Question about Maytag Ensignia MAV4758AWW Top Load Washer
Maytag Ensignia very loud noise during agitation
My Maytag Ensignia makes a very loud noise during the agitation cycle. It is coming from under and inside the cabinet. The noise is in time with the movement of the drum, and the drum seems to struggle to move back and forth. Any ideas?
catriver
  • 878 Answers
SOURCE: "howling" noise during spin cycle (still there after changing burned off belt)
Travioso, there was two service flashes out on this model concerning the seal and bearing which means they had an issue with this washer. The howling noise you are hearing is the bearing and will need the new designed triple seal and bearing kit. This should be covered under your warranty, I believe it is 5 years. The numbers for the service flashes are TDL-0048A-B. Call Maytag and inquire about these service flashes, these should be covered. Catriver.
Posted on Jul 25, 2006
Lumpy816
  • 246 Answers
SOURCE: ensignia maytag washer noise
The bearings on Maytag Ensignia's are part of the seals that keep the water in. Once you start hearing the bearings begining to go, you likely will have a leak following shortly thereafter as the bearing greased is washed out by your laundry soap. Up front. This is a procedure that requires specialty tools and takes me about 45-60 minutes to complete. The easiest way to tackel this job is to take your model number (just on the back side of the console) and take it to a local appliance parts store. Ask them for a tub seal kit. (I can't give you a part number since there is no model number listed) but they should be able to pull it up for you. When they bring it up to the front, inside the seal kit is not only step-by-step directions, but also the part numbers for the specialized tools required as well. If you opt to go the repairman route, I'll forewarn you, the company I worked for charged around 250-300 for the repair on this. Send me back a message if you have any troubles or other questions.
Posted on Jul 01, 2008
huuum
  • 750 Answers
SOURCE: Maytag Atlantis black oil like residue and can't remove agitator
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
this is a very common happening and it means
This usually means that a seal is degrading or dissolving.
This washer is a top loader, Right!
I believe it calls for HE ( High Efficient) laundry detergent.
If we use to much of either it will cause this !
This usually happens due to using to much detergent or bleach.
You said, Black oil like residue discharged from washer during use. Stain clothes, almost impossible to remove. Loosened nut on agitator but it will not budge, and am afraid of damage if I try to pry between agitator and bottom of drum.
Please remember to leave a rating before you go!
Thank you
Posted on Sep 28, 2008
  • 532 Answers
SOURCE: maytag washer screeches during wash cycle and spin
probably needs a new belt,water gets on it and makes it squeal
Posted on Aug 19, 2009
  • 12 Answers
SOURCE: Maytag Washer HAV2558AWW loud noise during spin
May be the bearing in your direct drive shaft. If washer is a belt drive, the belt could be frayed
Posted on Nov 17, 2009
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
I have a Maytag Performa Washer, model number PAVT244AWW, that does not agitate. Everything else is working. It makes a loud noise during the wash and rinse cycles when the agitator is supposed to be...
My Maytag Performa makes a grinding sound when it agitates. When it starts to dump the water it makes a loud grinding on metal sound... really loud. What is the problem and how much to fix?
Sep 05, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Maytag ensignia makes a great deal of noise during rinse cycle
"If you dont have a noisy spin cycle and the noise you hear is only on the rince cycle, dont be worried, as this is totally normal. Water sprays onto the drum while the spin cycle is in progress and rewets the clothes to allow any existing soap to be desolved. This noise is in effect the water hitting the drum during the rince part of the cycle.
Sep 03, 2010 | Maytag Ensignia 3.3 cu. ft. Top Load...
Maytag top-loader making very load creaking noises from agitators
it could be you lelft something in the pocket of your pant that fell out an didnt drain out an si in the bottom of washer tub you have to remove the agitator an the basket if you dont know how call a techican ok are try an take a flashlight an see if you see any thing stuck in the bottom are the side of the basket ok
Oct 21, 2017 | Maytag Ensignia MAV4758AWW Top Load Washer
Loud squealing noise during spin cycle.
Please keep in mind, I'm attempting to diagnose your unit without being there and with very little information.
From my experience, I would think you have a bad belt. They get stretched over time and start squealing in the spin cycle. If you don't change it, it will make a noise in every cycle until it comes off.
NOTE.
When changing belt. Check and be sure the pulleys have no play on their shafts. They also go bad. It's better to fix it all now than one to have to repair four or five times this year. Good luck!
Please rate solution
Sep 25, 2009 | Maytag Ensignia MAV4758AWW Top Load Washer
Squealing during agitation...drum seems to be 'sticking' ....
could be several things if it is an intermittent squeak that goes in time with the agitation then you have bad brakes if it is constant then you may have a bad pump or object in the pump
Sep 19, 2009 | Maytag Ensignia 3.3 cu. ft. Top Load...
Maytag top load performa, put clothes in , fill up and now the agitator is noisey, looked under washer belt appears to be loose 2-3 inches in play, should I replace belt,or something else to repair noise...
thats normal tension on the belt if the agitator is making noise the cams within the agitator are worn (loud clicking or popping noise during wash) the agitator will need to be replaced
Dec 15, 2008 | Maytag HAV2558 Top Load Washer
Burning smell/noise with my Maytag Ensignia MAV7657EWQ Washer
it could be [motor] or 'condensur' for motor, starting to burn out or over heat, check drive belt as well for ware
Dec 08, 2007 | Maytag Ensignia 3.3 cu. ft. Top Load...
Maytag Ensignia MAV4758AWW Top Load Washer Logo
70 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
