Question about Sony Audio Players & Recorders
Sony STR-D715 Protect Mode
I have a Sony STR-D715 that I'm working on. I picked it up from a guy who said it stayed in protect mode. I had it on my bench with nothing hooked up to it and it is in protect mode. So I do some looking and I notice that a few parts on the right channel where burned. A couple transistors and 2 resistors later, I replaced the noticably burned parts and parts with shorts on them. I can't find any more shorts and it is still in protect mode. I might have narrowed it down to the stk3102 amp but I'm not sure how to check the part to see if it is working properly. Does anyone have experience with this or know a quick and dirty way to check the amp ics? I have the schematics for it if someone needs those to look at. Thanks
    Scholar:
  • 167 Answers
This is a common problem...
It is in fact a bad power-amp module.
I have repaired quite a few of these receivers by replacing it.
The module is inexpensive. I Googled the Part number and found several sources for it.
Posted on Oct 10, 2009
Protect mode
I didn't see any mention of it in the STR-D565 manual, but on many other Sony models the "Protect" indicates a short in a speaker wire.
Aug 22, 2013 | Sony STR-D565 Receiver
Can not get surround sound to work
Your Protection System probaly come on for some reason,Sony Is Known for that problem, Check on your screen if a red lit warning Staying (protect) Is on.If there is, Try hiting the reciever on the sides or the top of the cover fairly hard when it is turned on, Some times this will work to turn the protect light back off, Sony is bad for there amps end recievers going into the protect mode,
Sep 19, 2012 | Sony STR-DG600 Receiver
Hi. my sony STR-DE 597 go in protect mode. how can I fix/repair this? Give me a tips.
protect mode means there is a shorted components inside your reciever it's probably the out put transistors take out the transistors and test it with a multimeter.
Jul 11, 2011 | Sony STR-DE597 Receiver
Sony str-de545 protect mode?
Disconnect all speaker wires at the receiver and turn the unit back on. If it stays on, your receiver is ok and you need to reconnect speakers one by one and test until you find the one causing the "protection" once you find this, disconnect the wire at the speaker and test again. make sure the + and - wires do not touch! If the receiver stays on, use a multimeter to test the speaker for a short with resistance check. If your not sure how to do this, any home audio shop will test it for free and while you wait. If speaker wires are disconnected and it still shuts down, it needs to be serviced. Hope this helps
Nov 18, 2009 | Audio Players & Recorders
Goes into protect mode..
you probly have speaker wires arching. unplug them and replug thm in making sure no bare wire is showing
May 17, 2009 | Sony STR-DG520 Receiver
Sony str-d715 flasses protector
Protet mode is a special diagnostic mode that starts when a fault is detected.
When in protection mode the unit is prevented from starting by protection circuit, so to prevent further damage.
Check the speakers and speakers wiring, a contact in speaker wires, or faulty speakers can send the unit in protection.
Try unplugging power cable for one hour or so. then connect cable back and see if you get rid of protect state. Sometimes accumulation of electrostatic charges inside circuit capacitors can kick in protect mode. In that case unplugging the unit from main for some times can get rid of electrostatic charges, and reset circuits by draining power completely.
If that was the problem, you will not get Protect when plugging back power cable.
If you do all the above and still get Protect, then there is a real fault.
In that case the unit may be disassembled and tested to find the fault.
If that is the case I suggest contacting the manufacturer at the number listed on the owners manual, or asking a quote on repair to a local technician.
May 03, 2009 | Sony STR-D700SS Shelf System
Sony str-de525 system "protector" problem
You've blown it. It recognizes a potentally harmful situation and goes into protect mode.
Mar 15, 2009 | Sony STR-DE935
Stuck in protect mode
Speakers shorted out, blew a fuse. Replace the unit or (cross your fingers and) open up the box and find the blown fuse.
Nov 23, 2007 | Sony STR-DE425 Receiver
810 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
