Question about Sharp AL-1655CS Copier
How do you calibrate the scanner bulb? I get a "Check SPF/RSPF" error message when trying to scan a document through the auto-feed tray and a local service company said that the scanner bulb needs to be calibrated. Any ideas?
    Guru:
  • 389 Answers
The Calibration of the scanner and calibration of the monitor - a complex process. Prcess requiring special equipment and experienced specialist. Not advantageously buy high-priced equipment for Calibration of its one scanner and monitor. If work high skilled, you it is necessary to return in service for calibration if you want this execute themselves, recommend to build apart monitor on test list, but then on test table by means of regulations adjusting the scanner on colour and density of the scene to build scanner
Posted on Oct 08, 2009
Testimonial: "Thank you for your reply. I've decided that it will be much less expensive in time and materials to just buy a replacement printer."
Samsung CLX-3160N Document jam Scanner Error
the printer samsung clx 3160nprinter to check the any papper part .to clear the papper jam then will be the adf scaner sencer hang.so you can change the adf paper senser or correct fix the senserliver. best wishes
Apr 05, 2013 | Samsung CLX 3160fn All-In-One Printer
Tray lifts to meet the rollers then drops back down. Error message 'No page was found in the feeder'
Clean the 'black dot' in the centre of the paper tray. There is an optical sensor under that. The tray will lift even without paper, but will go back immediately.
If the scanner stops after 3 pages, check disk space in your computer. If you are scanning in TIFF uncompressed, it takes lot of space. For color and Grey try JPG format, for mono TIFF G4 is the ideal option.
S. Mohan, Chennai, India
Mar 02, 2012 | Canon DR-9080C Path-Through Scanner
Message CHECK SPF/RSPF and will stick on scan often.
In the Jaguar series, (ar-168d) you will need to get into the simulations; press in rapid succession: # * C * You will know when you did it fast enough when all the display lights go out except the number display, press 41 start/copy. then 6 start/copy. Let the copier do what it needs to.
The scanner will move, keep the lid down, it will let you know when it is done when it goes silent. Then press CA key to clear out and try copies again.
Dec 15, 2009 | Sharp Office Equipment & Supplies
Tryong to use top feeder, it keeps reading
SPF is normal document feder
RSPF is autoreverse document feder.
Select the your document feder instaling the copiers,remove any originals to the glass.
Oct 21, 2009 | Sharp AR-168D Black and White Copier
Sharp AL 1551 CS RSPF not feeding
This can be a fault of the controller of the direct current. Apply to service This fault can be not eliminated by you.
Mar 23, 2009 | Sharp AL-1551CS Copier
OpScan Insight 4 scanner error message
i have a problem in opscan4 insight
Problem;
top/bottom image quality
Mar 20, 2009 | Office Equipment & Supplies
Problems with SPF message and black copies
The "Check SPF/RSPF" issue can be a couple of things
  1. If the scanner only moves from right to left then immediately moves back then the copier needs to be adjusted.
  2. If the scanner moves from right to left and tries to feed then displays message then the ADF needs to be cleaned.
Same for the dark issues
  1. If you lighten the exposure and the copies come out better then copier needs to be adjusted
  2. If you lighten the exposure and the copies come out the same then you may have a few problems check the following;
  • Open right side door and look at drum green/blue cylinder . If it is covered with toner (black film) then you might have a drum short.
  • Open right side door and look at drum, if it is not covered then you may have a board issue.
While making a copy off the glass listen to the right side of the copier and if you can hear a screeching sound then you could be having an electrical short that is causing your black copies.
Depending on your findings depends on the remedies.
Mar 16, 2009 | Sharp Office Equipment & Supplies
Resetting PaperPort after paper jam
I found the solution to this problem. Whenever the paper jammed in the feed tray, I was pulling the jammed paper out without opening the door of the feed tray. Apparently, PaperPort gets confused and does not know how to proceed. Now when I get a paper jam, I open the door of the feed tray, take out the paper, click on the paper jam error message in PaperPort, reset the paper in the feed tray, and then hit "scan." Works like a charm.
Sep 30, 2008 | Xerox DOCUMATE 510 Flatbed Scanner
Error Message: Check SPF/RSPF START to Resume
I just fixed this problem on my sharp all in one. The white rollers on the underside of the copier cover were not rolling well. I took an alcohol prep pad and started cleaning them, rolling as I went. A large piece of lint fell out. I put the documents in the document feeder and they fed through like a charm. Hope this helps.
Aug 06, 2008 | Sharp AL-1655CS Copier
Scanning in colour
Who and where do you get the idea that you should be able to, to scan in colour you need a colour scanner, yours is not it has a greyscale scanner only.
This machine has a scanning kit option but that is not colour see specs below.
AR-NS2 Network Scanning Kit (optional) 4
Type:
Flat bed monochrome scanning system
Original Feed System: Platen/document feeder, simplex/duplex with RSPF feeds up to 39 opm
Resolution:
200 dpi, 300 dpi, 600 dpi
Image Format:
TIFF 6.0, ITU-T G3/G4 TIFF, G3/G4 single/multi-page PDF
Scan Destinations:
E-mail, Desktop, FTP, URL
Destination Profiles:
Up to 200
Operating System:
Windows 95/98/ME, 2000, XP
Network Protocols:
TCP/IP (includes SMTP, LDAP, FTP)
Network Security:
E-mail server user authentication
Software:
Sharpdesk Document Management Software (included)
Link to brochere of the AR-M 237 GREYSCALE copier
Jan 10, 2008 | Sharp AR-M237 Copier
Sharp AL-1655CS Copier Logo
276 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
