Most likely is is a stuck float or float switch. Next most likely possibility is a loose or broken wire going to the water fill valve. For some reason, mice seem to be attracted to this wire (usually 2 thin brown wires) - check for mouse droppings and look for chewed-through wires. Finally, if everything else seems okay, it is probably a bad water fill valve.
I have the same problem...im pretty sure its sumfin to do with when my system updated.... Blooding Frustrating ive been waiting 4 a rugby game since rugby 08
Make sure you are in the mode to view the videos you recorded and make sure the camera is plugged in to the power supply, then the finanlize option should be available
Insert the DVD-R into your recorder and press the STOP button. Press the MENU button then the directional keys until DISK MANAGER is highlighted. Press the directional buttons to highlight UN-FINALIZE and press enter.
If you format your DVD instead of using the EZ-Record mode you can add additional recording and finalize when you are ready to.
Tip: Go to Samsung.com and search for your model and view the FAQ section. Lots of good info.
depends what type of disc-rw's won't highlight sometimes because they don't always need to be finalized to play-insert the disc if r in another brand and see if you can finalize-go to bb or circuit and ask them if you can stick it in display and see if it comes up-if never proably was done already-also try different dvd players
Go to this link if you are unable to find the"Wrong Catridge" link
then you need to type "wrong cartridge " in the small search box on the website.
If the website asks you to select
"Category.=Multifunction"
"Product Type =Inkjet"
"Model= Multipass F50"
For some reason one of the discs that i have recorded on will not let
me finalise. When i put the disc in it says recording disabled and then
i go to the finalise menu and the finalise selection is unhighlighted.
How can i fix this so i can finalise the disc and use it on my computer? thanks
WITH THE DEVICE SET TO DVD AND NOT HDD
PRESS FUNCTIONS
GO TO OTHERS PRESS ENTER.
GO TO DISK MANAGEMENT PRESS ENTER
GO TO FINALIZE AND FOLLOW THE ON SCREEN INSTRUCTIONS
