Question about Thomson Audio Players & Recorders
Thomson MS5300 CD rack doesn't open
The 5 CD rack of my Thomson MS5300 Hi-Fi station doesn't open itself since yesterday. I've been owning that product for 2-3 years and I have never have any problemn until now. The problem came suddenly and I don't see any apparent cause.There are currently 3 Cds within and it's not the first time I've listened to them with this station so I don't think they are responsible for the problem.
Any advice or assistance ?
  • 8 Answers
SOURCE: Wurlitzer omt
If it shows just 8 in the LED display then it is caused by the amplifier being distorted (set too loud) and/or fuse Si3 on the amplifier panel requiring changing.
Posted on Dec 27, 2007
  • 35 Answers
SOURCE: Problem with my Thomson VMP300 5-in-1 music system.
hi shan72,yes this could be your prob, u could burn your cds in low speed that is less than 8x n try next time.hope this helps.
raj..
Posted on May 12, 2008
tech48
  • 624 Answers
SOURCE: Hi. Own A Kenwood RXD
It is the laser, If the cd mech is in the top of this one you may just need to clean the lens manually. Cleaning discs are not all that reliable. You can do this by taking the top off and looking at the area where the disc gets clamped to play. The laser has the small glass lens. That is the part you need to clean. Take a Q-tip and wet it very lightly with some windex or some alcohol. Make it so that the Q-tip is just barely wet. Then just lightly rub the lens without pushing on it hard at all. Just nice and easy over the glass lens. Then dyr it off with the dry end just like you did with the wet end. That's it. close it back up again and turn it on and see if it plays. If it still does not play you need a new laser. No other fix for it.
Posted on Jul 03, 2008
SOURCE: RCA RS2620 - CD works well ocassionally and then not at all
Simple solution - a CD lens cleaner did the job. $11
Posted on Feb 20, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: 3 disc Phillips cd player sometimes skips. It is
At some time in its life, the laser that reads the CD starts to get too weak to operate reliably. That's probably what's happening here. Unlike mechanical parts that can be inspected for wear, electronic parts tend to work fine one day, then the next, poof. The laser assembly is replaceable if you can locate the part and find someone to install it. An electronic service shop could give an estimate for repair. If you can provide the full model number, I'll see if I can find the part number.
Posted on Mar 08, 2010
Testimonial: "Very informative regarding my problem. Pgh also went to the trouble to ask what the model number of my stereo is in an effort to help me locate a part"
Oldsmobile aurora 1998 steering noise
Sounds like CV joints(Front-wheel drive) need to be inspected / replaced..
May 09, 2017 | 1998 Oldsmobile Aurora
Can I store my wine after I've opened it?
Once you've opened bottle of wine, no matter how much you age it, you be able to drink it for 3-5 days since you've opened it and you can never age it again.
Aug 13, 2012 | Furniture
Sony Mini - Hi Fi MHC - EC55 won't play CD's. Says it is "Reading" then says "No Disk". I have used lens cleaner and reset factory settings. Any ideas
If you've already tried to clean the lens then with no improvement then its down to the laser having failed.
In some cases these are availble as a replacement part but aren't normally cost effective.
Jul 11, 2011 | Sony 720W 5-Disc Mini Hi-Fi Component...
WLAN orange light blinking
Wi-Fi base station: Understanding and resolving a blinking amber status light Your Wi-Fi base station status light blinks amber.
Here are some of the more common reasons that the status light may blink amber:
  • The Wi-Fi base station has not yet been configured because it is new.
  • The Wi-Fi base station has been reset.
  • A new firmware update is available for the Wi-Fi base station.
  • No IP address is available for the Wi-Fi base station.
  • A Wi-Fi base station in Extended Mode is out-of-network Wi-Fi range of a primary Wi-Fi base station.
  • The WAN Ethernet cable is unplugged from the Wi-Fi base station.
  • The Wi-Fi base station lacks a path to the Internet (or local router).
  • Internet access may be temporarily unavailable from your Internet Service Provider (ISP).
  • Your AirPort Time Capsule has detected that the internal hard drive has reported a SMART error, and is failing (This requires firmware 7.5.2, and AirPort Utility 5.5.2).
A persistent, blinking, amber status light indicates that your Wi-Fi base station may require your attention.
How to resolve a blinking amber status light alert
Launch AirPort Utility to determine why your Wi-Fi base station status light is blinking amber.
Apple recommends that you use AirPort Utility 5.5.2 for Mac, AirPort Utility 5.5.2 for Windows, or a newer version of AirPort Utility if one is available.
  1. AirPort Utility 5.2 or later opens automatically if your Wi-Fi base station requires your attention. You may also choose to launch AirPort Utility at any time.
    Do not use any version of AirPort Utility earlier than 5.0.
    In Mac OS X, AirPort Utility is located in the Applications > Utilities folder.
    In Microsoft Windows, AirPort Utility can be located by clicking Start > All Programs > AirPort.
    Note: You may also locate and download the latest Wi-Fi base station firmware and software by clicking here.
  2. In the AirPort Utility window, locate your Wi-Fi base station and double-click on it to open the Summary window. Note: If you have more than one Wi-Fi base station, double-click on the icon for the Wi-Fi base station that has the amber circle next to it.
  3. When the Summary window appears, double-click the amber circle to the right of Wi-Fi base station Status to open the Status window.
  4. The Status window lists any conditions that require your attention. Respond to each item until there are no more items listed.
    Important
    : You must reset the Wi-Fi base station using the reset switch to re-enable checking for the conditions you ignored.
  5. Eliminating the blinking, amber status light may require making changes to a specific setting, or putting a checkmark in the "Ignore" checkbox beside any option you don't wish to change. A checkmark simply tells the AirPort that you are aware of the issue and you have chosen to ignore it. For example, you may wish to leave your AirPort open without a password so that anyone can join your wireless network.
  6. Click Update to apply your changes (the Wi-Fi base station will restart).
  7. After the Wi-Fi base station has restarted, the status light should be green and not blinking. If the status light stays amber in color and blinks after the Wi-Fi base station restarts, you may repeat the steps above.
Oct 03, 2017 | D-Link (DI-784) Wireless Router
How do I preset radio stations on my hi-fi system?
Owner's Manual is PN 3834RH0020U
On pg13
1. Press TUNER/BAND to select AM or FM
(Leftmost rectangular button on left of volume knob)
2. Select station by using TUNING +/-
3. Press PROGRAM/MEMO on the remote
A preset number will appear.
4. Press PRESET +/- (or PRESET ^/v on remote) to
select the preset number you want.
5. Press PROGRAM/MEMO again. The statio is stored.
6. Repeat above for more stations.
Believe you can store up to 30 stations.
Apr 28, 2009 | Denon DRA-375RD Receiver
Cd jam in panasonic sa-pm17
Hi. Got the very same problem. At christmas I had loaded two cd's in one of the racks. I used needlenose pliers as well and pulled each of the 5 trays out (well past their runners). Tried to dismantle the unit with the 3 screws on each side, but gave up. When I turn the power off and on and do a cd check the "hello" flashes then nothing, tried cd/change power button and basically everything else. All I can say is go easy on the unit as I was to forceful an now think i've ruined it. I'm gutted as this was a great mini hi-fi and has served me well. Best of luck with ur Panasonic, cheers.
Jan 04, 2009 | Audio Players & Recorders
Sony Micro Hi Fi with iPod port ?!?
no it's not an ipod port ipod port a slightly bigger.
Dec 08, 2008 | Sony (TDM-NW1) Docking Station Adapter for...
Top Thomson Audio Players & Recorders Experts
shaun taylor
Shehu Pro
Shehu Pro
 Mikey
Mikey
Are you a Thomson Audio Player and Recorder Expert? Answer questions, earn points and help others
