black, it was fun while it lasted,, theres £90 ill never see again
Aug 24, 2006 | Samsung Digimax S500 Digital Camera
Samsung Digimax A503 Digital Camera Logo
23 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
