Slow frame rates and background where forground should be
Abnormal vcore at 1.17v and abnormal 1.2v at 1.5v also cpu running at 88c underload
    Sergeant:
    Champion:
  • 243 Answers
More info on yor system would help but at 88c it sounds like your cpu is overheating and throttling back.
Try cleaning out any dust on hsf and renewing the thermal paste with good quality stuff.
Hope this helps?
Posted on Jan 07, 2008
The highest vcore voltage on my intel 2500k
Suggest you try an overclocking forum
All I know, is you bump the Voltage up in SMALL increments.
Bump up a small increment, then do a 24 hour burn in.
(Yes. Means computer runs 24 hours straight for the test)
Everything's cool? Then bump the Voltage up another small increment.
Do another 24 hour burn in test.
GO TOO FAR, and things start getting 'bumpy', and eventually system turns off.
GO TOO MUCH at first, and you stand the chance of frying stuff.
Also; the Ram Memory, and expansion slot frequency rate, support changes, when you change the Voltage for the CPU.
You are changing the CPU's front side bus, also. (FSB)
[Frequency Rate = 'Speed'
People understand the term Speed, so they can relate to what is going on.
It is actually a rudimentary term.
Leaves you not exactly knowing what is going on.
A CPU (Processor) has an Oscillator in it. Operates in a frequency rate.
The Front Side Bus (FSB) is measured in a Frequency Rate.
How many Cycles per Second.
Example; CPU operates Up To a maximum frequency rate of 2.4GigaHertz. (2.4GHz)
Means it can operate Up To a frequency rate of 2.4 Billion Cycles per Second.
Mega = approximately 1 Million
Giga = Approximately 1 Billion
Hertz stands for Cycles per Second.
(2400MHz = 2.4GHz)
Also:
YOUR processor. The one you have now.
Was made with a BUNCH of other processors.
Intel tests them, and has a pass test range.
YOUR CPU may have been at the Bottom of that range, who knows?
This means YOUR CPU may not be able to be overclocked, like Harry's down the street; or some guy/gal on the internet.
THEY may have received a CPU that was in the Middle of the pass test range, or towards the Top.
Regards,
joecoolvette
Mar 14, 2013 | Computers & Internet
Where is vcore set? bios or cpu driver?
Vcore settings can usually be found in the bios settings menu. But be careful when playing around with those settings!
Mar 06, 2011 | Acer Aspire 5004WLMi Notebook
My pc seems to be running slow. t ran the dic
Type CTRL-ALT-DELETE, and click "Task Manager".
The "Performance" tab will show you the CPU-busy percentage
(it will be high when a computer-game is running, or when a computer-virus is running, or when a DEFRAG is running, or when Windows Update is running as a "background" task).
It will also show how much physical RAM is installed,
and how much of that RAM is "free' (currently not being used).
On the 'Processes' tab, you can see which process is using the largest share of the CPU, and the largest amount of RAM. Close any "runaway" process.
Run a virus-scan.
Dec 31, 2009 | HP Computers & Internet
Is cpu booster what i need?
How many services and/or applications do you have running in the background? Click <start> <run> and type "msconfig" without the quotes, then click on <Diagnostic Startup> <apply> and reboot. Now do the 3 finger salute (Ctrl, Alt, Del) and check your CPU usage. If it has dropped way down repeat the process and this time click on the Start up tab and uncheck all those things which don't need to be running in the background.
May 08, 2009 | HP Pavilion dv6000z Notebook
Hardware Monitor Problem Sony Vaio
have you tried installing a seperate controller card?
Jan 27, 2009 | Sony VAIO Digital Studio PCV-RX580 PC...
Samsung CRT Blank Screen
1.Check O/P Voltages that time If U find abnormal voltage of vertical IC supply Pl change supply Diode&IC
2. check 5V supply,change 5v Regulator.
Aug 19, 2008 | Samsung SyncMaster 793DF 17" CRT Monitor
Vcore power adapter for the cpu
Being that it's new it's probably still covered under warranty. Sounds like the motherboard is the suspect.
Jul 23, 2008 | DFI LANParty UT RDX200 CF-DR Motherboard
Is it possible to fix my laptop webcam?
I don't know what the deal is with gateway's performance monitor, but the low frame rate is normal for web cams (and digital cameras in general) in low light situations. I would recommend just getting a cheapy desk lamp and forget about the night mode if possible.
Jul 16, 2008 | Computers & Internet
H/W Monitor reports Abnomality/Voltage Problem
firstly i would replace the cmos battery
if the pc has been powered down for a while the battery may not
have had enough power to hold the settings
replace the battery and load defalt cmos/bios settings
let me know how you get on
Mar 24, 2008 | ASUS P5N32-E SLI PLUS (0610839148967)...
Computers & Internet Logo
119 people viewed this question
Alun Cox
David Payne
David Payne
