Question about 477L Ask RXTX HHU Remote
The 24 hour timer stays on and I don't know how to turn it off
Lock button and F (light) i hate that thing.
Posted on Jan 11, 2010
Model dehumidifier DDR2611/4011, how do you set the timer? What is the on and off timer for, and the 24 hours?
Boy you know you're in trouble when a web search for your product gives fixya on page 1 google.
There is a product manual for your dehumidifier Sept 2012: but it doesn't say how to set the timer. What a doofus manual.
http://www.danby.com/cms/products/en_manual/Manual_for_DDR26114011_%282%29.pdf
There is a customer care phone number:
http://www.danby.com/en/CA/customer_service
On and OFF are probably manual override, so you can operate unit without timer.
24 hour means a 24-hour military-time clock without am and pm. So 1pm is hour 13, and 8pm is hour 20, and 1am is hour 1, etc.
+/- set the humidity
Best guess for Seting the timer.
Press and release clock (timer) button. You may have to press and hold.
And probably auto start is first thing on menu.
Press + or - button to select start hour from 1 thru 24.
Press clock (timer) button again.
And probably auto stop is next.
Press + or - buttons to select stop hour from 1 thru 24.
Probably you press clock button again to exit timer programming.
Sep 06, 2012 | Hardware & Accessories
Need to know how to set timer #15075
GE 15075 is heavy-duty plug-in-type 24-hour analog timer with pins located around dial.
Each pin represents 1/2 hour. Two consecutive pins represent 1 hour.
Open following links to identify timer and to read detailed instructions:
http://waterheatertimer.org/How-to-set-timers.html
http://waterheatertimer.org/GE-timers-and-manuals.html#15075
Aug 31, 2011 | General Electric GE 24-Hour Timer, 2-Pin...
My power strip, that I paid good money for about 7 years ago, is now vibrating and making a noise during the night time. Obviously, this is when it is not in use and does not seem to have the problem...
Question posted under analog power strip.
Analog timer has small clock motor.
When the plastic motor gears wear down, the clock begins to make noise.
Might not hear the noise when TV is turned on.
To get analog timers to last longer, be sure to keep timer in dust-free environment so nothing clogs the gears.
I don't know how to take apart this timer without breaking it.
http://waterheatertimer.org/GE-timers-and-manuals.html#striptimer
New GE timer at Amazon $10.46
http://www.amazon.com/57698-24-Hour-Power-Strip-Timer/dp/B00067OOFY/ref=sr_1_1?ie=UTF8&qid=1292413124&sr=8-1
Heavier duty Woods timer at Amazon $19.62
http://www.amazon.com/Woods-22575-24-Hour-Power-8-Outlets/dp/B002L706K4
Buy Utilitec power strip timer locally at Lowes and save shipping.
Buy GE at Home Depot and save shipping.
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 29, 2011 | General Electric GE 24-Hour Power Strip...
Hi I have decora 24 hour programmable timer 6124h. Its display seems to be working just fine and I can change the settings on this. But its not turning the load on. Any idea? Much appreciate the help on...
I don't have repair for defective timer.
Check wire nut connection going to load.
Confirm that load is operable and turned on.
See if timer is producing output on blue wire.
Try timer in place of a different switch to see if problem is load or wire going to load, or if timer is defective.
Make sure there are both ON and OFF times programmed.
Check wiring:
Timer blue wire to load.
Timer black wire to hot.
Timer white wire to neutral.
Green to ground.
http://waterheatertimer.org/Leviton-timers-and-manuals.html
Aug 07, 2011 | Leviton 6124H 24 Hour LCD Programmable...
Lights come on but don't stay on even though the tabs are set for it to stay on say from 4-12 it will go off at 7:30. Someone got thier hands on this before i did---could the tabs have been broken if...
GM40 is commercial-grade electronic time piece with FM1 analog timer dial.
I bought a used GM40 once and the electronics were bad, so if this is a used timer, it might not function as expected.
I don't think the tabs/pins are broken. FM1 timer module is heavy duty.
Turning the dial clockwise does not damage timer. That's how you set current time and test timer.
Rotating dial counterclockwise is not possible without breaking the timer.
http://waterheatertimer.org/pdf/Intermatic-Grasslin-gm40.pdf
FM1 analog timer module can be replaced if timer stopped working.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#FM1
If certain pins/tabs are broken, you might be able to work around problem by offsetting current time by 6 hours or 12 hours. Or you can move wires from NO to NC terminals and see if the relays are causing a problem.
To set FM1 timer, the pins are pushed outward or inward.
For example to turn on Load for 1 hour, then 4 consecutive pins are moved.
To turn on Load for 3 hours, then 12 consecutive pins are moved.
To test if pins need to be inward or outward, set some pins and then manually rotate timer dial clockwise and watch when the Load turns on-off.
Jun 19, 2011 | Intermatic GM40 - 24 Hour/7-Day Dial...
I have ge model 15119 24 her timer and need help on how to set
GE 15119 timer is a 24-hour plug-in dial-type timer.
Dial rotates as time passes.
Plastic segments located around outer edge of dial control on-off operations.
Each segment represents 30 minutes of 24-hour day.
Timer comes with segments down.
Each segment can be lifted up using small screwdriver under edge of segment.
Segments down, timer is ON.
Segments up, timer is OFF.
So if you want timer to turn on at 7pm and turn off at 11pm, then lift all segments around dial except segments between 7 and 11.
Dial is divided into two parts > day and night.
Nighttime hours are shown by numbers with dark background >> notice small crescent moon where 12 midnight is located.
Daylight hours are shown by numbers with light background, and sun symbol shows at 12 noon
To set current time, so timer knows what time it is right now:
Rotate dial clockwise until current time lines up with arrowhead located on inner dial.
There is override switch located on one side of timer.
Move switch to Timer ON position and timer program will function.
If you want to turn lights ON using override switch, move switch to OUTLET ON.
Last steps:
Turn lamp on.
Plug lamp into timer.
Plug timer into wall.
Dec 01, 2010 | General Electric GE 24-Hour Timer, 2-Pin...
Intermatic ej351, i ned the instructions for resetting the timer. to turn it on at 630pm and off at 100am pleae
1) Use this procedure to automatically program, letting switch timer "record" ON/OFF activities over 24-hour period.
-Move control lever to OFF-CLEAR for about
20 seconds. Red indicator light goes off and previous
time settings are cleared.
-Move control lever to ON position. Red indicator
light starts flashing.
-At 6:30pm, manually press dial 'on' >>> then at 1:00am manually press dial 'off'
-At the end of 24-hour period, switch timer is programmed and Red indicator light will stay ON, indicating
switch timer is in AUTOMATIC mode.
2) Or you can manually program times using instructions from page 1 of manual:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/ej351c%20-%20english.ashx
Sep 19, 2010 | Hardware & Accessories
There is also a way of setting it by simply turning the light on and off at the desired time. Can yu help?
Manual: http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/ej351c%20-%20english.ashx
The manual says:
"To automatically program, letting the switch
timer "record" your ON/OFF activities over a 24-hour period,
storing them as programmed settings:
Move the control lever to the OFF-CLEAR position for about
20 seconds. The red indicator light will go off and any previous
time settings will be cleared from memory.
Move the control lever to the ON position. The Red indicator
light will start flashing.
Press the dial as an ON/OFF switch to turn lights ON and OFF
at the ON and OFF times you desire for the first 24 hours.
At the end of the 24-hour period, the switch timer will be programmed
and the Red indicator light will stay ON, indicating
that the switch timer is in AUTOMATIC mode."
Sep 17, 2010 | Intermatic Programmable 24 Wall Switch...
477L Ask RXTX HHU Remote Logo
574 people viewed this question
Top Avital Vehicle Parts & Accessories Experts
D. E. Hev
baire
Billy Mac
Are you an Avital Vehicle Part and Accessory Expert? Answer questions, earn points and help others
